Old 08-30-2011, 03:02 PM   #6661
jonnyw
Oddometer: 585
Thumb +1 on the Cycra Pro Bend
Originally Posted by mxchamp View Post
That what I have been useing for years. The best there is IMOP. I you can find a mount that will work on the triple thats the bomb. It keeps your bars open. The deal with the ProBend is it lets your hand get out easier in case of a get off. Some will trap your hand in certain situations. Which isnt good if your body and bike are parting ways.
jonnyw is offline   Reply With Quote
Old 08-30-2011, 03:57 PM   #6662
Sprout640
Sprout640's Avatar
Oddometer: 113
thanks
This aint no biggie. My 01 640adv isnt leaking. But I just did one on my 09 CRF450r. Pulled it from the outside. It did have a collar that when removed gave more room to hook the seal. It took all of 15 min. Definitely easier than a topend job.
Hey thanks for that. Im definitely leaking around the shift shaft, not the kick start shaft... it seems (from what I can read on the links that I was given) that the #9 O-ring is easier to replace...
The next couple days will tell. Ill post a follow up when I get into it...
thanks for the help and comments.
this is a great forum and resource.
Id rather be an "also ran" any day than one of those whose sole contribution amounts to an "I told you so..." from the distance of some ether-net induced coma... me...
Sprout640 is offline   Reply With Quote
Old 08-30-2011, 09:03 PM   #6663
mike cramb
mike cramb's Avatar
Oddometer: 1,312
rear frame
Anybody know if the exc rear sub frame fits a 640 Adv, fter one to chop up to fit the rallye tank.
Mike
we are already here!
mike cramb is offline   Reply With Quote
Old 08-31-2011, 12:55 AM   #6664
TEZZA
ADV B4 DEM/TED
TEZZA's Avatar
Oddometer: 298
Hi Mike , from what i have seen from my old 640 E to the 640 A thay are the same . The other way would be to make one(copy from the one on the bike ) out of solid steel bar with gusets and build it to what you need .
Tezza
Mike
Tezza.
KTM 990 ADVENTURE.
KTM 520 EXE.
Now the Perfect pair!!!!
TEZZA is offline   Reply With Quote
Old 08-31-2011, 07:17 AM   #6665
bmwktmbill
Traveler
Oddometer: 5,147
Originally Posted by Tseta View Post
There are typically two different cleaning/oiling products, the "bio" kind (basically the cleaner is water based) and the "regular" kind (the cleaner is solvent based).
Many manufacturers for both types. Usually, you don't want to use gasoline or any other harsh solvent for cleaning. You should use tried and tested products. The air filters for KTMs are made by Twin Air, and I've been using their Bio system with no problems so far. However, they say that you should start using the Bio system on only a fresh, new filter, not one that has been previously oiled and washed with some other system.
Here's one manufacturer's (TwinAir) instructions for their Bio system: Click!
And here for their traditional system: Click!
Also, a video tutorial for the bio system: Click!
Cheers,
Tseta
Tseta,
Well you know me...not always by the book.
I have many times pulled the fuel line off the tank and turned the tap on to soak the air filter, then squeezed it dry, rinsed again and again, three times usually does it.
Next I let the filter dry in the sun and then oil it with engine oil lightly and reinstall. I like the grease seal and always wipe the airbox clean.
Then it's down the road from the middle of nowhere to the middle of nowhere.
Improves my mileage around 5mpg usually.
When mpg drops I know the filter is dirty.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 08-31-2011, 07:36 AM   #6666
jmazz
Oddometer: 34
Originally Posted by Sumi View Post
Where does the yellow-black red-black two pole connector connect to? and what is it for? mine is unconnected:)
I took a look last night and couldn't follow it. It went into a loom and I never found where it came out. Also, when I look at the wiring diagrams I can never find anything that matches my wiring colors.
jmazz is offline   Reply With Quote
Old 09-01-2011, 10:12 PM   #6667
mxrider14
Oddometer: 12
Just bought a 2001 KTM 640e. It has the Magura HYMEC (aka Magura Jack, but the old one) system for the clutch cable. However, it felt like it was adjusted wrong, so I started taking everything apart to diagnose it. I've never had a hydraulic clutch like this. I was going to reverse bleed it with a syringe, but I could not find a bleeder valve anywhere.
