07-29-2012, 01:29 PM
#7321 |
Oddometer: 74
Just a confirmation question, and I don't think this is worth a separate thread...
What TwinAir part number is for a 2001 LC4 640E? 154514 or 154512? I pulled out the filter and it has the oval kind of opening. The TwinAir application guide lists disjointed years/models between these two part numbers. Thanks!
"Is there any system you can't introduce chaos into?!" |
08-08-2012, 01:28 PM
#7322 |
Oddometer: 24
in the for sale section
KTM 640 ADV 2005 plate 2 owner bike (incl me) MOT till 23/03/13 & Tax till 28/02/13
33k miles, FSH with all bills & MOT, last serviced 30/03/12 incl valve check new Conti TXC 80 F&R 300 miles ago & spare Metzler Saharas new battery new fork seals 300 miles ago H&B Gobi Luggage H&B Tank Guards KTM Handguards Touratech Headlight Guard, folding mirrors (& Originals) & rear rack Datatagged KTM briefcase, 2 keys Stenhouse bar ends great bike looking for offers around £3,500.00 ![]()
Lee Cook screwed with this post 08-08-2012 at 01:34 PM Reason: trouble with picture |
08-09-2012, 06:19 PM
#7323 |
slave to gravity
too bad it's so far away, I would have tried to pry the luggage
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk |
08-09-2012, 08:15 PM
#7324 |
KTM Tragic
LC4 Oil Change
Hi Everyone, just bought myself an '05 625SXC which shares the in-frame oil setup with the 640 adventure and I imagine the oil-change procedure is the same. I owned an adventure many years ago and recall there being an awesome step-by-step thread on how to do an LC4 oil change including photos. Can anyone post a link?
I seem to have a slow leak from the burping outlet at the top of the frame on the RHS and the oil is coming out really clean (might be due to a meticulously clean previous owner). I'd just like to make sure that all is good, perhaps it wasn't burped properly or I need a new washer? any advice much appreciated
08-09-2012, 08:33 PM
#7325 |
Track Addict ADV Wannabe
On the road less traveled.... .... You always meet more interesting people! ______________________________________ 2003 KTM 640 Adventure 2009 Husqvarna TE 310 |
08-09-2012, 08:47 PM
#7326 | |
Trans-Global Chook Chaser
Oddometer: 2,735
I found KTM do a kit with the filters, all bung washers & a filter cover gasket for an oil change for the same price as just the 2 filters separately so mine get replaced every time now. Cheers Clint
'03 KTM 640 LC4 Enduro The wilderness, the desert - why are they not crowded .................................................. .....with pilgrims? |
08-09-2012, 09:07 PM
#7327 | |
Big Bike, Slow Rider
Oddometer: 501
David 2005 KTM 640A 2008 Wee-Strom |
08-09-2012, 09:13 PM
#7328 |
KTM Tragic
You guys are awesome!
It's great to have a family like you blokes, answers in minutes!
08-10-2012, 08:47 PM
#7329 |
tallabanian
Oddometer: 162
anyone in ontario interested in a sequoia rack from tci
https://tciproductsusa.com/index.php...fdd73dedf31b9e looking for 150.00 and will include the ktm top case and all hardware its black few scratches nothing major Im putting hard cases on makes soft saddle bags a pleasure. just where I park i need a little more security picture here 2nd post http://www.advrider.com/forums/showt...35110&page=470
640 adventure rack for sale http://www.advrider.com/forums/showp...1&postcount=23 Gregidy screwed with this post 08-10-2012 at 09:11 PM |
08-11-2012, 03:36 AM
#7330 |
Oddometer: 893
Just putting my bike ( 625 SXC ) back together after a rebuild , thought I'd look at the jetting 41 mm carb , previous owner has put a 190 main jet in it , Std is 165 , Ive thrown a 175 that came in my JD jetting kit even thou kit said to run the 170 at sea level airbox snorkle off .
Be ok ?? |
08-11-2012, 06:10 AM
#7331 |
KTM Tragic
625SXC Speedometer
hi guys, my speedomter buttons are unresponsive. The display is stuck on the tripmeter view and I can't scroll between modes. Have tried taking the face off the unit and pushing the buttons behind and still no joy. Any suggestions?
08-11-2012, 01:01 PM
#7332 |
slave to gravity
new battery?
08-11-2012, 01:21 PM
#7333 | |
Traveler
Oddometer: 4,069
This worked for me. http://advrider.com/forums/showthrea...trument+lights bill
'02 KTM 640 Adventure-lowered "On the road there are no special cases." Cormack McCarthy-The Crossing The faster it goes the faster it breaks. And high performance=high maintenance. Bill Shockley |
08-11-2012, 02:54 PM
#7334 |
viertaKTMotor *****
Oddometer: 159
My buttons were non-responsive too. If it is the new version of didplay - orange - you have two choices - get the tripmaster switch, connect it and you have your functionality back. Other posssibility is to carefully open the unit, and resolder new microswitches into the board.
08-13-2012, 06:37 PM
#7335 |
Oddometer: 470
OK guys, help maybe?
03 640a, 13k miles, no smog stuff, but stock carb, engine, fuel. My bike is doing a weird fuel thing again at around 185mi left in the tank. I am puzzled by this. It runs like it's cutting out on fuel, but never stops. Not on reserve, probably still 2-3 gallons left (usually when I fill I'm filling 4-4.5gal, tank holds 7.4 or so). I've read about hiccuping, but it does not seem to be like that (maybe it is). Not sure why it'd always come around the same mileage if it was. Anyway, the bike does cut in/out for a bit, if I just stay rolling it will go away, and tends to be helped a bit if I do a left hand turn (maybe that's just my psychological thing). If I come to a stop the bike will die during this and be a bitch to restart (usually waiting a few min works). Here's a theory - tell me if it makes sense... Bike is getting good fuel when the pressure in the tank can help the weak ass fuel pump. When the gas gets lower in the tank, the pump is more on it's own and doesn't keep up so well (I believe it's about carb level in the tank when it does this). The part I don't get is that it doesn't just stop working, it will work again. My easy solution is just fill up when I'm about 175mi into a tank, but I'd prefer to ride with only about 5 in there max to not be so heavy. It's a lot more nimble off-road when it's not full. Do I just pony up and replace the pump or is something else out there?
'03 ktm 640a |
