Old 05-17-2011, 10:41 PM   #6301
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
Originally Posted by Dee Cee View Post
Hi all,
I have a 2003 640 adv and it is getting harder to start. It has always been hard to start with the button and pretty good with the leg. It seems as though the auto deco is not working as it should. The motor seems to regulaly get stuck on the comp stroke. I usually use the hand deco on the bars to get reliable results but this is not always good enough. I have been thru about three good batteries in four years and am now running an even larger than std battery ( bit of a squeeze ). Is the auto deco prone to wear in these things and if so, are they repairable, or do I have to replace the whole camshaft to get the needed part. I was checking out the thread about the starter clutch spring and that sounds like it would be a good fix as well.
All advice greatly appreciated.
Are the valve clearances correct?
I actually had the same problem happen over a rather short time period. It ended up being the larger cam bearing failing, which caused the valves to not open enough/for long enough.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Old 05-18-2011, 03:31 AM   #6302
edztra
edztra's Avatar
Oddometer: 19
Crash
my bike died a couple of weeks ago when I crashed into a u-turning car. Repair will cost more than the value of the bike. On the picture the bike doesn't look to bad, but after close inspection there was quite some damage to the front. Looking for a new bike :(
http://edztra.com/?p=939
edztra is offline   Reply With Quote
Old 05-18-2011, 04:40 AM   #6303
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,520
Ouch! Are you ok? As for value as stated by insurance companies-doesn't mean it's not worth fixing for the right person
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 05-18-2011, 04:51 AM   #6304
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
I hope you are OK and not hurt. I wish you all well.
about the bike, may I ask what is the damage? is the frame bent? or just the front fork.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
erdsh is offline   Reply With Quote
Old 05-18-2011, 05:25 AM   #6305
LukasM
Oddometer: 5,425
I would definitely buy that bike back if the price is right, if you can live with a few scratches that looks like absolutely minimal damage. Even if the forks, triples and front rim are a bit bent they can be straightened or replaced for a few hundred € with parts from Ebay.
Old 05-18-2011, 05:52 AM   #6306
Dee Cee
Dee Cee's Avatar
Oddometer: 212
2003 640 adv Starting problems
Thanks for all the response.
I have done the cam follower bearings and I keep my tappetts pretty accurate.
I will pull out the starter clutch and have a look but the symptoms are as if my battery is weak so I think that the cam/deco is the culprit.
I have an engineering shop at my disposal so I will let you all know if I can successfully repair the problem. Apart from a waterpump seal and general wear and tear this bike has preformed admirably for 62,000 klicks.
Dee Cee
richard.campbell4@bigpond.com
Dee Cee is offline   Reply With Quote
Old 05-18-2011, 12:08 PM   #6307
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
KTM 640 ADV Fuel Pump
Hello,
attached are a few pictures of the fuel pump replacement.
the new fuel pump has a different set of holes, therefore I had to create a new piece with new set of holes to attach it to the original location.
I also took this opportunity to clean and balance the carb.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
Old 05-18-2011, 01:53 PM   #6308
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,839
just wondering.. do you guys have water, hoses and soap where you live?
wrk2surf is offline   Reply With Quote
Old 05-18-2011, 02:22 PM   #6309
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,972
I was wondering the same thing. I wouldn't do any work on that filthy bike and especially remove the carb. Good time to check the valves or reseal the rocker box while you're at it.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 05-18-2011, 09:24 PM   #6310
Brokein2
Oddometer: 215
My mind isn't even that dirty...
Brokein2 is offline   Reply With Quote
Old 05-18-2011, 10:52 PM   #6311
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
I admit the bike is dirty... :(
I use the bike as commuter and I go to work through the fields, which are watered therefore very mudy.
I live in a small town and work in the big city, on my way to the highway I go through the fields.
http://www.youtube.com/watch?v=0RHL2a46sOE
the bike is full of mud on daily basis.
and on the weekends I go riding with friends, so I admit, the bike does not get cleaned on regular basis...
I know, I should do better then that...
But hi, I ride the bike instead of clean it all the time... :)
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
Old 05-18-2011, 11:10 PM   #6312
makazica
makazica's Avatar
Oddometer: 749
Ignore the girlish observations about cleaning the bike.........
Yeah, you should'a washed it before wrenching but that's the way a properly used Adv should look like!
M.
makazica is offline   Reply With Quote
Old 05-19-2011, 02:50 AM   #6313
johnno950
Oddometer: 1,076
Cleaning bikes....new ones dont need it....old ones dont deserve it
johnno950 is offline   Reply With Quote
Old 05-19-2011, 06:19 AM   #6314
Laphroaig
Oddometer: 38
Put some new decals on the fender.
L
Weegie - A slightly derogatory term applied to people from Glasgow by the occupants of the other, more insignificant area's of Scotland.
Laphroaig is offline   Reply With Quote
Old 05-19-2011, 07:47 AM   #6315
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
Originally Posted by johnno950 View Post
is this the `99 660?
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
Times are GMT -7.   It's 03:37 AM.
