Old 08-25-2012, 08:51 PM   #7366
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 869
Possible Purchase
OK, I defer to all the smarter people here. Have a chance to buy an 03 640, 21k, Scotts steering, cases, everything reported to be in good shape and bike looks clean!! Asking is $4099, what say you?
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is offline   Reply With Quote
Old 08-25-2012, 11:07 PM   #7367
bmwktmbill
Traveler
Oddometer: 5,140
I would but it might need a waterpump and cam follower rebuildASAP, check the sprockets and chain and tires, IS THE OIL CLEAN, or does it look like chocolate milk?
All the engines are noisey, arrive early and see how it starts cold, ask about the battery.
Buy it anyway, what cases...Touratechs are worth a grand.
b
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 08-26-2012, 01:02 AM   #7368
mudmaps
Aussie World Traveller
mudmaps's Avatar
Oddometer: 156
I would have thought $4099 was cheap, even for the US. Great bike, great model. I'd buy another.
mudmaps is offline   Reply With Quote
Old 08-26-2012, 05:24 AM   #7369
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,498
does anyone here know how many needle bearings are in a cam roller? We've found 14 so far, does it make sense to replace both of them?
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 08-26-2012, 05:46 AM   #7370
Tseta
Lost
Tseta's Avatar
Oddometer: 672
http://www.advrider.com/forums/showp...&postcount=163
I took a closer look at the camshaft area and was able to pull those pieces. This is good news, sort of... I now have about 12 of the needles accounted for. I counted that a new intake roller has 16 needles. The corner of the roller mounting tab is almost a perfect fit onto the rocker arm. This means that it has not rattled around inside the engine for very long, and conversely, there isn't much metal flakes in circulation from that.
-T
Tseta is offline   Reply With Quote
Old 08-26-2012, 06:22 AM   #7371
Alik
viertaKTMotor *****
Oddometer: 260
Originally Posted by Tseta View Post
Ditto:
(Source: http://www.advrider.com/forums/showthread.php?t=399867)
Alik is offline   Reply With Quote
Old 08-26-2012, 08:52 AM   #7372
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,498
thanks guys, Tseta, excellent thread you put up from your rebuild. It didn't look like the exhaust roller pin wanted to come out easily? I'll look at it again when I go back to the shop, it would definitely make it cheaper. Reading your thread makes me want to look at doing a little porting and polishing while it's open, a little polishing at the very least. Time is an issue though as I'm hoping to be getting out on a trip in a few weeks
Beerthief
Old 08-26-2012, 09:01 AM   #7373
Alik
viertaKTMotor *****
Oddometer: 260
The pin roller presses pretty easy in and out if you use vice and some proper size metric sockets like a press. Eventually You can use a Dremmel rotary to cautiously "open" the "flat" edges of the old pin. But I guess press out is not longer your problem if you have to collect the pin rollers from inside of the engine. :)
Old 08-26-2012, 09:11 AM   #7374
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,498
I was thinking that maybe I should replace the exhaust side now too?
Beerthief
Old 08-26-2012, 10:52 AM   #7375
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
When I did both of mine, they pressed in and out very easy using sockets and a vice. Peened then with a centre punch. I also did the water pump at the same. They did provide one wrong bearing with my pump parts, but I wasn't too worried about using one of the old ones. If you don't have some already, get yourself some anaerobic sealant. Loctite 518, Permatex Flange sealant, or Würth Flange sealant. I have experience with the latter 2, and all three are anaerobic, and have sealed everything from KTM rocker boxes to VW split engine cases.
You can also avoid this yucky mess, since it requires so little, and doesn't dry until everything is bolt down tight.
Kind of a chicken/ egg situation, but if it only dries with the lack of O2, why doesn't it harden in the tube
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod screwed with this post 08-26-2012 at 10:58 AM
B-Rod is offline   Reply With Quote
Old 08-26-2012, 01:43 PM   #7376
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,498
Ok, I get you. I think I'll order two new ones and give a try to press out the other one tomorrow. I definitely don't want to forget anything and have to order twice. That and a new countershaft sprocket seal.
Beerthief
Old 08-26-2012, 03:57 PM   #7377
Fulano
Scooter Trash
Fulano's Avatar
Oddometer: 424
I rebuilt my water pump and replaced both cams as preventive maintenance at 25k miles. Have slightly over 30k now and going strong.
Been to Spain, Maine and Spokane. Jumped rope, smoked dope, farted, fucked and fought round the world, twice. Hell, I've even seen goats fuck in the market place, but I've never seen shit like this!
All I need are loose shoes, tight pussy and a warm place to shit.
Fulano is offline   Reply With Quote
Old 08-26-2012, 03:59 PM   #7378
Fulano
Scooter Trash
Fulano's Avatar
Oddometer: 424
Tars
By the by, has anyone fitted a 120x80 rear on the beast before? Got one sitting around and I am to cheap to let it go to waste
Old 08-26-2012, 04:07 PM   #7379
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,498
good thought, what's involved in a water pump rebuild?
Beerthief
Old 08-26-2012, 04:35 PM   #7380
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 1,964
Looking at the fiche, 2 bearings, 2 o-rings, a seal, and the cover gasket. Here is a guide that I used.
Times are GMT -7.   It's 10:41 AM.
