02-17-2010, 06:08 AM
#4741 |
Adventure seeker
Hi all!! If anyone on here could give me any advice please check out my thread on my 640:
http://www.advrider.com/forums/showthread.php?t=551527 Cheers |
02-17-2010, 07:10 AM
#4742 |
Oddometer: 88
Here's my 04 640 E
BMW R1150 GS '01 - Sold KTM 640 LC4 E '04 - Sold Honda XRV 750 '02 - Sold Honda XRV 750 '95 - Sold |
02-17-2010, 08:25 AM
#4743 |
slave to gravity
Me on my buddy's 2000 640E with SM wheels on the track in Quebec last year, ghetto style
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk |
02-17-2010, 02:29 PM
#4744 | |
ceiling unlimited
Oddometer: 1,806
1.0 inch long screws with another tire inside the main tire to accept the long screws. The tires are heavy. Dune Loop (dunlop) 752. ![]() Kenda 4.0 x 18. Narrow and stiff.
sideways and smiling WIsixfitty screwed with this post 02-17-2010 at 05:45 PM |
02-18-2010, 12:10 AM
#4745 |
I did that.
Oddometer: 6,436
Question for the collective.
Background : Rolled up at a mates place yesterday and noticed some brake fluid driping from the front caliper bleed valve. No worries, thought I, borrowed a 10mm spanner, it spun on the nut part, went for an 8mm never going to fit, found a 9mm, wouldn't fit either. Turns out it is a 10mm thread with a 3/8 nut part. WTF? I thought these bikes were metric? Asked the mechanic at the local dealers, about as much help as a sparkplug in a christmas cake. So, is this a normal fitting for these bikes? Mine's a 2003 model. And are these 10mm bleed valves commonly available from brake shops? Nervously awaiting replies, as I have a ride planned to the World Superbikes and 2 days to sort it. |
02-18-2010, 12:52 AM
#4746 | |
Oddometer: 1,222
My hex size is 11mm spanner, a bit loose though. Front and rear are the same. Hope that helps
02-18-2010, 04:23 AM
#4747 |
I did that.
Oddometer: 6,436
Thanks mate. Got some other responses nearer home that the other guys seem to have brake bleed nipples that an an 11mm hex key, so I guess mine might be bastard children. I'll be on the phone in the morning to try and track a couple of new ones down. Might try the local Husky dealer too.
UPDATE: The 11mm spanner that seems to fit is for an updated bleeder that is in fact 7/16", which is why it takes an odd size 11mm. Mine seems to be an earlier 3/8" fitting. Why have a metric thread and an imperial nut? Go figure..... GodSilla screwed with this post 02-20-2010 at 02:30 PM |
02-18-2010, 08:32 AM
#4748 |
AKA; Mongo-E
Oddometer: 1,750
Hello Everyone!
Here is my 2001 640e. ![]() Not as clean as some I have seen here, but it sure gets the job done! Take Care All. Be Blessed, Eric. |
02-18-2010, 08:56 AM
#4749 |
ADVenture Capitalist
http://advrider.com/forums/showthread.php?t=202049
I believe this is the thread you guys are looking for.
Not an ACTUAL motorcyclist |
02-18-2010, 12:10 PM
#4750 |
Lost
Oddometer: 654
Well well...
Look what I found: ![]() What are they, you ask? Well maybe the next picture provides some clue: ![]() No? Well, here's the answer: ![]() The subframe attachment points/threads have sheared off. Sonofa... I guess it's time to fire up the trusty MIG once again.Watch those subframes, guys, especially if you have hard luggage on your LC4. Cheers, Tseta |
02-18-2010, 12:51 PM
#4751 |
Oddometer: 814
Mikä ei tärise rikki varisee irti...
Older frame/subframe models use simple bolt and nut system on these joints. |
02-18-2010, 06:36 PM
#4752 |
BITD/Rallye
Oddometer: 5,311
I like my 01 adv frame its easier than the 03 sxc to get it back together... and you dont have to worry about cross threading a nut welded on...
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle |
02-18-2010, 08:23 PM
#4753 |
Oddometer: 207
Hi all,
I know this info is out there somewhere but can't seam to locate it now that I need it. I'm looking to add some hard bags to the 640a and I remember a discussion on mounting brackets one to avoid one to look for. Can anyone point me in the right direction? Thanks, Gerst |
02-18-2010, 09:38 PM
#4754 | |
Oddometer: 534
http://touratech-usa.com/shop/show.l...4275YTg3FCDF1C |
02-19-2010, 08:08 AM
#4755 |
Oddometer: 207
Thanks Jiminy C,
But I was hoping to get a link to the the actual thread here that dicusses the pros and cons of different racks and paniers. I looked in the 640 index with no luck, I think I read about it in this thread. The search function, your friend not mine |
