Old 10-20-2011, 03:23 AM   #6781
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
Originally Posted by Jawk View Post
Not sure how I feel about the re-spray from orange, but its held up well for a lot of outback kms, so maybe I'll leave it as is...
Cheers
If it makes you feel any better about it, I have a picture of your bike saved on my computer as I think it's the best looking non-standard paint scheme. I love it!
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 10-20-2011, 05:40 AM   #6782
Jawk
Im lost again.
Jawk's Avatar
Oddometer: 224
hey b-rod, now Im curious...??
you get that pic off this site somewhere?
KTM250exc- for sale, KTM690e
Jawk is offline   Reply With Quote
Old 10-20-2011, 07:37 AM   #6783
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
Yup. Don't ask me to find it, but it's in the this thread somewhere.
Old 10-20-2011, 12:54 PM   #6784
Jawk
Im lost again.
Jawk's Avatar
Oddometer: 224
Found it...
Small world, four years later it turns up 1100km away fromthe bloke who did the sticker kit (wayne640).
Anyway, cheers, Im off to work.
Old 10-20-2011, 03:34 PM   #6785
Geekventure
Geekventure's Avatar
Oddometer: 125
What kind of bash plate is that black looking one in the pic with the little girl?
"Not all those who wander are lost." - J. R. R. Tolkien
Geekventure is offline   Reply With Quote
Old 10-20-2011, 10:14 PM   #6786
Jawk
Im lost again.
Jawk's Avatar
Oddometer: 224
Im assuming its just a KTM issue one - its a black plasticky one, with five bolts holding it on. Would only protect from rocks and stones, not from a frame crushing event. The one in BRods photo looks more substantial.
Old 10-20-2011, 10:19 PM   #6787
Geekventure
Oddometer: 125
It looks like it goes behind the frame (up front)...and even through the frame (on the sides)? Is this an '07 thing?
Old 10-20-2011, 10:23 PM   #6788
Jawk
Im lost again.
Jawk's Avatar
Oddometer: 224
No it doesnt go behind the frame at all but it is molded so it hugs the frame closely, but only covers the outside of the frame and up the front as far as just past the top of the spin on filter.
I'll see if I can get a part number of it somewhere (but cant let you know till day after tommorrow - im off camping in half an hour... gonna get wet!)
Cheers
Old 10-21-2011, 11:46 AM   #6789
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,594
I like wearing my MX boots if I'm going to be offroad at all, but I wore my Aerostitch Combat boots on my last 7500 km ride, mostly for rain protection. Pants I'm wearing Klim Dakar but I'm working on getting the Klim Adventure suit. Looks to be everything I'm looking for but crazy spendy.
Yeah the black and white looks great!
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 10-22-2011, 01:53 PM   #6790
Sumi
Sumi's Avatar
Oddometer: 1,864
I did a valve clearance check on wednesday, and I'm not sure I did it correctly..
I didn't have a soda straw, so this is what I did:
Removed the rocker covers, put the bike in 5th gear, and started to rotate the rear wheel.. When the intake valves opened, I started to back off the rotations speed, then they (the intake valves) kind of slamed to the closed position within 1mm of rear wheel movement.. After this I've turned the rear wheel slowly to get the timing mark in the center of the sight glass, then screwed in the locking bolt to the front of the engine.. a little movement on the rear wheel (+-1mm), and the bolt went in place..
Then I've checked the clearences.. If I grabbed the rockers and tried to move them up and down, I could feel and hear some "ticking". It was really difficult to get the feeler gauge in there, and IMO it was a quite tight feel.. Anyways, I didn't adjust the valves, because the guy, who I was doing this procedure with said it was okay. (the guy is a KTM dealer).
My only problem with the whole thing, and my doubt is, that it (still) has quite an audible valve ticking noise when the engine is runing. Gets even worse when the engine gets warmed up..
I'm confused because I think that if I were checking the valves at the correct timing position + it felt tight - then why is the ticking noise? Plus why does it get louder if it's warmed up? I'd expect the oposite behaviour..
So:
1, Do you think I was at TDC?
2, What could cause the ticking (valve?) noise, if the clearances felt tight?
Thank you!
Old 10-22-2011, 03:44 PM   #6791
tallbob
tallbob's Avatar
Oddometer: 616
Well it's a 640 but not an Adventure, the light weight (relatively speaking) E model A good day to ride today!
Twin Valley Riders
tallbob is offline   Reply With Quote
Old 10-24-2011, 07:13 PM   #6792
Baja Dad
Baja Dad's Avatar
Oddometer: 2,041
What a nice Sunday Ride!
Went out for a quick ride yesterday..... put in over 100 miles!!!!!
love IT!!
Baja Dad screwed with this post 10-25-2011 at 08:03 AM
Baja Dad is offline   Reply With Quote
Old 10-30-2011, 04:10 PM   #6793
Sumi
Sumi's Avatar
Oddometer: 1,864
Hi!
Will a 120/80-18 tire fit the stock (2.50) rim?
Old 10-30-2011, 05:44 PM   #6794
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,349
Originally Posted by Sumi View Post
Hi!
Yes, I have run 3 or 4 in that size without a problem... That skinny tire makes the back wheel look like a pizza cutter....
gunnerbuck is offline   Reply With Quote
Old 10-30-2011, 06:32 PM   #6795
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,165
Hi!
Works just fine, I think that's what the shinko that I just used up was. And I know I had a avon roadrider on in that size for 1,000 miles after that. Now I've got a 140/80-18 TKC on there, looks much different.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Times are GMT -7.   It's 09:13 PM.
