Old 05-30-2011, 03:31 AM   #6346
buckingfastered
buckingfastered
Oddometer: 8
i
buckingfastered is offline   Reply With Quote
Old 05-30-2011, 05:03 AM   #6347
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
that machine looks great in white
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 05-30-2011, 05:41 AM   #6348
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Old timers would call that "Creeperesque"...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 05-30-2011, 05:48 AM   #6349
MCLARDIE
Oddometer: 58
Laugh
Originally Posted by buckingfastered View Post
i
Yeh that's nice looking bike love the talon hubs and excel rims
MCLARDIE is offline   Reply With Quote
Old 05-30-2011, 06:58 AM   #6350
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,447
well, the time has come to give the old girl some new pep. met my engine builder in yuma the other day and passed her off.
the plan is...
1) lightened, balanced crank w/ carrillo rod and angular contact main bearings (stock 78mm stroke)
2) balanced counter-balancer
3) cylinder wall re-hone (hopefully stay at stock, if not bore to 102)
4) new piston rings
5) port and polished head
6) new over-sized kibblewhite valves (see how big of valves will fit)
7) custom cam
8) all new seals and bearings, rebuilt h2o pump
9) bore carb to at least 41mm (hopefully 43mm) w/ modifications
10) new over-sized aluminum radiators w/ ASI hoses
hoping that the bike will be stronger, more durable, and run much smoother than before. lightening and balancing the crank will be the big part. hopefully loose a couple lbs. of rotating mass which will have a profound affect upon the handling and characteristics of the engine.
not sure what the final price tag is gonna be, but it's not gonna be cheap. with that said though, it will still be cheaper in the long run than buying a new bike and outfitting it, and bringing it up to this level. plus, i've always wanted a rally engine.....
Cut7 is doing all the work and so far i haven't been able to find anyone who has anything bad to say about the guy other than he can be a little slow. that i don't mind, it means he's taking his time and doing it right. he claims that i should easily see the same numbers, or better, than his built 613 RFS and the engine should be under less stress. he claims his bike ran 31 ft/lbs at 3000 RPM, 54 ft/lbs at 6200 RPM, and 73HP at the rear wheel at 8800 RPM. sounds good to me...!
hopefully i will have the engine back within a few weeks. once its back in and ready to run i will post the final numbers.
laters,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 05-30-2011, 08:38 AM   #6351
G-Funk
That ... Umm ..... "Dude"
G-Funk's Avatar
Oddometer: 5,259
i
Awesome looking .......
G.
03 Caponord
"The Funness out-weighs the Dumbness ....." - Mr. Jetmoto
G-Funk is offline   Reply With Quote
Old 05-30-2011, 12:50 PM   #6352
makazica
makazica's Avatar
Oddometer: 754
the plan is...
4) new piston rings
7) custom cam
laters,
laramie
This here is pure bragging. Not appreciated. We need pics. And graphs. And more pics. And some more specs would do. M.
makazica is offline   Reply With Quote
Old 05-30-2011, 07:23 PM   #6353
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,596
laters,
laramie
looking forward to hearing how it turns out and the $$ figure at the end
Beerthief
Old 05-30-2011, 08:11 PM   #6354
Gerst
Gerst's Avatar
Oddometer: 253
Back in the saddle
A broken wrist has kept me off the bike since July, yep July, well the "spring" weather hasn't helped either. So Saturday I went for a spin to find a lake and test some of the upgrades I installed this winter.
All water flows downhill (downvalley)
I thought I'd crest the hill and see water! Nope, not yet. (I swear I was not moving when I took the pic).
Ah ha, water!
That's better. Still not what I'd call a lake, the search continues (when I have more daylight).
Always a welcome sight
This is both headlights on
This is both headlights and two Trail Tech SCMR16 HID flood lights on (with clear covers) Much better!
The next morning I found one tiny drip of oil and discovered this.
Not to worry I happened to have parts on hand, all better!
She's good to go. I'll post pics from Monday later
Gerst
Gerst is offline   Reply With Quote
Old 05-31-2011, 03:14 AM   #6355
MCLARDIE
Oddometer: 58
Ok I am a little lost here what does active verb mean as it appears to be the in saying but I have no idea what use mean by it
Cheers
Old 05-31-2011, 03:32 AM   #6356
LukasM
Oddometer: 5,427
the plan is...
4) new piston rings
7) custom cam
laters,
laramie
Man, that should be a sweet engine Laramie! Do you have any idea on budget or did you tell Tom to go crazy?
Old 05-31-2011, 06:00 AM   #6357
laramie LC4
crash test dummy!
Oddometer: 2,447
i told Tom to make sure it runs, and runs forever. since we arent stroking or boring (hopefully) the engine shouldnt be that stressed. with all new bearings, better materials, and everything balanced i hope its all worth it.
as for price, well, its not cheap. i will keep that little gem in my pocket until i get the engine back and run it. hopefully my smile will justify the expense. then i will post the final number. i don't want to scare anyone off....
laramie
Old 05-31-2011, 07:59 AM   #6358
Gerst
Gerst's Avatar
Oddometer: 253
Cheers
Mclaridie, if you're referring to this statement:
"She's good to go. I'll post pics from Monday later"
It's just my poor use of punctuation. I meant that I will post pictures from Monday at a later date or time.
If you're a hipster and end a conversation with "later" it's shorthand for "I'll see you later" or something like that.
Later,
Gerst
Old 05-31-2011, 10:25 AM   #6359
MCLARDIE
Oddometer: 58
Cheers it's ok got it now all good
Old 05-31-2011, 01:59 PM   #6360
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,691
Talking
Later,
Gerst
It's too bad you didn't post photos of your seal change job.
I am probably mistaken but I don't think that there is one in the index.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Times are GMT -7.   It's 01:47 AM.
