Old 07-27-2010, 08:46 PM   #5461
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,935
You can post a request on KTMTalk.
Or you can build it yourself with instructions from here. Good Luck.
Originally Posted by mxchamp
Well if you haven't heard my bearing took a dump on me.
The bike still runs but sounds terrible.
I need your help. I can do the job myself no problem, but I need that bearing puller.
I know somebody somewhere has one floating around. Help a newbie out and help me save some money.
$1200 dollar quote from the dealer to do the job. I have located a Facom puller but it's $341 US dollar. I will gladly give a $50 to the owner of one of those pullers!
TIA
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 07-27-2010, 11:06 PM   #5462
G I Mavro
Orange monster
G I Mavro's Avatar
Oddometer: 25
6fotty knock
I had Adamska serviced just thisFriday past & it had a noisy top, Resert told me it was the cam follower, but after inspection the dealer found that the tappits were out badly, they set them & the noise was gone, serviced & all was well. Yesterday, Tuesday afternoon i had the most horrible knocking in the tops of the engine & i called the dealer to pick him up today. Guess i'll have to go & see my bank manager!!!
If you're not bleeding, you ain't doing it right!!!
G I Mavro is offline   Reply With Quote
Old 07-27-2010, 11:18 PM   #5463
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,113
A symptom of a failed cam follower bearing is excessive valve clearance...
As part of normal operation when the valves wear the clearances tighten and the valves actually get quieter.... Clearances that open up should ring alarm bells as to something is not right...
When the follower roller wears or loses it's needles the valve clearances open up and the tappets will get noisy as a result of the roller slop... If this is not corrected in a timely fashion the dollars can add up quick... Your dealer maybe should of picked up on this...
gunnerbuck is offline   Reply With Quote
Old 07-28-2010, 06:42 AM   #5464
G I Mavro
Orange monster
G I Mavro's Avatar
Oddometer: 25
Cry 6fotty knock
Thanks gunner. I'll be sure to ask the dealer. They will pick him up today still & strip & let me know, sad story man. I love that bike! I stripped the seat & tank last night & then started Adamska & could clearly hear the noise ( Klanking ), in the top of the cylinder, above the water pump, so i am confident that it has nothing to do with the crank or something more expensive than that! When idling it sounds like there is a loose bolt or metal object of some size being picked up & tossed around and smacked into the sides of the inner casing walls, it's not in a rythmic fashion at all, it sounds every couple of seconds and not constantly, but continuously!
What does that sound like?
Old 07-28-2010, 08:20 AM   #5465
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Hey mavro! Is it not your decomp that is making that sound.. I might be wrong but if the bike is running low revs maybe it's that? Try adjusting the idle a little higher.. The cam might be worn a little.. Like the other guys have said the most obvious cause is the rocker arm rollers.. If your bike has done more that 20k it's worthwhile checking!
GreyDawggg is offline   Reply With Quote
Old 07-28-2010, 02:02 PM   #5466
pcvance
Walk Verplank
pcvance's Avatar
Oddometer: 5,542
Thumb KTM 640-E Siging in
I'm signing in my new to me (6mo.) 00' 640 w/18L tank, 11732 MI. on the clock,looks like it's never seen dirt, soon to be tested in the dirt @ WMRS ride this weekend. The bike runs and rides great, It was bone stock when I got it. I've done the carb mods found on this forum and changed the exhaust can to a KTM Supermoto unit. I changed the gearing from 17/42 to 15/42 and added higher and wider fat bars. White mountains here we come.
pcvance is offline   Reply With Quote
Old 07-29-2010, 04:56 AM   #5467
G I Mavro
Orange monster
G I Mavro's Avatar
Oddometer: 25
Pissed 6fotty knock
Just got the prognosis...
Adamska's rocker roller bearing is seized & the chances are i will have to have the cam replaced, or the rocker roller. So i am just waiting for a price then i'll know how much to lend from my bank!
Old 07-29-2010, 05:46 AM   #5468
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
Save yourself some money and order the parts from partshark.com and get the dealer to fit them. If parts prices in SA are like Australia, you will save yourself a fortune.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 07-29-2010, 06:12 AM   #5469
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
+1 very wise words of wisdom
Old 07-29-2010, 06:20 AM   #5470
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,832
munn racing are 15% off
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 07-29-2010, 07:02 AM   #5471
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,313
They wont ship overseas, only within the US (according to their website)
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 07-29-2010, 07:11 AM   #5472
veetwo _tls
RENOVATIO:
Oddometer: 1,832
i just got some quotes via a friend that buys all his KTM parts from munn. i was told chip will freight to australia (maybe that was for me i don't know)
i was just doing a price comparison munn are $3 above on partshark.com in the discount price.
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 07-29-2010 at 07:17 AM
Old 07-29-2010, 07:27 AM   #5473
G I Mavro
Orange monster
G I Mavro's Avatar
Oddometer: 25
6fotty knock
That's my big problem. Any Ktm part i want to order will go through Ktm SA which is who the dealer has to go through as well, so might as well let the deler get it for me, wanted to get myself but T.I.S, This is Africa people. Hahaha!
Luckily i am on a good foot with my dealer & negociate good prices for parts. Thanks anyway, would have been nice. Still waiting for the prices, will most probably have to call them tomorrow morning...
Old 07-29-2010, 07:39 AM   #5474
dnrobertson
Oddometer: 794
Don't understand how if you order the parts yourself from munn or partshark, KTM SA get involved, but it's your money.
Good prices in AUS means the dealer only sticks his finger up your ar#e and not his whole member.
David
2005 KTM 640A
2008 Wee-Strom
Old 07-29-2010, 11:33 PM   #5475
Coho911
Coho911's Avatar
Oddometer: 1,366
Why am I not going with you on those trips Brian. Damn - I have GOT to stop making work a priority - haha !
Originally Posted by B-Rod
Just a couple pictures from yesterday, on a 3 day ride in Montana. I can't believe that over the winter I was trying to sell this thing. A little more slab than I planned (about 800 kms of 1700 total), but it does it so easily, but boring nonetheless.
2007 KTM 640 Adventure 'Bricktop'
----> LC4 Info Thread <----
So many places to go and see, so little time...do it whenever you can, cause too late comes fast. - Coho
The internets BEST Site for Image Hosting ---> Smugmug <--- SAVE $ 5.00 on smugmug membership with this COUPON - hUuJ7EHBKXWDU
Coho911 is online now   Reply With Quote
Times are GMT -7.   It's 06:22 PM.
