Old 02-06-2010, 06:13 PM   #4651
1coolbanana
1coolbanana's Avatar
Oddometer: 1,437
Originally Posted by Geekventure
No...it's just the question underlined.
Thanks...I have read that link, but I'm still not sure...
Our (early 640's) bikes have not got the dual ignition curve mapping built into the CDI.
If we buy the other CDI module, part no 584.39.031.300, then we are able to switch high/low octane modes by connecting or disconnecting the red loop wire (switch on the dash would be better).
It should be a straight swap over process from what I can gather.
Ive looked up the price list and its a $311 part.
Hope this helps?
1coolbanana is offline   Reply With Quote
Old 02-06-2010, 06:18 PM   #4652
Geekventure
Geekventure's Avatar
Oddometer: 117
Thumb CDI low octane loop?
Thanks a lot!
"Not all those who wander are lost." - J. R. R. Tolkien
Geekventure is offline   Reply With Quote
Old 02-06-2010, 07:50 PM   #4653
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,207
2006-07 Ktm 640 Adventure Enduro Cdi Igniter Unit
This could be your lucky day....
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 02-06-2010, 07:55 PM   #4654
1coolbanana
Oddometer: 1,437
Originally Posted by mgorman
What a bummer, I wish it was
Thanks, but thats a late model with different harness.
The one Im looking for is about a 2000 model but a different version of my existing one.
Old 02-06-2010, 07:59 PM   #4655
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,207
there is a 2nd unit listed. It says wiring harness and has a bunch of extras listed. Not sure if they are part of the deal or listed as fits...
Michael
Old 02-06-2010, 08:10 PM   #4656
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,179
Lets go to the reasons why they changed to a switchable CDI in 03.
In 03 the engine received the new hi flo head which put into play bigger valves for more flow.... They also went to a thinner base gasket which likely bumped compression up a little giving the engine a higher chance for detonation over the 02 and older engines....
gunnerbuck is online now   Reply With Quote
Old 02-06-2010, 08:18 PM   #4657
1coolbanana
Oddometer: 1,437
So are you saying that its not necessary in the early "Low Flow" head models?
Why then is there an alternative CDI for low octane on early models available?
The change could well be a perceived need and an improvement on something that was lacking on earlier models?
Old 02-06-2010, 08:26 PM   #4658
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,179
For round the world travel the switchable ignition is a very good idea on all LC 4 engines regardless of year... In some 3rd world countries the fuel quality is so poor that without the switch you'll cook the motor in short order....
If that type of travel is in your plans indeed aquire a switchable CDI...
Old 02-06-2010, 08:37 PM   #4659
overlandr
Dystopist
Oddometer: 5,864
Here's a link to some CR info on the 03 -5 engines
http://www.advrider.com/forums/showthread.php?t=471646
overlandr is offline   Reply With Quote
Old 02-07-2010, 02:49 AM   #4660
makazica
makazica's Avatar
Oddometer: 746
May I disagree with this?
The old paper gasket was 0,7 mm thick, the new metal gasket is 0,5mm with a niche around.....when tightening the cylinder you squash the paper gasket...also you do the same with the "niche" on the metal gasket......so my opinon is that there's no significant difference in compression due to different material base gasket.
makazica is offline   Reply With Quote
Old 02-07-2010, 02:53 AM   #4661
bmwktmbill
Traveler
Oddometer: 5,103
I don't know the '03 engine by experience but I can tell you that in Mongolia I ran the lowest octane Russian fuel in my '02, someone said the Russian gas was 70 octane but the numbers are useless without confirmation, anyway the bike ran fine, just a little ping at wide open throttle. Probably I rode 1K miles in the Gobi desert on this stuff. This was the worst gas I have found so far for power.
I had the switchable ignition box for all this but never used it. I just listened to the bike and stayed off WFO throttle, heck it was hardly possible to run hard in Mongolia given the rough tracks.
I blew the head gasket 300 miles south of Ulan Bator and had the bike trucked to the capitol, with the head off it was possible to examine the cylinder and piston as well as the head. Honestly they were fine. At this point I was about 7K miles from my home in Wisconsin.
The head gasket failure had nothing to do with the gas, the head came loose from vibration.
I think I did the whole trip to that point on regular fuel and after replacing the head gasket I continued across Russia, through the east bloc to the KTM factory in Mattighofen and then to Germany on regular. The factory serviced the bike in Austria and gave it the thumbs up. From Germany the machine was shipped to Nova Scotia and my son rode it to Wisconsin on regular gas. I have run it two more years since on the ATV trails in Wisconsin on regular gas. It runs cleanly from 1600 rpm to redline in all gears without a miss or a ping. The jetting is stock, snorkle removed, KTM Competition exhaust, needle raised one notch.
(I have also ridden in North, Central and South America on my BMW Airhead and my KTM. Both machines call for high octane but I always run reglar. In S. America I ran the BMW above 14Kft elevation on regular gas. My KTM has been across the Rockies several times with no issues and was run hard in the Alps on regular( way above the treeline).)
Here it is this fall on the trail. Regular gas in the tank...
That's a pretty blue on the pipe.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill screwed with this post 02-07-2010 at 03:20 AM
bmwktmbill is offline   Reply With Quote
Old 02-07-2010, 02:57 AM   #4662
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,563
Maybe not, IIRC there are reports of igniter boxes being fried by switching with the engine running (not sure if it was this bike or not). It's probably better to mount the switch behind a sidecover, or under the seat, or somewhere else accessible fairly swiftly but where it won't get bumped at an inopportune time.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 02-07-2010, 03:00 AM   #4663
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,563
Originally Posted by GreyDawggg
Where could all that fine silver metal come from then?? Any suggestions?
Starter clutch?
Cheers,
Colin
The Stable
Old 02-07-2010, 03:01 AM   #4664
1coolbanana
Oddometer: 1,437
Originally Posted by bmwktmbill
I don't know the '03 engine by experience but I can tell you that in Mongolia I ran the lowest octane Russian fuel, someone said it was 70 octane but the numbers are useless without confirmation, anyway the bike ran fine, just a little ping at wide open throttle. Probably I rode 1K miles in the Gobi desert on this stuff.
I had the switchable ignition box but never used it. I just listened to the bike and stayed off WFO throttle, heck it was hardly possible anyway given the tracks.
I blew the head gasket 300 miles south of Ulan Bator and had the bike trucked to the capitol, with the head off it was possible to examine the cylinder and piston as well as the head. Honestly they were fine. At this point I was about 7K miles from my home in Wisconsin. I think I did the whole trip to that point on regular and after replacing the head gasket I continued across Russia, through the east bloc to the KTM factory in Mattighofen and then to Germany. The factory serviced the bike and gave it the thumbs up. From Germany the machine was shipped to Nova Scotia and my son rode it to Wisconsin on regular gas. I have run it two more years since on the ATV trails in Wisconsin on regular gas. It runs cleanly from 1600 rpm to redline in all gears without a miss or a ping. The jetting is stock, snorkle removed, KTM Competition exhaust, needle raised one notch.
bill
Well you know what Bill?
Thats good enough for me and since my bike is identical to yours I think Ill just save myself the grief and just leave it alone and it will be fine.
BTW, have you reinforced your subframe? And I know its a dumb question but is the Renazco been worth it?
Old 02-07-2010, 03:02 AM   #4665
1coolbanana
Oddometer: 1,437
Good point and good idea
Times are GMT -7.   It's 06:03 AM.
