Old 09-06-2010, 09:41 PM   #5671
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Just read that thread thanks tseta.. Still don't understand half of it. I have a bst without the tps.. Am I going to screw my bike up or notice any dramatic differences??
GreyDawggg is offline   Reply With Quote
Old 09-07-2010, 01:11 AM   #5672
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,148
Originally Posted by GreyDawggg
Could someone tell me what this connection on the carb is:
My bike has the SAS removed but this is a photo I got off an inmates bst.. The bst I got hasn't got the black connection and plug on the carby???
cheers
That is the Throttle Position Sensor, yes it will run without it as many do, but it gives the ignition system a batch of info to help choose a timing position for the spark. Not sure if it is used for detuning the bike for smog. I ended up putting an '05 carb on my '99 specifically for the TPS, that way my aftermarket computer has better info to run it on!
Low594 is offline   Reply With Quote
Old 09-07-2010, 05:55 AM   #5673
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Cheers for the heads up Low!! My bike never had the tpc since I bought it so the new carby will have to go without it.. Hopefully my float is set right(tried to get it parallel) time will tell.. Other than having to wait a few more weeks for a choke/cold start piston because the carby that was "in perfect working condition) had it missing out the side. Should get the carby in and ride the bike this weekend finally.. Guess I shouldn't count my chickens before they hatch.
Old 09-09-2010, 02:57 AM   #5674
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,397
Fork guards again.
Have just put the long travel guts in my WP48 forks, the 85sx fork guards are now too short.
Anyone got any leads on a longer set of fork guards? I saw a post saying husqvarna ones were the go but cant find any more info?????
Aussie Steve is online now   Reply With Quote
Old 09-09-2010, 06:56 AM   #5675
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,849
Question Fcr Cable Routing ?
need a little help please.
i've installed my FCR carby on the 640ADV.
how did you guys that have the FCR route your cables. from the bars to the carb ?
looks like i'll have to shift my wiring to the left side of the bike also as it's very close to the cable attachment on the carb.
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 09-09-2010, 07:29 AM   #5676
LukasM
Oddometer: 5,418
I can't answer your question but I hope you don't mind if I tag along since it's on topic: What does it take to install a FCR from an EXC on a LC4? Do you just need different carb boots or is some special adapter required?
Cheers,
Lukas
Old 09-09-2010, 07:47 AM   #5677
Tseta
Lost
Tseta's Avatar
Oddometer: 672
I remember Creeper doing a thread about the FCR conversion. With a little searching, I found this. Sadly, it seems that the pictures are gone.
-T
Tseta is offline   Reply With Quote
Old 09-09-2010, 08:12 AM   #5678
veetwo _tls
RENOVATIO:
Oddometer: 1,849
-T
thanks for that answered my Q's & thoughts
CHEERS: brett
MY07 950 SER
Old 09-09-2010, 08:27 AM   #5679
LukasM
Oddometer: 5,418
Great link indeed, thanks Tseta!
Old 09-09-2010, 10:08 AM   #5680
legion
Pope's Nose
legion's Avatar
Oddometer: 12,782
-T
Sadly, it appears Creep is, too. Looks like he bailed a couple months ago. Left a msg on his profile that says 'gone, gone, gone...'
legion is offline   Reply With Quote
Old 09-09-2010, 10:24 AM   #5681
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Cheers,
Lukas
It seems that maybe someone should step up and write it again. It would be useful information to those that may be considering doing it. If it isn't too much trouble, I'd be curious to install an FCR.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 09-09-2010, 10:56 AM   #5682
LukasM
Oddometer: 5,418
Are you volunteering?
Sounds like the SXC cables and air boots are important for a good fit, and maybe having the later header to clear the AP pump - though I'm not sure if that's only true for the newest 07/08+ carbs (which are easily recognized because they have a non-removable intake bell).
Old 09-09-2010, 11:14 AM   #5683
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Pffft! Me? Not at this time. I've saving my pennies for a second orange bike. We'll see how that goes, but who knows. I depends how long the winter is Why don't you do it? You probably have ten FCR's just kickin' around in your spare parts. . . . or you could send me one. That would motivate me.
Old 09-09-2010, 11:43 AM   #5684
wallache
wallache's Avatar
Oddometer: 378
I put a FCR39 from an '08 450 EXC on my '02 640a. Stock cables wouldn't fit, so used SXC cables. Stock intake boots fit better than the SXC ones I ordered. The exhaust header had to changed out to '03+ to clear the AP. Pretty easy, but the complete header was pricy.
wallache is offline   Reply With Quote
Old 09-12-2010, 03:34 PM   #5685
mcgovski
mcgovski's Avatar
Oddometer: 82
clutch cover
I am looking for a clutch cover for a 2002 640 adventure if anyone has one they want to get rid of........
thanks
mcgovski is offline   Reply With Quote
Times are GMT -7.   It's 02:46 AM.
