Old 02-13-2013, 04:21 PM   #1231
wah64apache
Older Than Dirt
Oddometer: 64
Originally Posted by wah64apache View Post
Auspuff it is an M5 with an estimate of 15 threads per CM. I say estimate because there are only 5 threads on it .
Cheers, Frank
I must have measured the wrong piece as Derek says it is M6 and he knows far more about this bike and carb. If I can find the picture book I was looking at. Cheers, Frank
wah64apache is offline   Reply With Quote
Old 02-13-2013, 04:29 PM   #1232
wah64apache
Older Than Dirt
Oddometer: 64
Yep, I measured the idle jet, next to the main jet, not the fuel/air screw. Sorry for the error. Cheers, Frank
Old 02-13-2013, 11:26 PM   #1233
Auspuff
Auspuff's Avatar
Oddometer: 5
wah64apache & motolab - Many thanks for your kind efforts and lightning-quick responses to such an obscure question.
Never argue with a fool; bystanders cannot tell who's who!
Auspuff is offline   Reply With Quote
Old 02-17-2013, 10:45 PM   #1234
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,100
Originally Posted by motolab View Post
The item is a cold start enrichment metering jet. It is normally located inside the upstream end of the cold start enrichment feed pipe (The cold start enrichment feed pipe is part of the float cage. The o-ring that isn't the float seat o-ring attaches to the downstream end). You should be able to push it back into its hole. If it won't stay, you can superglue or cylindrical parts bond it in (don't obstruct the hole in the process).
Regards,
Derek
In hunting around for a hard starting problem on my 640, I notice that this metering jet is absent from my enrichment feed pipe. Was it used on all bikes? If it was there, it must affect performance- what do I need to buy to get another one?
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 02-17-2013, 11:02 PM   #1235
motolab
motolab's Avatar
Oddometer: 2,632
It's used on all BST40 carburetors. It's not available separately, so you'll need a new float assembly.
Regards,
Derek
Addendum: It turns out that the cold start enrichment metering jet is not used on KTMs (the place where it would press into on other models is left open).
motolab screwed with this post 11-09-2014 at 08:34 AM
motolab is offline   Reply With Quote
Old 02-17-2013, 11:07 PM   #1236
slackmeyer
slackmeyer's Avatar
Oddometer: 3,100
Regards,
Derek
Thanks, I'll give you a call about getting that assembly on it's way soon.
Zak
ktm
old bmw
others
Old 03-04-2013, 07:08 PM   #1237
rockscrambler
rock climber
Oddometer: 4
hey guys i need some help figuring out where the vacuum lines on the right side of bst 40 (dr650) go (the side that says mikuni). i've figured out where the big 1/2" hose goes. but would like to know where the 1/4 " vacuum line that comes out the side of the carb goes?. this is a calif. model. the other line from other side of carb goes to petcock vacuum.
thanks in advance
rockscrambler is offline   Reply With Quote
Old 03-04-2013, 07:17 PM   #1238
motolab
motolab's Avatar
Oddometer: 2,632
The hose you are referring to is not a vacuum line. It's a float bowl vent line, and on a California model would connect to a charcoal canister.
Regards,
Derek
Old 03-04-2013, 07:30 PM   #1239
ER70S-2
ER70S-2's Avatar
Oddometer: 6,490
205'd by Derek
One of these:
Or this one:
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 03-04-2013, 07:39 PM   #1240
motolab
motolab's Avatar
Oddometer: 2,632
Originally Posted by ER70S-2 View Post
205'd by Derek
One of these:
Or this one:
Unless I misunderstood rockscrambler's post, he had already identified the petcock vacuum line.
Regards,
Derek
P.S.: What's "205d" mean?
Old 03-04-2013, 07:58 PM   #1241
theGrinch
SNF Dream Riders
theGrinch's Avatar
Oddometer: 2,071
BST Carb parts order
Derek,
PMed you, could you give me a call?
Thanks,
Peter
Originally Posted by pcvance View Post
Who's the clueless noob?
theGrinch is online now   Reply With Quote
Old 03-04-2013, 08:20 PM   #1242
rockscrambler
rock climber
Oddometer: 4
yes, its in the pic "one of these". and is the smaller vacuum line, do you know what that connects to on the other end? thanks guys!
Old 03-04-2013, 08:43 PM   #1243
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,543
It doesn't connect to anything. It vents to air and is routed inside the outer frame back past the battery. It ends just past the battery.
joefromsf is online now   Reply With Quote
Old 03-04-2013, 08:55 PM   #1244
ER70S-2
ER70S-2's Avatar
Oddometer: 6,490
This one:
Goes here: Pay attention, the photos will mislead you. The 1st pic shows the hose goes to the left, the second shows the hose comes in from the left (backwards).
2013 WR250R
Old 03-04-2013, 08:57 PM   #1245
joefromsf
Dark Happens
joefromsf's Avatar
Oddometer: 1,543
That's what I get for trying to answer from memory. So it ends before the battery. I was right about venting to air though.
Times are GMT -7.   It's 03:36 PM.
