03-15-2010, 02:21 PM
#4921 |
Custom User Title
Oddometer: 608
Looks good Brian, and those numbers don't seem too bad. Once T-odd brings home that Husky your 640 won't seem so loud!
C. |
03-15-2010, 02:26 PM
#4922 |
slave to gravity
nice! I would really like to make my akro quieter too, thanks for putting that up for us
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk |
03-15-2010, 02:40 PM
#4923 | ||
RubberNecker
Oddometer: 1,698
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI |
03-15-2010, 02:50 PM
#4924 |
slave to gravity
I don't know that there ever was an insert? I ordered the pipe from a dealer in Indiana a couple of years ago. It's definitely loud. I'll look more closely when I'm back at it.
03-15-2010, 04:33 PM
#4925 |
Oddometer: 50
My new (used) 640 adv.
Picked my '07 640 adv last Friday, and have already put about 500 k's on it. It has only done about 4000 k's in total and without going thru this entire thread for the answers was wondering if someone can help with 3 questions I have? 1. I used the lights last night and found that they are absolutely abysmal, I left it on low beam as that seemed better than high beam. Is this a simple fix with different globes, or is something else needed. 2. I had it back at the dealers yesterday after I found that it was leaking rapidly from the overflow tube from the carby at idle, it was all pulled apart and cleaned. The mechanic pointed out a bit of fine grit on the needle etc, that could have caused the needle to not seat properly. They have also ordered a new needle as it is rubber tipped and scoring may have occurred on the tip of the needle. This will be fitted on Wednesday as the the leak is nowhere near as bad, but it will still let go a few drops when left sitting with the fuel tap on. Anyone else had this problem? 3. Mufflers. My bike is bog standard & I will be fitting a muffler in due course. Any suggestions on preference such as Staintune, Akropovic, or the KTM SXC muffler. On this point I have also heard that the muffler, re jetting & opening the air box actually softens the vibes? Anyway, other than those points I am really happy with bike & look forward to getting lost on it. Thanks for any responses in advance.
KTM250 EXC-F FOR THE TIGHT STUFF KTM640 FOR THE DISTANCE SUZUKI GSXR750 FOR THE BLACK WINDY STUFF |
03-15-2010, 11:08 PM
#4926 |
Oddometer: 814
For lights, go for HIDs.
And connect lights so low beam stays on with high beam. Its easy one wire installation, maybe with switch. Is float level checket to be ok? |
03-15-2010, 11:41 PM
#4927 |
640-24-7
Oddometer: 53
loooooong distance traveling
can anyone tell me what to look out for before i go on my 1600km trip with my '05 6fotty?? and if there is anything specific that i sould check wilst traveling exept oil and fuel!! the 6fotty is now tikking over 43050km's and was serviced by KTM on 40990km's.. i am planing to drive down to the coast in one day , thats 760km i wanna do in one day..
http://mefi.us/images/fuelly/sig-metric/85122.png better to sweat than to bleed there is only one kind of adventure, the lc4 kind!! |
03-16-2010, 03:59 AM
#4928 | |
Adventure seeker
03-16-2010, 06:27 AM
#4929 |
640-24-7
Oddometer: 53
sad day
thx grey dawgg, dut unfortunatley i just heard a very scary funny eninge noise, that gets worse higher the rev.. just notesed it this afternoon.
Back to KTM to check it out.... just the sound of it sounds expencive.... good bye life long dream.... you know the funy thing is when i took my bike to KTM for service they asked me is there anything in particular to check, i said 'oh yes plz check the engines guts, something sounds funny to me' . KTM took the liberty of tearing her down and assembleing it, and then tell me nothing wrong, all good.....
03-16-2010, 06:46 AM
#4930 |
Adventure seeker
Ah sorry mate that sucks and I know how you feel.. I just spent big bucks on mine only to find out I need to be spend more because the problem isn't solved so I'm pulling the engine out to sort it out properly.. This bike has taught me patience!
You are likely to get more help from a helpful inmate on here solving your problem than through a dealer and you then learn how your bike works and you'll save cash! Can you describe in a little more detail what sort of noise the engine makes? Is it vibrating more than normal? engine normally is noisy but I usually notice less of the engine noise with higher revs.. Hope it works out! |
03-16-2010, 11:48 AM
#4931 | |
640-24-7
Oddometer: 53
... want to open her myself but have way to little knowlage, or tools..
03-16-2010, 12:13 PM
#4932 |
Oddometer: 814
Any idea from what part of engine sound is coming?
Engine stethoscopes are cheap... Try listen with stick, screwdriver or tube. Any change on sound if engine is on idle or on gear? Any change on valve clearances or clutch feel? Cam chain tensioner, is it installed right? If front sprocket is removed, and gear on neutral, transmission should spin freely and without any rough spots or sounds. E-Starter intermediate gear is easy to remove and allows some inspection to how freewheel works. |
03-16-2010, 05:14 PM
#4933 | |
Trans-Global Chook Chaser
Oddometer: 2,699
If you are planning to travel far on any bike it's a good idea to learn how to do at least a basic service yourself. Luckily for you there are some excellent tutorials written specially for the LC4 - have a look in the Index There are no special tools required. Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
03-16-2010, 07:16 PM
#4934 | |
Big Bike, Slow Rider
Oddometer: 497
And if you don't catch it in time, you can destroy the cam and follower in less than 1000 kms (about 600miles).
Don't ask me how I know. I had it on my list of things to do and didn't get around to it before the ride. Good thing is, the bike got me home! Don't forget, loud rattly motors save lives!! A $50 job is now $500. David. Quote:
David 2005 KTM 640A 2008 Wee-Strom |
03-16-2010, 07:28 PM
#4935 | |
Oddometer: 2,699
Cheers Clint
