Old 05-31-2011, 08:58 PM   #6361
Gerst
Gerst's Avatar
Oddometer: 245
Originally Posted by mxchamp View Post
It's too bad you didn't post photos of your seal change job.
I am probably mistaken but I don't think that there is one in the index.
http://www.advrider.com/forums/showthread.php?t=102920
It's in there, actually it's how I learned
Gerst is offline   Reply With Quote
Old 06-01-2011, 02:29 PM   #6362
WIsixfitty
ceiling unlimited
Oddometer: 2,165
I'll just put this here cuz...i dunno I need halp.
riddle me this or I am crazy or option #3.
Ok so about 6 mounths ago I pulled my top end off for new cam follower bearings, water pump rebuild and roller bearing upgrade to my 02.
I vaguely remember at the time having a problem with my pump coming off even when I was pretty sure it was at tdcc.
Now when it is at tdcc the slot in the cam bolt is horizontal. The only way to get it verticle for pump install is at bdc.
I did not remove the cam or anything off the crank itself. Just the clutch etc for the bearing change. Since nothing was removed in the crank and valve train it should still be timmed and in synch, correct?
The clucth is a seperate system.
Did I screw up or miss something?
Am I crazy?
Should I drink more beer and just put it back together?
option#4
signed,
two strokes are simple like me in WI.
sideways and smiling
WIsixfitty screwed with this post 06-01-2011 at 02:30 PM Reason: speelink
WIsixfitty is offline   Reply With Quote
Old 06-01-2011, 04:41 PM   #6363
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,114
The slot in the pump often will not point upward with the engine at TDC... You need to roll the engine till the slot points up for pump removal and installation and then roll the engine back to TDC with the cams pointing down to install the rocker cover..
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 06-01-2011, 04:54 PM   #6364
WIsixfitty
ceiling unlimited
Oddometer: 2,165
ok this relieves my confusion.
Old 06-02-2011, 12:34 AM   #6365
makazica
makazica's Avatar
Oddometer: 746
I don't know how it's set up on other LC4's but the slot on mine is NEVER horizontal when the piston is at TDC!
M.
makazica is offline   Reply With Quote
Old 06-02-2011, 03:43 AM   #6366
jonnyw
Oddometer: 585
Guess what I am riding?
The proper way to do a water crossing.
jonnyw is offline   Reply With Quote
Old 06-02-2011, 08:06 AM   #6367
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,518
Talking
DoH!!!
I just had my entire engine rebuilt. That seal was leaky and so was the kickstart/shift shaft seal.
No leaks on my 640 no more!!!!!
Only cost me $2250 bucks!
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 06-02-2011, 10:29 AM   #6368
Gerst
Gerst's Avatar
Oddometer: 245
DoH!!!
mx, mind sharing what the mileage was? Was this a preventative rebuild? If not, were there signs she was going before she went? I'm new to mechanical things and trying to learn what I can (I need a motorhead neighbor)
Got a thread?
Old 06-03-2011, 03:12 AM   #6369
blanc
blanc's Avatar
Oddometer: 73
Just bought my first ktm adv a 2001. Have a few questions
http://www.advrider.com/forums/showthread.php?t=693986
blanc is offline   Reply With Quote
Old 06-03-2011, 09:07 PM   #6370
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,518
Talking
Got a thread?
Hey Gerst, here's a little story for ya.
I bought the bike used from a Marine up in Minneapolis with 24,000 miles indicated on the very inaccurate IMO. Paid too much for it seeing how much 07's are going, but was only 2 hours away, not sitting in Cali. She ran real good though coming home from Minneapolis. I just had to kick start her only.
Anywhoo, first test ride the electric starter would not work. Made one heck of a noise. This is my 3rd LC4 so I wasn't worried. I read the index and knew it was the starter clutch.
Fast forward to fixing starter clutch fixed it no problem. Except one problem was that I didn't have the proper GIANT torque wrench to torque her down properly. So I hit her 3 times with a big hammer and said hey it's all good.
Rode her around for a week or two and my conscience got to me. Opened her up again with the proper torque wrench and I should have left her alone.
Turns out this is what I think happened. While attempting to torque her properly, I removed the little allen screw in front of the engine took out the washer and put her back in to hold the connecting rod so I could torque the flywheel. This is a BIG NO NO! She was quiet before the re-torque, instant banging after the re-torque.
I damaged the connecting rod from putting that much torque on the flywheel nut. (I found this out after getting a proper owner's manual and it says it right there in black in white) So from now on put a 1 inch dowel between the spokes of the back wheel in 5th gear to hold the engine. Never use that little screw for nothing but to hold the engine in place while adjusting your valves.
The bike still ran when I rode her to the local KostsTooMuch dealership a week before West Fest in Darby MT. My mechanic told me to shut her down and not ride her again. The engine was bangin harder than a screen door in a hurricane. Thank goodness I had my trusty X challenge.
To finish up with this long drawn out story. The connecting rod was still within KTM specs. She was a little on the higher side but still good. The piston was bangin the side of the cylinder. Sooooo she needed to have the cylinder re-nickel plated. That's why the high cost. I kept everything to stock so I didn't have a hard time finding parts later in life.
I also did some other thing's to her like a new clutch cover with site glass to easily read the oil level, new oil pumps, water pump rebuild, some other little odds and ends.
But she has all new bearings, seals, gaskets and I think I even have a brand new main bearing because I replaced the main bearing before the engine rebuild.
It was all worth it because I love this bike! And the governor will never let me get another bike again.
I hope this helps and I didn't put you to sleep!
Ride safe!!!!
2014 KTM 690 Enduro
Old 06-03-2011, 11:37 PM   #6371
johnno950
Oddometer: 1,049
The tdc bolt locates into the crankshaft.
johnno950 is offline   Reply With Quote
Old 06-04-2011, 01:14 AM   #6372
makazica
makazica's Avatar
Oddometer: 746
Not only black in white, but I believe that info is written in BOLD letters in the manual.
Why is the X challenge so trusty? You don't mess around it without a manual?
Just messing with you.........
M.
Old 06-04-2011, 10:08 AM   #6373
Gerst
Gerst's Avatar
Oddometer: 245
Thanks for the story mx,
That's a hard lesson to learn but it sounds like you took it in stride, have a practically new engine and taught a stranger on the internet something.
I should buy a service manual! Anyone know where I can get a spiral bound hardcopy?
Gerst
Old 06-04-2011, 08:32 PM   #6374
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,518
Bluhduh
Wherever it goes, I broke it.
Ride safe!!!!
2014 KTM 690 Enduro
Old 06-04-2011, 08:34 PM   #6375
mxchamp
Registered Lurker
mxchamp's Avatar
Oddometer: 1,518
M.
I don't have an owner's manual. Never got one with the bike. I saw the BOLD wording at the dealership, after the damage was already done.
The X challenge is the bike that got me to Darby Montana and back last summer. That Rotax engine is bulletproof. Never had a problem with her the entire 16,000 plus miles that I put on the girl.
She is now happy down in Dallas Texas with her new owner.
How do you do multiple "quotes"???
Ride safe!!!!
2014 KTM 690 Enduro
mxchamp screwed with this post 06-04-2011 at 08:47 PM
Times are GMT -7.   It's 02:33 AM.
