Old 04-22-2012, 10:40 AM   #7141
AEsco48
Oddometer: 63
Transmission issues...
Two things are happening on my 2002 Adventure thats new to me.
1st is that if I am stopped and I ride off and give it a little more gas then the minimum as I take out the clutch I get a noise that is like a intermittent slipping/friction noise. I am not talking about giving it a lot of gas... just enough to ride of a little faster then the minimum.
If 1/4 of a liter of car oil was put in to top it off... Could that have affected the clutch plates?
Other thing is when I go from 2nd to 1st if I am riding really slow and just clutch in and click down it goes into N and I have to clutch in and kick down 1 or two times with extra force to get it into 1st.
Thank you!
AEsco48 is offline   Reply With Quote
Old 04-22-2012, 10:41 AM   #7142
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,488
Originally Posted by Gregmanton1 View Post
they dont list one for our bike how did you get it call them ??
or am I not seeing the listing
I emailed them, and they had the molds for it and made me one.
Originally Posted by Tye View Post
I'd be interested in that seat. was going to invest in a renazco.
The original is comfy but too wide. Being only 5ft 6 I could do with something a bit narrower. Its like sitting on a shire horse
The new seat is narrow at the front and a bit wider in the back. Much firmer than the old one that's for sure.
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 04-22-2012, 10:43 AM   #7143
juames
juames's Avatar
Oddometer: 2,488
I'm no expert, but sounds like the 'car oil' you added might have had some anti-friction additives, which is no good for a wet clutch.
Thank you!
Old 04-22-2012, 01:07 PM   #7144
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,969
That could do it for sure. Don't fret though, get that oil out of there, put some proper m/c oil or Rotella, or similar, ride for a bit, then change it out again. It shouldn't do any permanent damage to the plates. A couple oil changes should get the car oil out of there and your clutch should return to normal. Not to turn it into another oil post, but Rotella synthetic works very well in the 640, and Rekluse even recommends it for auto clutches, which use the stock friction plates.
Thank you!
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 04-22-2012, 08:28 PM   #7145
bansheeman
Oddometer: 9
Just a couple of pic's to show off my recently overhauled 640, a set of graphics to finish her off is the next purchase......hope you like!!!!!!
bansheeman is offline   Reply With Quote
Old 04-22-2012, 10:19 PM   #7146
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,158
oh yeah and Juames I made my own tank guards about 50.00 in material
Sounds like a write up is in order!
Low594 is offline   Reply With Quote
Old 04-22-2012, 10:20 PM   #7147
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,158
Looks awesome! I would paint the headlight area black, but thats me! I really like the orange frame!
Old 04-22-2012, 10:22 PM   #7148
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,158
What was the cost? Is it stock height?
Old 04-22-2012, 11:24 PM   #7149
bmwktmbill
Traveler
Oddometer: 5,185
Thank you!
I don't think the oil is the problem, all we used to have was car oil.
If the noise continues, sure change the oil but better yet adjust the cable first and disassemble the clutch case side of the engine, check the clutch basket for grooving. You can file/Dremel them awayfor a smooth operation,
Check tne needle bearing and other parts or wear, replace the lip seal in the clutch case that runs on the end of the crank. Now you are sure the clutch is good.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 04-22-2012, 11:52 PM   #7150
AEsco48
Oddometer: 63
bill
Thx!
Any ideas about the 2nd gear to Neutral instead of 1st gear?
Old 04-23-2012, 04:55 AM   #7151
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
A'm not a fan of white bikes, I must say, I would like to see it with the graphics on. I think it can do the change.
I totally agree about the black light area to give a color cut, and I definetely like orange for the frame.
Keep us updated!
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider screwed with this post 04-24-2012 at 02:14 PM
liferider is offline   Reply With Quote
Old 04-23-2012, 04:19 PM   #7152
TaxMan
TaxMan's Avatar
Oddometer: 114
+1 on the car oil adding to the clutch slipping. a buddy of mine recently made this mistake with his first bike. he did it with 100% car oil, so the problem was pretty dramatic in the before/after context. as mentioned, a couple of oil changes later, problem fixed. perhaps slightly worn clutch springs plus 1/4 of car oil was enough for your beast to lose traction. not sure if this bridges over into your shifting problem, but I'd try at least one oil change to see if that sorts it out before pulling the side of the case off.
Thank you!
2002 Triumph Bonneville
2003 KTM 640 Adventure
TaxMan is offline   Reply With Quote
Old 04-23-2012, 04:38 PM   #7153
jconly
jconly's Avatar
Oddometer: 409
Hey Guys,
I'm currently thinking about a 2003, and if I'm correct, this is the year KTM made a major update to the bike.
Were there any more updates to the 640 before they discontinued it in 2007?
-J
jconly is offline   Reply With Quote
Old 04-23-2012, 07:01 PM   #7154
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
why did you route the brake line on the outside?. looks vunerable to trail debris and tip overs
and man that thing glows you gotta get it dirty
640 adventure rack for sale
http://www.advrider.com/forums/showp...1&postcount=23
Gregidy is offline   Reply With Quote
Old 04-23-2012, 07:21 PM   #7155
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,487
Originally Posted by jconly View Post
Hey Guys,
-J
Yep, 03's got the high flow head, upgraded gbox bearing, hydro clutch, nicer dash. 04 got bigger pegs & an upgraded clutch. 05 (IIRC) Adv got the twin disc front brakes. Dunno if there was much else.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Times are GMT -7.   It's 07:07 PM.
