Old 05-17-2009, 04:04 PM   #61
waserman
Oddometer: 30
supertrapp stock exhaust
I was under the impression that the disc portion of the "stock supertrapp exhaust" was more of a spark arrestor than a tunable exhaust,like some of their other exhausts.I don't believe that it would be overly loud if the discs were completely removed,although it would have to make it more free flowing to the extent that the muffler would allow. JMO
waserman is offline   Reply With Quote
Old 05-17-2009, 04:15 PM   #62
laramie LC4 OP
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,421
it serves both duties. adding over the stock amount may not add much, but reducing it sure will.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-17-2009, 04:19 PM   #63
waserman
Oddometer: 30
What would be the stock number of discs?I believe mine came with 8 on a 2000 640.
Old 05-17-2009, 04:26 PM   #64
laramie LC4 OP
crash test dummy!
Oddometer: 2,421
its either 8 or 10, its been so long that i cant remember. sorry....
laramie
Old 05-18-2009, 09:32 AM   #65
andredechh
Oddometer: 9
Bluhduh
Hi All,
Just bought a 06 LC4 supermoto. Haven't had fun with the bike since it has fuel leaking from the drain hose. What possible fix should i take? someone said it's possibly the fuel pump doesn't prime after turning the petcock into reserve position (which i did) and he said he solved the problem by blowing the gas tank breather hose. Can someone explain how to do this?
Andre - Qatar
Originally Posted by Gregarious
Great thread -- I've been using it help diagnose a leak problem. This should definitely be on the LC4 Index.
One item I would add is the air jet:
http://rides.webshots.com/photo/1058...36995609fbyxiT
I didn't know what these were until other threads discussed 1.1 and 1.2 air jets.
andredechh screwed with this post 05-18-2009 at 10:23 AM
andredechh is offline   Reply With Quote
Old 05-18-2009, 10:25 AM   #66
laramie LC4 OP
crash test dummy!
Oddometer: 2,421
read the section on setting the float height. this is pretty common for the carbs. if the float isnt set correctly you will get the "pissing" out of the float bowl and lot's of "bogging" while ridding, especially the rougher the road gets. the good news is that is pretty easy to fix.
laramie
Old 05-18-2009, 11:28 AM   #67
Kemosabe
Perpetual Adverturer
Kemosabe's Avatar
Oddometer: 124
Mine 2002 640e came with 6 six disc's in it.
Do you need to add disc or remove them to make the engine run richer?
I read somewhere you remove disc to run richer. I really can't see running less then the stock 6 though.
I did stuff the 142.5 main jet back in to ride Cinnamon Pass.
Kemosabe screwed with this post 05-18-2009 at 11:36 AM
Kemosabe is offline   Reply With Quote
Old 05-18-2009, 11:49 AM   #68
laramie LC4 OP
crash test dummy!
Oddometer: 2,421
reducing the number of disc restricts flow, which in turn richens the system. it also will reduce the volume of the exhaust. but personally i would not use this as a method to "jet" my carb. for that you really need to tear into the carb and change the actual jets.
laramie
Old 05-19-2009, 02:03 PM   #69
andredechh
Oddometer: 9
can someone look at my BST 40 float and tell me if the lid position is correct (it's hanging below the plastic) or should it be resting on the plastic bar?
and which one is the float valve? got any picture?
laramie
Old 05-20-2009, 02:19 PM   #70
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,144
Looks fine.
Smear a bit of 2-stroke oil on the o-rings before you mount it back up and they'll seat properly and with little hassle.
The float valve is hidden on that pic but the metal tab you can see presses on a pin that connects to the valve.
NordieBoy is offline   Reply With Quote
Old 05-20-2009, 02:52 PM   #71
laramie LC4 OP
crash test dummy!
Oddometer: 2,421
the float valve is the same thing as the "needle valve" i have in this pic...
not really sure what you are saying here? go back into the post and look at the "float height" section and that will hopefully help with any questions. if that doesn't work, then try and give me a little more info so i can understand what you are asking.
laramie
Old 05-26-2009, 10:03 AM   #72
thaiseli
Oddometer: 3
Fellow Wyomingite
Problem- Bad gas leak, stalling in idle, bogging
First round- cleaned float bowl....
Fixed- bogging, stalling and helped with response
Problem- Still leaks as much fluid as my 3 yr old nephew
Round 2- Set float height as the ktm manual and your manual said (lines parallel at vertical)
Fixed- No Gas leak, but bike won't start (not enough gas going to carb?)
Round 3- Readjust float height
problem- gas leak back, bike will start but barely
I'm out of ideas I don't know if i have worn o rings or if I need to adjust float height like I did in round two or if the idle screw needs adjusting maybe it's bike shop time.
thaiseli is offline   Reply With Quote
Old 05-26-2009, 11:26 AM   #73
waserman
Oddometer: 30
Well I finally got the jetting sorted out,the racing air box cover installed,needle set where it seems to run the best and a smile the first time I twisted the throttle hard.Front end lofts nicely with little effort,still averaging between 40 and 50 mpg depending on riding style.I ended up with 47.5 pilot,160 main,needle clip second from full rich,still playing with gas screw,as the weather is wacked here,goes from 50 to 87 overnight.Now it's on to the suspension.Oh forgot to mention,removed all discs as I'm not riding offroad right now,waiting for another full leg brace to be made.I'm looking for some info on the forks,mine has what appear to be the same ones I had on my 98 TE610.I believe they are 50mm zokes or wp.Where can I find a cd or manual for this bike,2000 LC4 640? Thanks
Old 05-26-2009, 12:01 PM   #74
laramie LC4 OP
crash test dummy!
Oddometer: 2,421
well, your gonna have to fix the leak. if it will not stop when adjusted correctly, or completely shuts off the gas you will probably need to replace your float vlave and needle. i'd bet that it just needs to be adjusted personally, but ya never know. they can and do go bad....
Part Number: 58431020000
Description: NEEDLE VALVE 2,8MM
Retail: $43.95
once you get the float set then move on. where is your fuel/air screw set at? and what idle jet do you have? see if you can "richen" the bottom up (right-tighty leans it out, left-loosy richens it up). you should be somewhere in the 2 1/4 to 2 3/4 range.
start with that and see what happens. if ya need more help just ask....
laramie
Old 05-26-2009, 05:12 PM   #75
thaiseli
Oddometer: 3
little more progress
Well Laramie,
I replaced the o ring on the needle valve. The gas leak has stopped and the bike runs. When in idle the bike will run strong but with an inconsistent stutter every 4 seconds and the throttle is very responsive. I'm guessing to high of a float level. I don't know if it's a good idea to go in and try to adjust the float lever tab again. If you think i can fix the problem with the air/fuel or maybe the idle screw, let me know. Great article and thanks for the help.
suggestion- poor your miller lite into a clear glass and then "accidently" spill a little motor oil in there for added color and flavor but mainly to ward off the beer snobs
Times are GMT -7.   It's 03:13 PM.
