Old 06-12-2011, 04:02 PM   #6391
daviken
Oddometer: 17
Hi, I'm David, from Spain
My bike is a ktm lc4 640 adv 2004 and 20.000km
Crash Bar hepco becker
akarpovic slip on.
fcr 39 mx in the process of adjustment and idle problems, You can see here.
http://www.advrider.com/forums/showthread.php?t=696541
ktm 640 adv 2004
daviken is offline   Reply With Quote
Old 06-13-2011, 01:41 AM   #6392
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,317
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 06-13-2011, 08:19 PM   #6393
mike cramb
mike cramb's Avatar
Oddometer: 1,312
Remus twin system
Hi all,
Anyone got any picks of a 640 with the twin remus exhaust system. I got a chance at buying a set but want to see what it will look likew on the bike. There are supposed to be some in here but i gave up after looking at 50 pages.
we are already here!
mike cramb is offline   Reply With Quote
Old 06-13-2011, 09:24 PM   #6394
mike cramb
mike cramb's Avatar
Oddometer: 1,312
2001 adventure remus
Anyone know if a remus twin system off a 2001 model adventure will fit a 2005 model. Aparently it fitted stock standard 2001 with original bash plate.
Old 06-14-2011, 12:53 AM   #6395
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,396
2001 had different sized primaries and exhaust ports than 2005, according to staintune they do not interchange either. I think 2001 had a different seat and subframe as well, not sure if it was 2000 or 2001.
From what I have read the remus twin systems with the larger primaries and collector also had different version for different carbs, they are that tight.
Aussie Steve is offline   Reply With Quote
Old 06-14-2011, 03:08 AM   #6396
mike cramb
mike cramb's Avatar
Oddometer: 1,312
Bugger
There goes that idea, I will have to keep my wings and my brother gets the akros.
Old 06-14-2011, 03:32 AM   #6397
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,470
I tried to get a Wings but by that time they were sold out everywhere. Upon talking to the manufacturer they said they wouldn't do another run for us even with a big # order. Akro it is. now I just need new packing to quiet it down a bit.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 06-14-2011, 04:26 AM   #6398
mike cramb
mike cramb's Avatar
Oddometer: 1,312
I have a wings
I have a wings but was offered the remus twin set and a full akro set as well. I was thinking of using the twin remus and my brother will use the akros. I dont think the twin set will make a huge difference but they sure look good.
Old 06-14-2011, 08:27 AM   #6399
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,391
akra makes a dB killer that you can fit into the silencer. makes it run about 91dB. without it, it's somewhere in 100dB range. let me know if you need a part #, you can also get a Spark Arrester for it, but i haven't tried it yet.
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-14-2011, 09:41 AM   #6400
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,948
laramie
I'm pretty sure Mike has one. Sorry skibum69, you probably aren't going to get it much quieter than you already have it, unless to left half of your packing out on the Trans-Lab. It would be interesting to see how much packing does. Grawydawgg repacked his Akra when he did his motor.
I did the FMF arrestor in the Akra. Worked perfect.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 06-14-2011, 02:07 PM   #6401
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,470
yeah we had this chat once already and I'm pretty sure that yes the Db killer is in mine-it's stock and I didn't mess with it. I'm just hoping I can get the noise down a little. I talked to Grawydawgg already about his experience so I'll just wait a bit. Hmmm...I bet the industrial high heat shit I run into at refineries would work pretty good?
Beerthief
Old 06-14-2011, 02:50 PM   #6402
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,538
Talking
Refractory insulation? Get yourself some of that and you won't ever have to repack again.
It's here at the ethanol plant where I work. We put it in our boilers. Withstands 1600 degrees constantly.
I just repacked my silencer on the 520 because it was so loud. It didn't help with the noise at all.
Still loud just doesnt rattle anymore.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is online now   Reply With Quote
Old 06-15-2011, 05:04 PM   #6403
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,470
thanks for the tip, all I need to do is get back on the job where we had it-too bad I didn't think of it then. Nasty shit-don't breath around it unless you're wearing a respirator
Beerthief
Old 06-15-2011, 10:20 PM   #6404
Reinhold
No, not Messner
Oddometer: 195
Originally Posted by clintnz View Post
Damn, it's those nefarious air elves again...
Mine get spongy every now & then, bled it & pissed around with it quite often until somebody on this fine forum suggested pushing back the pistons in the caliper with the master at the highest point of the line - bike on sidestand, bars turned left, push on caliper with knee (helps to have knee guards on) then tip the bike over some more to make sure the master is at the highest point, hold the line down if needed, & pump em back up - works every time.
Cheers
Clint
Sorry Clint but what do you mean by "push on caliper with knee". I'm just not picturing what you're suggesting. Thanks......
Reinhold is offline   Reply With Quote
Old 06-16-2011, 12:35 AM   #6405
makazica
makazica's Avatar
Oddometer: 746
Its a "floating" caliper so you can push the piston in by moving the caliper assembly towards the disc!
M.
makazica is offline   Reply With Quote
Times are GMT -7.   It's 04:11 PM.
