Old 11-09-2010, 08:43 AM   #5911
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,344
Originally Posted by B-Rod
They are the same except for colour. Yours looks so much better with that on. I've never like the proboscis that came on the silver bikes. . . . sorry Gunnerbuck.
I may do a bit of an appearance shake up on my bike before I'm finished with it...I have a six days version of the proboscis fender to try... It's colored gloss black with a green metallic sheen... I also have a spare tank from an 07 that may see a gloss black paint scheme...
gunnerbuck is online now   Reply With Quote
Old 11-09-2010, 09:35 AM   #5912
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,999
I actually like the silver/ black bikes the best, this one is pretty cool too. A little heavy with the white, but inspiration nevertheless.
Loadedagain's old 640. Yummy
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 11-09-2010, 09:48 AM   #5913
greasyboy
cur·mudg·eon
greasyboy's Avatar
Oddometer: 1,767
[quote=B-Rod]I see you have an '06. I found a picture of your bike, and sure enough, someone has removed one rotor. '04-'07 640's came with dual discs, but many feel it is too much brake, and too much weight, so they lose one. Single disc is fine, provided the process involved swapping the master with one from a 950 SE (also single disc) or and EXC. If it works good, I wouldn't worry about it.
I'm not real happy with how it works on the road. Its fine in the woods. I need to replace the front rim, and the rotor is warped. That could be some of the problem. Money is super tight at the moment, so, i am hoping to replace all that in the spring, thanks!!
greasyboy is offline   Reply With Quote
Old 11-09-2010, 11:28 AM   #5914
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
I haven't been farther that the car wash with it. It's -4º C, so today isn't looking good either. I imagine it will be good, due to it's shape and the flutes in the back. It's pretty stiff too.
I have the prior model of your high fender installed in my '06. I think they are similarly stiff enough.
I have rode @ 175Km/h (aprox 109mi/h?), no wind, no cases, no high windshield, flat route, and nothing remembered me i had the high fender on. I write this just to give an extreme example, but I never drive at that speed, and I think you don't either .
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 11-09-2010, 11:58 AM   #5915
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,591
no issues with the high fender on the highway for me, except feeling it catch a little in sidewind gusts of over 50 km/h. I threw down the dosh for the Touratech setup to keep the dual disk which I like too.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 11-10-2010, 04:54 AM   #5916
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
A quick question if anyone might have had the same problem, I have oil seeping from the top of my forks. Not from the vent screw o-ring but I think maybe from a o-ring in the rebound adjuster. In the parts manual I don't see an o-ring associated with the rebound knob although it lists one near it #7 in the parts under fork legs. Anyone had this before?
Sorry about the poor picture but whiich o-ring might be the culprit, #7 maybe?
GreyDawggg is offline   Reply With Quote
Old 11-10-2010, 08:00 AM   #5917
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,344
O-rings are cheap, I would replace #7 and #10 in both legs...
Old 11-10-2010, 06:27 PM   #5918
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
Have you done it before Gunner? I was reading Meat's thread on fork maintenance and he said that if you get oil in the wrong place where the rod is(the one that can rust and get stuck) then it will cause oil to leak from the rebound.
Should I just pull my forks off and unscrew the top cap or do I have to disassemble the forks.. The forks got some new fork oil and fork seals recently so I don't want to have to drain oil etc again.
Cheers
Old 11-10-2010, 07:01 PM   #5919
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,344
Cheers
If your forks have been serviced recently then you could just remove the caps and not drain the oil.... You will need a skinny wrench to slip in between the spring and the cap to hold it while you unscrew the cap...
If when your forks were serviced a little oil went into the adjustment tube it will weep out through the cap dial for a little while and then stop...
Old 11-10-2010, 09:21 PM   #5920
GreyDawggg
Adventure seeker
GreyDawggg's Avatar
Oddometer: 464
I thought that might be what was happening but it keeps weeping, especially after tough going. The top of the forks will have oil all over them. The right fork more than the left. It doesn't seem to be seeping any less for nearly 2k km now, so I might just do them this wknd when I service my bike. They've probably lost quite bit of oil.. Bike has been great other than that.
Old 11-18-2010, 05:24 PM   #5921
VxZeroKnots
VxZeroKnots's Avatar
Oddometer: 2,921
Been part of the club for about a week, so far this is the most fun all around motorcycle I've ever ridden. I absolutely love the LC4. Is it wrong to want an enduro and supermotard one too?
I say we take off and nuke the entire site from orbit. It's the only way to be sure
No bike does everything perfectly. In fact, no bike does anything until someone gets on it to ride.
VxZeroKnots is offline   Reply With Quote
Old 11-18-2010, 05:50 PM   #5922
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,160
Welcome to the support group! Who wouldn't want more than one variation!
Low594 is offline   Reply With Quote
Old 11-18-2010, 06:18 PM   #5923
NDTransplant
Oddometer: 420
Been thinking that same thing....
2015 BMW 800 GSA
NDTransplant is offline   Reply With Quote
Old 11-19-2010, 12:17 AM   #5924
Ben99r1
Ben99r1's Avatar
Oddometer: 3,090
Did you get that 99 from So cal? I think I seen it for sale about 4 months ago. I like both your bikes good job on the paint choices. Ben
Ben99r1 is offline   Reply With Quote
Old 11-19-2010, 08:44 AM   #5925
Gerst
Gerst's Avatar
Oddometer: 253
Ortlieb saddle bags
I'm looking for pics of 640a's with Ortlieb saddle bags mounted. Just curious how you mounted yours. Are you using a frame? If not how secure are they? If you're using a frame which one? Do you like it? What would you improve?
I bought a second hand pair to replace my Dirt Bagz and will spend some time this winter fiddling with the fit.
Thanks and Happy Thanksgiving!
Gerst
Gerst is offline   Reply With Quote
Times are GMT -7.   It's 11:34 PM.
