Old 10-19-2010, 04:36 AM   #5821
Adrian V
Oddometer: 515
Fan not working - earth fault?
After bashing through some sand the other day I noticed the temp had got up to 5 bars and the fan hadn't come on (it normally would). On the way home I noticed the brake/back light didn't work. - bear with me here.... Checked the wiring diagram and they are both on fuse circuit 4, but the horn + flashers which are also on circuit 4 still worked mmmm. Checked the fan - working when shorted to earth so power is getting to the fan. Power getting to the brake light switch as well.
Theory 1 - The earth return from the temperature switch is common with the rear light/brake earth and it's broken/corroded somewhere? The brown earth wire from the temp switch disappears into the loom and may come out near the ECU. The rear light switch seems to go into the same area.
Theory 2 - Temperature switch not working and its just a coincidence that the rear brake/light doesn't work as well. Both seemed to happen around the same time though?
Ran out of light before I could delve any deeper, but anyone know where the earth return wires go near the ECU/battery? Any other thoughts?
Thanks,
Adrian
Adrian V screwed with this post 10-19-2010 at 04:42 AM
Adrian V is offline   Reply With Quote
Old 10-21-2010, 08:32 AM   #5822
Aybars
Oddometer: 26
Hi Guys,
Due to low income levels of our country; I've reached my first KTM at my 32 this year; riding a 640 Adventure R - 2000.
It has a rebuilded engine on 15.500Kms. Previous owners were really "sick" guys who cared the bike like puppy :)
09092010088
Aybars is offline   Reply With Quote
Old 10-21-2010, 12:45 PM   #5823
veetwo _tls
RENOVATIO:
veetwo _tls's Avatar
Oddometer: 1,850
Originally Posted by Aybars
Hi Guys,
09092010088
anyone know were to get these high windshilds
Sent from my HTC ONE X - Using Rooted S-OFF , Open Home 6 & Buuf icon pack
http://forum.xda-developers.com/ BUILD YOUR OWN PHONE
CHEERS: brett
MY07 950 SER
veetwo _tls is offline   Reply With Quote
Old 10-21-2010, 01:45 PM   #5824
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
The taller windshield is found on the older Adventures, I think they changed the nose to a one piece in 2003? Not sure if you can use the older nose on the younger tank. One of our fellow inmate had a 1 piece nose made up with the older style screen/lip. I have no ides why they changed it, seems most of us prefer the taller version. Its good for daily use and dirt days. Personally, I'd like to see one a little taller and a bunch wider for those 300+ mile days!
Low594 is offline   Reply With Quote
Old 10-21-2010, 01:57 PM   #5825
veetwo _tls
RENOVATIO:
Oddometer: 1,850
just wondering if it would sit over the 2001 one piece screen.
CHEERS: brett
MY07 950 SER
Old 10-21-2010, 02:10 PM   #5826
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
I do remember seeing a bike on here that appeared that they did exactly that! It looked pretty good,too!
Old 10-21-2010, 02:28 PM   #5827
veetwo _tls
RENOVATIO:
Oddometer: 1,850
found the parts $Usd
#58211002000 WIND SIGN TINTED ADVENTURE '97 $168.79
#58208003000 WASHER BLACK FOR WIND SIGN $1.74
#0966050208 O.H.SCREW DIN0966-M 5X20 BLACK $1.47
#0125050003 WASHER DIN0125-A 5,3 $0.34
#0985050003 SELF LOCKING NUT DIN0985-M 5 $0.61
CHEERS: brett
MY07 950 SER
Old 10-21-2010, 02:43 PM   #5828
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,319
i tried to put the taller screen on mine when i had an adv,,, id dint look right just laid over the stock one piece upper, i think the oly way to make it right is to cut the one piece style screen to bolt on the earlier style properly.
2 SPOT is offline   Reply With Quote
Old 10-21-2010, 03:01 PM   #5829
veetwo _tls
RENOVATIO:
Oddometer: 1,850
sounds like it might be easier to just buy a rallye full piece.
CHEERS: brett
MY07 950 SER
Old 10-21-2010, 03:07 PM   #5830
2 SPOT
wannabe
2 SPOT's Avatar
Oddometer: 3,319
there were two parts of the early screen that didnt work with the later style for just being laid over it and bolted on,,, the mounting "lip" at the bottom flared out in a way that just didnt jive and the "bubble" thats in the screen made it sit away from the later style one piece. i think if you cut the lip off the early screen it would be a much smoother look, but you still have the bubble. i have seen a screen that looks like a stock replacement for the early one but smooth with out the bubble,,, thats prolly the one to get.
Old 10-21-2010, 03:11 PM   #5831
veetwo _tls
RENOVATIO:
Oddometer: 1,850
i think it looks ok i'll have mine painted to match the rest of the body work though.
CHEERS: brett
MY07 950 SER
Old 10-21-2010, 03:16 PM   #5832
veetwo _tls
RENOVATIO:
Oddometer: 1,850
anyone know were i can find it
i'd say it's the one above by the look of it.
CHEERS: brett
MY07 950 SER
Old 10-22-2010, 02:41 AM   #5833
Adrian V
Oddometer: 515
Veetwo - check out the screen Danno has on his 640. There are pictures of it in this thread: http://www.advrider.com/forums/showthread.php?t=626560
Ta,
Adrian
Old 10-22-2010, 03:07 AM   #5834
veetwo _tls
RENOVATIO:
Oddometer: 1,850
Ta,
Adrian
thanks for that cheers
CHEERS: brett
MY07 950 SER
Old 10-23-2010, 09:00 AM   #5835
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
V2,
have you looked at the LaminarLip? It says it fits all years, but looks like it will only fit the later style, its held on my highspeed velcro, so it would work as a tour screen. I might have to get one for myself!
Times are GMT -7.   It's 02:19 AM.