Long story short, I got air in the lines. Now the lever is completely soft. I found out that the arm was just adjusted wrong, and I didn't even have to bleed it in the first place stupid me.
How can I get the air out of the system? I have literally been searching for the past hour and a half, and searching google as well.
It looks like where the bleeder valve is supposed to be, there is just an allen bolt that has no bleeder on it, where you would attach the hose to. That allen bolt has the hole drilled through the side of it of course. If I need to take pictures, I can. If I need to buy a new banjo bolt with a bleeder on it, does anyone know where I can get one from? The bike is just sitting in my garage now, begging to be ridden.
Thanks for your help.
mxrider14 screwed with this post 09-01-2011 at 10:49 PM
mxrider14 is offline   Reply With Quote
Old 09-03-2011, 10:32 AM   #6668
cbobr
Oddometer: 10
Hello,
below (hopefully) is a photo of my bike, a 2006 640 Adventure.
Does anyone happen to know the standard bearing no. for the inlet cam lobe follower bearing? I've had a wee failure at ~47,000km in Dushanbe (where there is no KTM dealer) and am hoping to find a bearing locally.
Cheers
Wayne
cbobr screwed with this post 09-03-2011 at 10:41 AM Reason: I only speak English, but I haven't mastered it
cbobr is offline   Reply With Quote
Old 09-03-2011, 10:40 AM   #6669
Nokmuay
Plan B Specialist
Nokmuay's Avatar
Oddometer: 532
Damn bro, that sucks! Sorry I cant help ya at this instant, but Im gonna dig out my manual and see. Its a long weekend here in Canada so all the dealers are MIA until tuesday. I will do my best to find it for ya! Best of luck at getting one faster then I can find it!
NokMuay!
Current ride is
08 CBR1000RR
05 KTM 640 Adventure R
Nokmuay is offline   Reply With Quote
Old 09-03-2011, 10:46 AM   #6670
Tseta
Lost
Tseta's Avatar
Oddometer: 672
Originally Posted by cbobr View Post
Hello,
Cheers
Wayne
I've spent some time trying to figure out possible alternative bearings for this application. Unfortunately, it seems that it is only available through KTM.
Hope everything works out for you.
-T
Tseta is offline   Reply With Quote
Old 09-03-2011, 10:54 AM   #6671
cbobr
Oddometer: 10
Thanks Tseta and Nokmuay, the quick replies are appreciated.
I might have to try to get onto a KTM dealer in Europe after the weekend.
Cheers again.
-T
Regards
Wayne
Old 09-07-2011, 11:44 PM   #6672
mike cramb
mike cramb's Avatar
Oddometer: 1,312
Geeezzzzz Wayne
Hello,
Cheers
Wayne
Looks like your are abit out of the way there Wayne. Where the hell is Dushanbe
Old 09-08-2011, 12:21 AM   #6673
Nokmuay
Plan B Specialist
Nokmuay's Avatar
Oddometer: 532
Sorry I called out of town on a very last minute call, and got the joy of riding in the cold rain without bringing the rain gear, since it called for 5 days of 0% chance of rain. Man, meterologists are just really bad at thier jobs lol.
I saw the guy had answered your question so I figured it was all good. My manual didnt show a bearing # either. Hope things have worked for you.
Hope things are all good now!!!
NokMuay!
Current ride is
08 CBR1000RR
Old 09-08-2011, 02:15 AM   #6674
Laromonster
Vesperado !
Laromonster's Avatar
Oddometer: 1,322
Tadjikistan (sp?)
'99 Road king
'09 XR1200
Laromonster is offline   Reply With Quote
Old 09-08-2011, 04:24 AM   #6675
Danielmoben
Danielmoben's Avatar
Oddometer: 27
Rebuilding my KTM 640 adventure lc4
http://mobenmotorcycles.blogspot.com...nture-lc4.html
Hello to all, here a link from a non-profesional restauration from a 01 KTM adventure from Spain, I have to say, that this is not a profesional restauration, just done, with the tools we have in ur house, and due to the hard use is this bike used, not spending a lot of money in the process...
Any new idea is wellcome, the next idea is keep working in the electrical instalation and in the dash board...
Thanks a lot.
Dani.
Danielmoben is offline   Reply With Quote
Times are GMT -7.   It's 02:01 AM.
