Old 08-08-2010, 10:32 AM   #5536
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,352
2- 03 640s
640 Adventure with 121,000 KM logged, 640 LC 4 - 34,000 KM logged
gunnerbuck is offline   Reply With Quote
Old 08-08-2010, 10:52 AM   #5537
Gerst
Gerst's Avatar
Oddometer: 253
Damn, that's some riding gunnerbuck! Just curious if you've had to do any engine work?
Gerst is offline   Reply With Quote
Old 08-08-2010, 06:12 PM   #5538
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,352
On the Adventure a complete top end rebuild at 40,000... Valve jobs at 40,000, 80,000 and another slated for this winter along with a piston ring refresh.... I bought the bike new in 04 so that gives me a 20,000 KM per year average...
The 640 E was purchased recently by a friend... He's the third owner...
Old 08-08-2010, 08:59 PM   #5539
Coho911
Coho911's Avatar
Oddometer: 1,370
THAT is SERIOUSLY Wicked !
I have a new rolemodel ! I shall call him - ' GUNNERBUCK ! '
Now I want to go ride my 640 till 100,000 miles !
2007 KTM 640 Adventure 'Bricktop'
----> LC4 Info Thread <----
So many places to go and see, so little time...do it whenever you can, cause too late comes fast. - Coho
The internets BEST Site for Image Hosting ---> Smugmug <--- SAVE $ 5.00 on smugmug membership with this COUPON - hUuJ7EHBKXWDU
Coho911 is offline   Reply With Quote
Old 08-09-2010, 02:22 AM   #5540
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
2- 03 640s
That is great work Gunnerbuck!! That's the most kms I've read of and the bike looks beautiful..
How were your valves at 40k? Some replace them, mine were ok so I'm going to save and get a valve when I can over time and replace them at 50k.. That is if I get it running soon anyway.
Another question if I may, have you replaced your cam chain and if so at how many kms?
Cheers!
GreyDawggg is offline   Reply With Quote
Old 08-09-2010, 04:21 AM   #5541
makazica
makazica's Avatar
Oddometer: 754
Bullsh*t............
He attaches a drill to the front wheel and lets it spin for days to get that kind of mileage....
Good stuff gunner!!
M.
makazica is offline   Reply With Quote
Old 08-09-2010, 07:15 AM   #5542
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,352
Cam chain is the original and will be replaced along with the camshaft during my winter service.... My auto decomp cam is finally on its way out...
Valves at 40k km for the first service required 2 new intake valves + 2 new exhaust guides along with the seals and regrind...
At the second 80k km+ service it required complete replacement of all valves and guides + seals and regrind....
Old 08-09-2010, 08:03 AM   #5543
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Thanks! Mine had only 28k on it before rebuild but I only replaced what was damaged and the valves were fine(I hope).. I'll do them down the track.. Glad to hear your cam chain has lasted 120k wow.. Mechanics recommended I get a new cam chain but I couldn't see any signs of wear at all and from what I've read there haven't been many cases of them giving up.. So I might get my moneys worth out of it too..
Gunner do u think using 10w40 oil could have possibly been a cause of bearing failure? The wrong viscosity.. I didn't know about oils when I got my bike and took the wrong advice.. I do kno now that I will run the correct 10w50 fully synthetic stuff from now on.
Cheers
Old 08-09-2010, 04:48 PM   #5544
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,352
I ran Maxxima 5w/40 synthetic for the first 40,000 KM until the top end failure...
Since then I've been running Rotella 5w/40 synthetic and have been very happy with the results.... I noticed right off that the shifting was way smoother as was the engine... It's good stuff in my books, the next oil change will finish off my 2nd- 20 liter pail ...
Old 08-09-2010, 04:54 PM   #5545
Gerst
Gerst's Avatar
Oddometer: 253
Pegs?
Sorry if this is posted in the wrong thread.
Does anybody have info on WIDER (front to back) foot pegs for a 07 640a? There is some talk in the index but it's for earlier model bikes. I just spent two weeks covering 3008 miles, most of it on the pegs and my arches were protesting! I like the look of the Fastway F series but they don't list the 640 as a fit. Mainly looking for "bolt on" options as I'm lacking metal working tools.
Thanks for helping (again )
Gerst
Old 08-09-2010, 05:08 PM   #5546
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
Gerst
What boots are you wearing? You can get the weld on variety.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 08-09-2010, 06:06 PM   #5547
Gerst
Gerst's Avatar
Oddometer: 253
Thanks B-Rod,
I wear SIDI mx boots with Superfeet insoles. The insloes may be worn out but to find out I'd have to stick my hand in the boot, risky business! I'll check out the weld on widners, thanks. Just need to make sure that wider is front to back and not center line of bike and out. Wider or longer, always the question
Old 08-09-2010, 06:08 PM   #5548
camdenlake
Oddometer: 11
Originally Posted by veetwo _tls
can anyone make heads or tails whats been done here & removed ?
so far i've tagged the dash , tach , horn & indicator wires.
click on pics
Key > orange > fused > relah > spliced into blue (LO ?)
relah > red wire cut/disconnected with a splicer ?
these plugs for what ? (from L to R)
4 pin tach
2 pin ? - Y/Bstripe & Br
4 pin ? Y/Bstripe - Br - Gr/R - Y with blk sheaving
& above 2 pin ? Y&Bstripe/Br
dash/speedo etc
Man i thought mine was messed up when i got it. Its a lot of fun to untangle. I took it all out and started over. Its usally more to to repatch it all togehter. I got a set of good weather tight connectors and made new stuff. Still have some todo but it runs now :). I removed all sorts of stuff the did nothing and connections just looking to leave me on the trail.
A little time a VM and you should have it all set.
Josh
camdenlake is offline   Reply With Quote
Old 08-10-2010, 12:51 AM   #5549
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,853
Josh
thanks josh
by no means am i near educated like an auto sparky - just very basics
once i know what is for what then i'm ok
& the manual wiring diograme should be in colour/coded for people like me to follow
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls screwed with this post 08-10-2010 at 01:03 AM
veetwo _tls is offline   Reply With Quote
Old 08-10-2010, 12:54 AM   #5550
veetwo _tls
RENOVATIO:
Oddometer: 1,853
is this the HID kit that can be used on the 01/02 640 adv ?
XENON HID SINGLE BEAM type H1 H4 H7 6000K 50w 12v 55W
2 ballasts (50w)
2 HID XENON bulbs (50W single beam)
2 fixing pads
screws and wiring's
CHEERS: brett
MY07 950 SER
Times are GMT -7.   It's 03:49 PM.
