08-01-2011, 04:55 AM
#6541 | |
Oddometer: 219
KTM LC4 640 Adventure 2006 KTM LC8 990 SM-T 2010 KTM 530 EXC 2011 ![]() www.alburmoto.com Nomada panniers, Holan crashbars, Remus silencers etc. Worldwide shipping. Better deals for ADVriders |
08-01-2011, 05:17 AM
#6542 |
ADV B4 DEM/TED
Oddometer: 117
Rallye side tank
Who ever has the best buy price can buy the tank . Send me a PM with your price , this will be plus postage.
Tezza
Tezza. KTM 990 ADVENTURE. ![]() KTM 520 EXE. ![]() Now the Perfect pair!!!!
08-01-2011, 06:39 AM
#6543 |
Oddometer: 1,312
Rallye tank
Hmmm that would look good on this and almost give me the range I need for the CSR. I am in North Victoria on Thursday sent you a PM.
![]() ![]() ![]() Mike.
we are already here! |
08-01-2011, 08:46 AM
#6544 |
Oddometer: 219
btw what volume does it carry?
08-01-2011, 12:44 PM
#6545 |
Oddometer: 1,220
I ask for it
and you boys try to snake me on it? Thanks!!!! |
08-01-2011, 04:22 PM
#6546 |
ADV B4 DEM/TED
Oddometer: 117
Rallye side tank
Now stop all the Bitching boys . I am not sure how much the tank holds as i have never filled it up , it is possably 8 to 10 litres. The tank came with the bike when i bought it , as you can see in the pic of one fitted it dosen't fit up to the seat and has a 20mm / 3/4 " gap.
It wouldn't fit if you have a muffler on that side , you would have to drop the exhaust down and under the bike like the Rallye . Tezza.
08-04-2011, 11:44 AM
#6547 |
Lost
Oddometer: 654
![]() ![]() Well, well, well.... Those are not supposed to look like that, now are they? Despite "heavy" reinforcements, the subframe has cracked. The deep gouge is on inside of the swingarm and is quite a mystery. It cannot have come from the inner fender or the tire. My theory is that a large rock has gotten lodged in the knobs and it has then made a few rounds. Not pretty. The joys of LC4 ownership. Somebody here on AdvRider said something to the style of "Ural miles are kind of like dog years." As a corollary, I could claim that miles spent traveling on Russian roads are kind of like dog years as well. Cheers, Tseta |
08-04-2011, 02:21 PM
#6548 |
ceiling unlimited
Oddometer: 1,806
miles after reserve to empty?
I ran out of gas. Lucky for me I was 1/4 mile from my shop.I coughed it to reserve within a mile of the light going on, then about 18 miles later it done died. Normal? btw the 640 runs on coffee. well at least the gas that went in looked like coffee.
sideways and smiling |
08-04-2011, 06:47 PM
#6549 |
ADV B4 DEM/TED
Oddometer: 117
Sub frame crack
Tseta , when the sub frame is braced to stop the cracking it has to be plated on the down leg as well to stop this type of cracks .You can also remove the tool box frame and plate from one end to the other the same as the muffler side .
The inside of the swing arm , it gould be the wheel out of alignment and over to one side more than the other .Or is it back futher to the sprocket or disc rubbing ????????????? ![]() Tezza
08-04-2011, 07:37 PM
#6550 | |
Crashing since 1964
Oddometer: 4,248
The 908 didn't impress me enough on the rear of my 950, never tried it on the 640. However, I do like the MT-21's on the 640, enough to race it in the mud on them and feel stable at speed and on twisty back roads, plus they can be had as a set pretty cheap
Michael |
08-04-2011, 07:52 PM
#6551 | |
Lost
Oddometer: 654
The gouge on the swingarm is on the brake disk side. The rim, tire or the disk show no signs of wear that could be attributed to causing the gouge. All the relevant spacers are in place etc. The location of the gouge, relative to the tire/disk supports the theory that something (a larger rock?) got lodged in between the knobs of the tire. -T |
08-05-2011, 01:39 AM
#6552 |
Oddometer: 11
Greetings from South Africa! Been lurking for quite a while now. Here is my 2002 640. I've had it for a couple of months now. What an amazing bike! Will be personalising it some more as time goes on. So far I've only done the front fender.
08-05-2011, 02:42 AM
#6553 |
viertaKTMotor *****
Oddometer: 155
Hi, there… It sure is a sweet looking bike but a lot too clean
08-05-2011, 02:46 AM
#6554 |
Oddometer: 11
08-05-2011, 11:23 AM
#6555 |
Lost
Oddometer: 654
The trick, and how it's done...
![]() I had the swingarm TIG-welded at a local shop. ![]() I filed down the welds a touch. Good as new? --- Then, the subframe... ![]() Started off by separating the cracked pieces and stripping the paint off of them. ![]() An appropriately sized solid insert was then fabricated for the frame tube. ![]() Holes were drilled in the frame pieces and the assembly was aligned for welding. ![]() Plug/spot welds through the holes hold the assembly together while the insert ensures proper alignment and increases the strength. ![]() The cracked area was "opened" with an angle grinder and welded up. ![]() As a final touch, an additional gusset was added and the welds were ground down a bit. Ready for painting and reassembly. ... Easy as 1 - 2 - 3, huh? ![]() Cheers, Tseta |
