Old 06-05-2010, 06:46 AM   #5341
K2ride
Single track mind!
K2ride's Avatar
Oddometer: 1,615
Be careful removing the lower cap (lower clips); had to break off one of its retaining clip openings to remove mine the first time.
...much faster, these days; thank God for electrical tape!
Ride hard, ...life's short!
K2ride screwed with this post 06-05-2010 at 07:04 AM
K2ride is offline   Reply With Quote
Old 06-05-2010, 08:32 AM   #5342
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,470
ah yes, I've had the pleasure of removing that before
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 06-06-2010, 01:12 PM   #5343
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,137
I finally got to the wiring in the dash. I added a fuse block and going to add this
for power to my accessories on the dash, GPSr, phone or whatever. As most handheld items these days charge on 5v and .5(500mA)Amps of power and most also have USB charging available this is an ideal way to go via the old method of having individual cig power adapters for each device.
While I was in there I finally put my repaired IMO back in and now I cant find my notes on what hooks to what. I am left with a 3pin(blue-violet-grey) and a 2pin(red-black). If my memory serves me the 3pin is unused and is for tachometer. And the 2pin connects to one of the roadbook connectors(blue/yellow-brown). I can't find the IMO in the wiring diagram, why is that?!
Can anyone confirm this?
'99 640A USmodel
Low594 is offline   Reply With Quote
Old 06-06-2010, 08:08 PM   #5344
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
well I've been saving up for all my 640 parts for over 4 months now after my motor was a dud. I thought I finally have them all and was going to build the engine this week or next week.. I opened the box and took apart the "engine cases complete with bearings" and was delighted to discover the bastards don't give you the f'ing main crank bearings.. I am super pissed off.. Why clearly state that the cases come complete and then leave out the most important bearings from the cases.. Good thing is they sent me the wrong cylinder which happens to be the right cylinder for the wrong piston I was sent.. bunch of dumb asses! I am sad that this is the way it's turned out for my 640.. I have spent so many hours, blood sweat and tears. I've literally sacrificing having a life to afford the thing and it has been a nightmare.. What to do...
GreyDawggg is offline   Reply With Quote
Old 06-06-2010, 09:35 PM   #5345
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,692
you can source those bearings out of a supplier cheaper than oem and the same bearing...
wrk2surf is offline   Reply With Quote
Old 06-07-2010, 04:24 AM   #5346
MattyDB
Oddometer: 9
ADV '98 fuel line routing...
Hi ADV crew - now Wrk2Surf has been helping out but im still confused as to what hose goes where - I have a '98 ADV LC4 and cant figure out the fuel line routing..? I have 3 taps on the tank two main taps (one each side, and im thinking one has two outputs) and one reserve..
Mikuni LeftSide
http://s149.photobucket.com/albums/s...t=IMAG0335.jpg
Mikuni Right side
http://s149.photobucket.com/albums/s...t=IMAG0334.jpg
Mikuni Top
Fuel Pump
http://s149.photobucket.com/albums/s...t=IMAG0331.jpg
MattyDB is offline   Reply With Quote
Old 06-07-2010, 09:16 AM   #5347
wrk2surf
wrk2surf's Avatar
Oddometer: 6,692
its a delorto carb... havent had the pleasure... you might need two T's..
Old 06-07-2010, 09:34 AM   #5348
MattyDB
Oddometer: 9
Ah.. a Delorto - yes I have two tee's just need to work out which one goes where! Thanks for your patience , my questions may be a bit noob..
Old 06-07-2010, 07:37 PM   #5349
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
local reputable bearing supplier, nj 207 = 112AU$ + 50$ postage and 1 to 2 weeks wait for it from singapore. nj 306 = 92AU$ and in stock. Damn! Well I won't be going local unfortunately. Back to US where I can get both of the crank bearings, shims needed and a freewheel bearing I forgot to get for 200$Au delivered. 5 months ive waited will be atleast another 2 or 3 weeks.
Old 06-07-2010, 08:13 PM   #5350
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,137
Anyone??
'99 640A USmodel
Also, while trouble shooting the grip heaters, I found that I only have 3.5 volts at both of the roadbook connectors. Is this normal? I would think it would be at least 12 volts if not the 13.5 volts at the battery and elsewhere on the bike. I should clarify, I am only using the roadbook power to turn the coil of the relay on, this way they are only on when the bike is running. The gripheaters will be drawing their current directly from the battery via my added fuseblock.
Low594 screwed with this post 06-07-2010 at 10:21 PM
Old 06-07-2010, 11:45 PM   #5351
seahaul
Oddometer: 2
hey, sorry if this has been asked but does anyone have a link to KTM for the 2007 640 owners manual? there are links for all bikes still in production and for previous years but since the 640 adv is gone there is no easy path.
thx
2008 KTM 450 EXC-R
2008 KLR 650 (sold)
2007 KTM 640 Adventure
2006 Honda CRF150F
2006 KTM 85SX
2005 Honda CRF100F
seahaul is offline   Reply With Quote
Old 06-08-2010, 12:51 AM   #5352
wrk2surf
wrk2surf's Avatar
Oddometer: 6,692
took me 6 months ...
Old 06-08-2010, 01:24 AM   #5353
HEAVY METAL
Lucky Adventurer
HEAVY METAL's Avatar
Oddometer: 77
Front Wheel setting
Could someone please explain the method of changing front wheel size on my 640ADV.Thanks Brad
PS I mean speedo setting
Do it now,there maybe no tommorrow
1996 BMWR100GSPD Classic
1998 Harley Wide Glide
2003 Yamaha WR250F
2005 KTM 640ADV
2007 KTM525EXC
HEAVY METAL screwed with this post 06-08-2010 at 01:48 AM Reason: more info needed
HEAVY METAL is offline   Reply With Quote
Old 06-08-2010, 05:16 AM   #5354
GSteve
GSteve's Avatar
Oddometer: 1,275
Said Arch:
Hmmm, so it's not adjustable on the '02s? Well that's a drag, Tim.
Yes it is adjustable on the 02, I missed in in the manual too because the wording is a bit misleading (no I'm not that thick). RTFM closely. (read the f'ing manual)
you hold both buttons down together with the ignition on for about 5 secs til the display starts flashing then press the mode & other button to change. I thought the bike felt slower than indicated and when I went on a GPS ride it proved it. The GPS and other enduro computers verified it was right on with the stock tires and set to 19". A taller knobby may need to be changed back to 21" or it may be too slow. But, at least the mileage on the odometer will be 7% less too ! I used to brag I had a 180kph offroad bike, now i can only say its 170kph, but its accurate !
Steve
Little Rock, AR
GSteve is offline   Reply With Quote
Old 06-08-2010, 04:02 PM   #5355
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,560
I can't help with the carb, sorry.
Not sure if this is the same for your early model, but the newer ones have two inboard-facing mini thumb-wheel taps which are joined directly by a length of hose. These taps are always open except when removing the tank from the bike. Then on the left-lower lobe is a normal on-off-reserve tap, with one output which goes to the fuel pump input.
Looking at the part 'fiche wrk2surf quoted here, it looks like the two inboard taps (#3, only one shown?) are connected to the fuel pump input via a T and fuel filter (#19), and if you have a fourth connection on the fuel pump, then maybe that connects to the main fuel tap #46. A much more complicated arrangement than they use now.
But I'm just guessing here...
The fuel pump is vacuum operated, fed from the inlet manifold. That is likely the narrow hose marked "?" in your pic.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is online now   Reply With Quote
Times are GMT -7.   It's 04:10 AM.
