Old 08-07-2010, 09:12 PM   #5521
motorjon68
motorjon68's Avatar
Oddometer: 430
Searched the Thread index and no luck. I put risers on under the bars. Now when I turn the bike full lock to the right, it stalls! No clue what is causing it. Any ideas? thx, Jon
Do you know what "nemesis" means? A righteous infliction of retribution manifested by an appropriate agent. Personified in this case by an 'orrible c*#t... me.--Brick Top, "Snatch"
motorjon68 is offline   Reply With Quote
Old 08-07-2010, 09:26 PM   #5522
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
manual decomp cable needs re-routing or like mine (needs lengthening)
i'm using a Scotts BRP top triple + a raiser added again
click on pic for BIG:
you can see the cable running through between the raiser atop of the top triple clamp. (mine is not connected as it needs approx 400mm lengthening)
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 08-07-2010 at 10:27 PM
veetwo _tls is offline   Reply With Quote
Old 08-07-2010, 10:37 PM   #5523
sjeproductions
sjeproductions's Avatar
Oddometer: 271
Originally Posted by kdennan
What tires are those?
Have you had them off road yet?
What do you think?
I also noticed that the plastic cover is off to expose the upgraded air filter side cover.
I have that part but the plastic is on top of it. I got the bike that way. Am I supposed to lose the outer plastic cover?
Thanky
Those were TKC80s, but they are on their last leg.
I am running a Dunlop 908 in the rear now and a tkc80 up front. Think its a solid all around combo. Might swap the front to an MT21 if I head to baja, but otherwise like the setup. Granted I love the tkc80 front and rear, as a good reliable setup if you are mixing pavement and offroad. I've run them into copper canyon and they've always proven reliable and predictable. the 640 just seems to burn up the rear tire faster then my dakar did, so I went for the proven 908.
As for the airfilter question, not 100% sure of the answer. the bike came setup that way and at altitude, it seems to run fine so I am leaving it as is and checking the airfilter frequently for dust and dirt buildup.
sjeproductions is offline   Reply With Quote
Old 08-07-2010, 10:39 PM   #5524
sjeproductions
Oddometer: 271
Originally Posted by Coho911
You Need to make some "After" pics...
LOL, you read my mind!! Vacation starts next Friday and I've got a week plus to ride with buddies, so "after" is coming soon!!! Maps roll out tomorrow...now if only those damn crash guards would get here!!
Old 08-07-2010, 11:09 PM   #5525
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,520
A friend of mine has had great luck with the Dunlop 998's but I can wear out 4 sets of el cheapo Shinko's for the same price it would cost me for the 998's.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 08-07-2010, 11:40 PM   #5526
veetwo _tls
RENOVATIO:
Oddometer: 1,850
i got with the 640adv (yet to be fitted) a
120/100 x 18 bridgestone ED78 GRITTY
these any good
thinking of using the Motoz tractionator desert HT
i always used CHENCHIN C755's on my XR630 was getting 3,000K same as the dunlop 908.
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 08-08-2010 at 01:41 AM
Old 08-08-2010, 12:59 AM   #5527
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,880
Locally, the Dunlop 606 rear is a good bet, seems to work as an all-rounder and is reasonable on tarseal too, plus they are relatively cheap and come in 130 as well. 120 might be a bit narrow.
For fronts I've had a great run from a Michelin Starcross HP4, the grip is great both on and off road.
GodSilla is offline   Reply With Quote
Old 08-08-2010, 02:06 AM   #5528
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,397
Nope but interested in how you fair with the Tractionator and cheng shin.
I do agree with Godsilla, the d606 are a good allrounder, and last as long or sometimes longer than a lot of the more expensive tyres.
Aussie Steve is offline   Reply With Quote
Old 08-08-2010, 02:41 AM   #5529
veetwo _tls
RENOVATIO:
Oddometer: 1,850
i've only tested on the 92 XR600RN later 630 the chenchin C755 , Dunlop 908 , trellbourg teracross ?, OE irc that was with the bike new & a pirelli all wore around the 3K mark. the chenchin was the best for the $
once my 908RR is done on my 950SE i'll try the motoz Tractionator Desert HT (i can buy a front & rear + delivered for the $$$ of a D908RR) & are easier to obtain than the Dunlop 908RR if they are as good as i have read from others using them i'll stay with them for both bikes.
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 08-08-2010 at 02:48 AM
Old 08-08-2010, 03:47 AM   #5530
Aussie Steve
Oddometer: 1,397
Thanks for that.
Old 08-08-2010, 04:00 AM   #5531
veetwo _tls
RENOVATIO:
Oddometer: 1,850
can anyone make heads or tails whats been done here & removed ?
so far i've tagged the dash , tach , horn & indicator wires.
click on pics
Key > orange > fused > relah > spliced into blue (LO ?)
relah > red wire cut/disconnected with a splicer ?
these plugs for what ? (from L to R)
4 pin tach
2 pin ? - Y/Bstripe & Br
4 pin ? Y/Bstripe - Br - Gr/R - Y with blk sheaving
& above 2 pin ? Y&Bstripe/Br
dash/speedo etc
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 08-08-2010 at 07:04 PM
Old 08-08-2010, 06:42 AM   #5532
Coho911
Coho911's Avatar
Oddometer: 1,369
Are you going to the KTM Rider Rally 2010 ? (October 15-17th in Moab, KTM owners only for $125.00)
2007 KTM 640 Adventure 'Bricktop'
----> LC4 Info Thread <----
So many places to go and see, so little time...do it whenever you can, cause too late comes fast. - Coho
The internets BEST Site for Image Hosting ---> Smugmug <--- SAVE $ 5.00 on smugmug membership with this COUPON - hUuJ7EHBKXWDU
Coho911 is offline   Reply With Quote
Old 08-08-2010, 08:17 AM   #5533
sjeproductions
Oddometer: 271
Until your email, I didn't know about this event. Granted until two weeks ago I was a BMW owner and would have been flogged at a KTM event.
Just talking to two buddies of mine last night, also KTM owners, about a fall trip to Moab. This could be fun. I'll check it out and thanks for the 411...
Old 08-08-2010, 08:30 AM   #5534
bikepikespeak.com
bikepikespeak.com's Avatar
Oddometer: 598
I'm in process of trying to get a hall pass to go out there myself. We'll have to stay in touch. I see you're from Boulder...
bikepikespeak.com is offline   Reply With Quote
Old 08-08-2010, 09:04 AM   #5535
sjeproductions
Oddometer: 271
Sounds like a plan. We've got a good posse of KTM riders up in the Boulder bubble and I think they'd be down for this event.
Times are GMT -7.   It's 04:01 PM.
