Old 09-12-2012, 06:25 AM   #7456
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Originally Posted by dirty_sanchez View Post
Get somebody to lend a hand to spot you so the meter reader doesn't find a dead, but very oily body next month with a KTM laying on top of him.
Dirty
fixed...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 09-12-2012, 08:01 AM   #7457
MCLARDIE
Oddometer: 58
Originally Posted by MCLARDIE View Post
Hi guys I am looking to change the speedo on my 2001 adv to the new type ones from a 2002 model has anyone done this I have the complete surround
With the speedo and the rev counter so
I am thinking it will just be the wiring
That will cause the problems
Cheers
Dave
Well that's it done changed to new style speedo
Cheers
Dave
MCLARDIE is offline   Reply With Quote
Old 09-12-2012, 05:43 PM   #7458
jon6.0
jon6.0's Avatar
Oddometer: 546
My hydraulic clutch conversion is doing weird things. In the morning it was easy to change gears and it started engaging just barely after I started releasing the lever. After a 350 mile ride today it is harder to shift into neutral when stopped and the clutch engages almost to the end of releasing the lever. I can't feel it slipping. Do you think I just need to swap out the Magura fluid? Can I really use ATF instead of Magura fluid?
On an unrelated note, I love this bike! It mountain goats up rutted out hills. The Renazco seat only started bugging me after 7 hours of my 10 hour ride. It's way under sprung for my 285 pounds. The Scott's steering damper is worth it's weight in gold.
2013 KTM 690 Duke w/ performance cam, airbox, and Akrapovic full system. 300lbs and 74.5rwhp
2011 KTM 250XC with lots of protection stuff for when I bounce it down a hill.
jon6.0 is offline   Reply With Quote
Old 09-13-2012, 03:25 AM   #7459
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,593
sounds like maybe your clutch needs to be bled?
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 09-13-2012, 12:13 PM   #7460
ROUNDSTOCK
Oddometer: 202
dash pic
heres my dated dash pic.......steve
roundstock
ROUNDSTOCK is offline   Reply With Quote
Old 09-13-2012, 05:25 PM   #7461
NitroAcres
MotoBiggots Suck
NitroAcres's Avatar
Oddometer: 529
Tell me about that GPS, I have one that is color Lorance, fish finder sonar looks just like that one..
NitroAcres is offline   Reply With Quote
Old 09-20-2012, 05:03 AM   #7462
Tye
Oddometer: 29
Quick question for you 640 ADVers
Will the down pipe come off without removing subframe etc?
Mine has developed a couple of small holes near where it attaches to the back box (by the spring hanger)
Was going to try an repair before forking out for a new one
Do not go where the path may lead...go where there is no path and leave a trail.
Tye is offline   Reply With Quote
Old 09-20-2012, 08:05 AM   #7463
smokeeater495
smokeeater495's Avatar
Oddometer: 605
I don't think you can use ATF. If I remember right the fluid is a mineral oil based. Hopefully someone else will chime in.
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 09-20-2012, 10:30 AM   #7464
Tye
Oddometer: 29
Yes its mineral oil.
I had to use standard fluid to get myself home when the piston in the lever failed.
Was told by KTM that non mineral fluid would rot the rubber seals in the clutch.
I had to bleed from clutch to lever to make sure all was remove.
Old 09-20-2012, 08:36 PM   #7465
ROUNDSTOCK
Oddometer: 202
fluid
i've used vegatable oil in a bind to make it thru the weekend!!!!!!!!!!!!!steve
roundstock
Old 09-20-2012, 08:37 PM   #7466
Droptarotter
Oddometer: 1,301
Mineral oil and ATF will work for the clutch.
When you say you used "regular" fluid, what do you mean?
If you are referring to DOT 3,4,or 5 brake fluid, then all the seals in the clutch system will need to be replaced as they will have absorbed the DOT fluid and are now swelled.
Cheers
HP2 Sport, R1200S, R100S, KTM 640 Adventure, KTM 520 EXC/Motard, Yamaha RZ350, Hodaka 125 Wombat
Droptarotter is online now   Reply With Quote
Old 09-24-2012, 09:52 AM   #7467
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,843
Hi all,
I am looking to buy fuel hose pipe for my '02 Adventure. I cant acces the bike though cause I am away from home for work at the moment... Does anybody remember the inner diameter of the fuel hose pipe? Looking to buy some quick fit coupling connectors and I was thinking to replace the pipe as well ...
Cheers...
-o0-
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 09-24-2012, 12:10 PM   #7468
TaxMan
TaxMan's Avatar
Oddometer: 122
Originally Posted by 640 Armageddon View Post
Hi all,
Cheers...
-o0-
Mine is a 5/16" fuel line and my guess is that is universal across years, but lord knows I could be wrong.
2002 Triumph Bonneville
2003 KTM 640 Adventure
TaxMan is offline   Reply With Quote
Old 09-26-2012, 01:32 PM   #7469
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,593
Motorex makes the proper mineral oil if you can find any? I wonder if Shimano disk brake mineral oil would work?
Beerthief
Old 09-27-2012, 12:14 PM   #7470
MCLARDIE
Oddometer: 58
Building a 660 internals into a 640 adv engine
Ok can anyone tell me if this has been done or can be done
I am looking to fit 660 crank rod and piston
And cam into my 640 lc4 that way I have the 660 but with
The electric start thanks for your help
Cheers
Dave
Times are GMT -7.   It's 06:18 AM.
