Old 09-22-2010, 06:19 AM   #5731
sillymike
Yep! That's me...
sillymike's Avatar
Oddometer: 159
Another 640ADV rider from North of the border
Quick question about wheels...
- Anybody knows which other KTM model/year would fit on a 640 2003?
sillymike is offline   Reply With Quote
Old 09-22-2010, 06:11 PM   #5732
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Hi Mike,
Good question as the stock 03 wheel that was supplied with the bike was a subject of recall... You get a recall letter in the mail, take the bike into a dealer and they replace the stock DID with a new excel rim,hub and spokes...
I'm thinking the wheel used for recall replacement by KTM was the same part used on the 03 450/525 EXC's as it takes the same bearings #6906dducm...
gunnerbuck is online now   Reply With Quote
Old 09-22-2010, 08:09 PM   #5733
vegastele
vegastele's Avatar
Oddometer: 402
Originally Posted by skibum69
terrible photo, but I just mounted one on my '06
I see you did the triple clamp too. Scotts says it don't work on the pre 05.
vegastele is offline   Reply With Quote
Old 09-22-2010, 08:14 PM   #5734
vegastele
vegastele's Avatar
Oddometer: 402
Originally Posted by 9Toes
Try Colin STENHOUSE(Racing) just got under mount for 03 adv easy fit, post was welder for over mount and appears still to have right angle, just needed cutting down.
Thanks. I will be calling them about this thing soon.
Old 09-25-2010, 10:45 PM   #5735
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,923
Originally Posted by dnrobertson
Thanks mate, much appreciated.
GodSilla is offline   Reply With Quote
Old 09-25-2010, 10:50 PM   #5736
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
2001
click on pic for BIG:
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 09-26-2010, 08:44 AM   #5737
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Originally Posted by veetwo _tls
2001
Looks good with the orange and blue ASI hoses! I almost went with colored hoses myself, but decided black was best for me since I don't have a good way to keep mine too clean!
Low594 is offline   Reply With Quote
Old 09-26-2010, 09:37 AM   #5738
makazica
makazica's Avatar
Oddometer: 752
2001
I want more pics of this bike from all angles.....
Good job!
M.
makazica is offline   Reply With Quote
Old 09-26-2010, 03:16 PM   #5739
overlandr
Dystopist
Oddometer: 5,908
M.
Not that bike but what about this one - one of Franki's (see his RR) buddies in China had a mishap... Arrrgh!
Edit: Beware; this is another case of the dreaded sheared subframe bolts.
overlandr screwed with this post 09-27-2010 at 06:14 AM
overlandr is offline   Reply With Quote
Old 09-26-2010, 04:02 PM   #5740
veetwo _tls
RENOVATIO:
Oddometer: 1,850
Good job!
M.
all in this post:
http://www.advrider.com/forums/showthread.php?t=615045
CHEERS: brett
MY07 950 SER
Old 09-27-2010, 05:21 AM   #5741
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
After getting the bike to run great and doing 100km, I dumping the oil just to check on the mag plugs for any signs. No metal, great!
The bike gets a little warmer when I'm going slowly. Before it never went to 5 bars or maybe a handful of times in the toughest soft sand conditions at 40 c. the fan comes on and it cools down again so it should be fine. I think their might be just a little too much coolant because some coolant has leaked from the overflow. Other than that the bike feels great to ride, It feels like it is alot smoother and less vibration with the wossner piston.
Then my awesome luck come back to bite me in the ass!!!! 120 km away from home in the middle of the bush my clutch lever snaps where it holds the piston in
What are the odds??
I didn't have any epoxy or any metal glue. Stuck in the middle of the bloody aussie bush... I had one mission getting home!! It was fine more or less when I was on offroad tracks but when I came close to the city I had to try and time traffic lights so they were green but ended up popping it into neutral before it stalled, pushing the bike across the lights each time and then push hard and pop it into first. Probably the toughest day of riding in my life. I got home having lost 10kg, water finished and shin splints from pushing the fat bastard so much.
I don't know anybody with a ute and being a public holiday didn't help my cause. Not good for my first bush bash in 7 months.
GreyDawggg is offline   Reply With Quote
Old 09-27-2010, 05:35 AM   #5742
Darryl625
Darryl625's Avatar
Oddometer: 53
Good to see the bike is going fine and that every thing went well in the end with the rebuild. Don't let a broken leaver get you down I've had to get home with worse problems. Other than that looks like you had a goog ride. Just going over my bike and getting ready for a ride next weekend thinking of heading down to Stirking NP for a look around.
Darryl625 is offline   Reply With Quote
Old 09-27-2010, 05:53 AM   #5743
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 526
Could you not use the front brake lever on the clutch side in an emergency?? or will they not interchange if flipped over?
NitroAcres is offline   Reply With Quote
Old 09-27-2010, 05:55 AM   #5744
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Cheers Darryl
Where is that? I also wanted to go on a trip next week sometime but looking at a 3 nighter or maybeeee 4.. Where is Stirking NP? Stirling ranges? I want to see the area around and east of albany.
Old 09-27-2010, 06:03 AM   #5745
Tseta
Lost
Tseta's Avatar
Oddometer: 674
Fall colors...
Grey, green, yellow and a FLASH of ORANGE!
(From a recent excursion to Russia...)
Cheers,
Tseta
Tseta is offline   Reply With Quote
Times are GMT -7.   It's 08:21 PM.
