Old 06-16-2011, 01:10 AM   #6406
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
KTM Stand
Originally Posted by Lee Cook View Post
see you're using a KTM lift stand
i think I've seen the same on cyclehuts website
how good is it at taking the 640's weight?
on cyclehuts website there are 2 different sizes is yours the 310/400mm one?
need to get a bike lift for a decent price & these look OK but would appreciate your comments
thanks Cookie
The stand is from KTM dealer. I do not know the height but my bike was lowered so its a little hard to put it under the bike. I usually put the front wheel on something and then it go's easy under the bike.
It holds the bike with no problems, it is easy to lift the bike and take it down.
I recommend.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
erdsh is offline   Reply With Quote
Old 06-16-2011, 02:04 AM   #6407
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
Mikuni Fuel Pump
Since the original fuel pump is not working, I ordered the 14 L/H single outlet mikuni vacuum fuel pump.
Since then, the carb is pouring fuel. I replaced the needle and balanced the float and still the carb is leaking fuel.
I bypass the fuel pump, by connecting the fuel tap directly to the carb and filled the fuel tank and it is working great with no problems.
By doing this, I assume the fuel pump has higher pressure the the original, and due to this the CARB is leaking with fuel.
Please advise, what should I do?
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
Old 06-16-2011, 02:43 AM   #6408
blanc
blanc's Avatar
Oddometer: 73
If any of you guys are familiar with lc4 engines please take a look, I am an unlucky new 640 Adventure owner whos bike blew on my second ride.
http://www.advrider.com/forums/showthread.php?t=696592
blanc is offline   Reply With Quote
Old 06-16-2011, 11:12 AM   #6409
Lee Cook
Oddometer: 24
I recommend.
thanks, its the weight that I was more interested in
the stands come in 2 heights so that shouldn't be a problem
I'll buy one tomorrow
Lee Cook is offline   Reply With Quote
Old 06-16-2011, 03:23 PM   #6410
WIsixfitty
ceiling unlimited
Oddometer: 2,304
is anyone using the upper fairing for tube storage?
only downside I see is possibly having to drill through for some type of mounting. Or glue some tabs?
sideways and smiling
WIsixfitty is online now   Reply With Quote
Old 06-16-2011, 10:39 PM   #6411
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,852
buy the KTM pump .. the gallons or liter output per hour is more than likely higher with the 14LH mikuni.. without the pump you will only get half the gas out of the tank or until the fuel level reaches the carb level..
wrk2surf is offline   Reply With Quote
Old 06-16-2011, 11:52 PM   #6412
TEZZA
ADV B4 DEM/TED
TEZZA's Avatar
Oddometer: 299
Thumb Brakes
Hay Zack you are a magic man .
I pumped the front brakes up last night and just took off the cable tie after 20hrs and PRESTO i have front brakes .
This method must alllow the air to be burped out some how .
Thanks Heaps Zack.
Thanks Tezza
Originally Posted by bigzack View Post
This has always worked well for me. Squeeze the lever several times like your pumping it up to bleed it and zip tie or tape the lever to the grip and leave it for several hours, overnight if you can wait. When you release the lever in the morning the brakes should be as good as they ever will be. It works on all brakes, cars too.
Zack
Tezza.
KTM 990 ADVENTURE.
KTM 520 EXE.
Now the Perfect pair!!!!
TEZZA is offline   Reply With Quote
Old 06-17-2011, 07:21 AM   #6413
bigzack
6'6" of awesome
bigzack's Avatar
Oddometer: 61
Brakes
Glad to hear it worked for you.
Zack
bigzack is offline   Reply With Quote
Old 06-17-2011, 10:24 AM   #6414
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
The ktm pump is actually Mikuni. and it looks like he original is less then 14L/H.
I wonder if anyone knows the details of the original pump. it is not specified in the owners manual nor the workshop manual.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
Old 06-17-2011, 12:56 PM   #6415
Tseta
Lost
Tseta's Avatar
Oddometer: 674
-T
Tseta is offline   Reply With Quote
Old 06-17-2011, 01:01 PM   #6416
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Mikuni DF52 - 32L/h (from some older AdvRider posts YMMV)
58512087000 FUEL PUMP MIKUNI DF52-601 01 $78.94
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 06-17-2011, 11:42 PM   #6417
bigboyxl
bigboyxl's Avatar
Oddometer: 331
hi all!!
i have a 2006 640 Adv model and covered more than 30000 kms, I use it mostly for long offroad blasts and for traveling to the countries with bad roads (read without roads). Now I decided to make it little bit lighter and first I want to change is to put a titanium exhaust on it. I've found only 3 options:
1. Titanium factory headers (57305007000) + Factory-endsilencer titan (57305079300)
2. Remus FREERIDE, full system (header & y-tube, muffler), titanium, EEC (SKU 219802 654603)
3. Remus FREERIDE, full system left/right ( header & y-tube, 2 mufflers), titanium, EEC (SKU 219802 654503LR)
Which one is better? (lighter and gives more power?) Or maybe there are some more options?
Thnx in advance
bigboyxl is offline   Reply With Quote
Old 06-18-2011, 04:23 AM   #6418
mike cramb
mike cramb's Avatar
Oddometer: 1,312
Same same only different
Hi big boy xl
hope someone knows the answer cause I am asking the same questions. I just got a used remus twin system and dont know if it fits yet.I may have to modify the ports. See a few posts back.
Like to pack up my bike and come over your way and ride the road of bones.
Mike
we are already here!
mike cramb is offline   Reply With Quote
Old 06-18-2011, 04:42 AM   #6419
The Mass
Timbuktu or Bust... Both!
Oddometer: 335
Originally Posted by mike cramb View Post
Hi big boy xl
Mike
Gents
Try a search for WINGS mufflers.
They are made solely for KTM's and are a class piece of work. (Dare I say....equal to an AKRO)
The Oz importer is MOTOTOYS, he doesn't list one for the 640 anymore, but there might be a few flying(get it?) around somewhere.
Cheers
Mass
01 640 Adv
06 250 EXC
73 250 Motosport
04 GSX1400 (with USD front end)
The Mass is offline   Reply With Quote
Old 06-18-2011, 05:22 AM   #6420
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,533
Originally Posted by The Mass View Post
Gents
Cheers
Mass
nope, I tried to find one on 4 continents and the manufacturer won't do another run-I tried.
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Times are GMT -7.   It's 12:42 PM.
