Old 02-02-2010, 06:24 PM   #4621
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Cheers
Originally Posted by clintnz
Don't panic until you have checked the cam bearings mate. My 640 often had fuzz on the bung (maybe not quite that much tho) & the only thing that's worn out in 80 000 km was the inlet cam follower roller bearing. It could just be that $30 bearing, it may have got bad enough to damage the cam which is quite a bit worse, but nowhere near as bad as a big end failure.
Cheers
Clint
thanks clintnz makes me feel a little better.. I'm going to check that tonight or the night after and try get the bike back together this weekend and take it for a ride and see how it goes.. Think I'll do A few hundred ks and dump the oil again and see the verdict..
There are flat spots on the bore of the slave cylinder so it needs replacing rather than a new o ring.. Is it difficult to replace that bearing in the cam?
Cheers
GreyDawggg is offline   Reply With Quote
Old 02-02-2010, 07:27 PM   #4622
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 8,007
Originally Posted by Ogre_fl
Curious, I thought the idea behind the mineral oil based clutch fluid was because it was some what benign should it leak into the engine.
I don't know the reasoning behind the mineral hydraulic oil, but it is not rated for the type of stresses found inside the motor at all. Adding water to your oil would probably have a similar effect, as the stuff is very light. I was first warned by Frank Pons, ex GP and World MX mechanic/tuner, that the stuff needed to be removed ASAP for the health of the big ends. I figured who am I to argue? I just did it.
GodSilla is offline   Reply With Quote
Old 02-02-2010, 10:32 PM   #4623
bmwktmbill
Traveler
Oddometer: 5,219
Originally Posted by CodyY
on pavement
Increase the tire pressure, increase the preload in the rear.
Are you running bags?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 02-03-2010, 07:40 AM   #4624
CodyY
ADVenture Capitalist
CodyY's Avatar
Oddometer: 9,507
bill
Lots of rear preload right now. I'm 225lbs and still running stock springs.
It got better when I moved further back on the seat. Tire pressure could have done it. It may have been low.
Wolfman enduro's with maybe 5-8lbs of load. Pair of shoes, handfull of tools, and a change of clothes is all.
Not an ACTUAL motorcyclist
CodyY is offline   Reply With Quote
Old 02-03-2010, 11:44 AM   #4625
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,584
Cheers
Hi Mate, there is a thread on doing the cam & follower bearing: http://www.advrider.com/forums/showthread.php?t=286283 Not a full how to there but Creeper's re-sealing the rocker cover guide is a very complete guide to dis/reassembling these parts: http://www.advrider.com/forums/showthread.php?t=112127
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 02-03-2010, 01:50 PM   #4626
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
B-Rod, thanks for that link, I'd missed it.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 02-03-2010, 10:07 PM   #4627
bmwktmbill
Traveler
Oddometer: 5,219
It's nice to carry an 12V plug in electric air pump. I tore the plastic off a Walmart model to make mine smaller. It plugs in the electric vest pigtail and wraps in a rag. I either pump up or slow down when I get to pavement.
bill
Bill Shockley
Old 02-04-2010, 03:24 AM   #4628
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
my pump plugs into the powerlet plug on my console
Beerthief
Old 02-04-2010, 07:26 AM   #4629
CodyY
CodyY's Avatar
Oddometer: 9,507
bill
I've got the slime that plugs into my battery tender lead.
Old 02-05-2010, 02:54 AM   #4630
bmwktmbill
Traveler
Oddometer: 5,219
Youre set.
b
Bill Shockley
Old 02-05-2010, 03:55 PM   #4631
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,312
I finally have a pic worth posting.
My ride home from work this evening...
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 02-05-2010, 04:24 PM   #4632
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
lovely shot there
Beerthief
Old 02-05-2010, 04:29 PM   #4633
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,312
Thanks, Last week I was going the other way on the 950 and well, let's just say the crash bars came in very handy!
Michael
Old 02-05-2010, 05:00 PM   #4634
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,354
Originally Posted by mtbdemon
I have a 1997 620 Adventure and can't seem to find the correct spec for coolant. It seems I might have a leak where coolant is being burnt off, but I'm not sure. Do I need to drain all the coolant and simply put in some prestone? Thanks!
Ken
Use a coolant made for aluminum.
You likely have a water pump seal leak. Look in the LC4 640 sticky http://www.advrider.com/forums/showthread.php?t=86958 and scroll down to just above the somewhat scary looking portrait and check out LC4 Pilot's wisdom.
Sparrowhawk is offline   Reply With Quote
Old 02-05-2010, 05:08 PM   #4635
Sparrowhawk
Oddometer: 2,354
on pavement
New tires? These bikes are famous for the weaves for the first few hundred miles on a new set of rubber. I've had the experience when I put on a 908RR rear with an older front and new Scorpion Pro on the front with an older rear. The symptoms went away after about 300 miles on the tires.
Times are GMT -7.   It's 09:48 PM.
