Old 01-23-2013, 01:47 PM   #7756
joe cool
joe cool's Avatar
Oddometer: 987
Originally Posted by Geekventure View Post
It has the mount for the 2nd caliper...must be a 2007.
From this pic it looks like this one must be running
"One more day I find myself alive
Tomorrow maybe go beneath the ground"
Garcia/Hunter
joe cool is offline   Reply With Quote
Old 01-23-2013, 02:26 PM   #7757
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,917
Best way to move the thing when it's on the center stand is to start it and rev the motor a little.
Boon Booni is online now   Reply With Quote
Old 01-23-2013, 02:54 PM   #7758
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
You made me remember when my 640A was brand new, the first time I started her to warm the engine, it was on a smooth floor, I went inside, and when I came back to the bike, she was already leaving me ... 2 meters away from the original position
'Long Life to Dirt Riders'
__________________________________________________ _______
Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
liferider is offline   Reply With Quote
Old 01-23-2013, 02:56 PM   #7759
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
As far as I know, '06 and '07 are identical.
Old 01-23-2013, 03:18 PM   #7760
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,546
'05 - '07 wasn't it?
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 01-23-2013, 03:41 PM   #7761
B-Rod
RubberNecker
B-Rod's Avatar
Oddometer: 2,001
Kind of. Liferider has it. The 2005 had different graphics on the tank, but the rest was the same. '06 and '07 look identical.
Save $5 on Smugmug by using this code. LW9ZIPzdRGzaI
B-Rod is offline   Reply With Quote
Old 01-23-2013, 08:09 PM   #7762
overlandr
Dystopist
Oddometer: 5,926
From a thread:
2003
New colour scheme silver and black
'High flow' cylinder head with 32mm exhaust valves vs. 30mm, dual curve CDI, new cam, hydraulic clutch, oil level window in primary drive cover, input shaft bearing changed from ball to roller, bigger oil filler screw on frame, oil pump drive ratios increased
Slightly different fuel plumbing, 40BST carb fitted with a TPS
Secondary air system (SAS or SLS) for "Euro 2" emmissons standard introduced to EU bikes
Different primary drive gearing (changed from 30:81 to 31:79)
Location of merge collector and elimination of separate cross-over, exhaust pipe (still high level)
Location of fuses moved to battery tray area, 10A un-switched powerlet plug in dash
More comfortable seat
Assist tab added to center stand, structural change in swingarm "arms" and chain adjuster blocks,
2004
New orange colour scheme
Low front fender
Same front suspension as 950 Adv with twin front discs, foot brake pedal wider and fold-away, wider footpegs with new rubber inserts, Front left footrest bracket made from aluminum
Black wheel rims (no longer pre-drilled for locks)
Locking fuel cap, fuel tank capacity is quoted as 25.5L rather than the 28L for the earlier models
SAS/SLS for US spec bikes
Reinforced outer clutch hub, CDI with optimised ignition curve, changed the auto decomp components but not design
2005
New oil feed line to base of piston
Smaller indicators
15mm handlebar risers
Sintered brake pads, a new Brembo brake disc with round holes
X-ring endless chain
2006
Canadian model has no SAS/SLS
Behr rims improved (do not bend as easily but still not as good as Excel)
Black powdercoated frame
overlandr is offline   Reply With Quote
Old 01-23-2013, 09:12 PM   #7763
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,666
If anyone has a line on a fairing from one of these, I'd appreciate the info. I'm picking up a 625 that I'm going to convert.
Scott - Semper Fi
'04 BMW R1150GSA, '05.5 KTM 950 Adventure
Y E T I is offline   Reply With Quote
Old 01-24-2013, 03:11 AM   #7764
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Originally Posted by overlandr View Post
From a thread:
2003
2004
Low front fender
2005
Smaller indicators
2006
Old 01-24-2013, 08:59 AM   #7765
Baja Dad
Baja Dad's Avatar
Oddometer: 2,042
send me a PM !!
I have a hook up
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 01-24-2013, 09:44 AM   #7766
Y E T I
No Talent Ass Clown
Y E T I's Avatar
Oddometer: 7,666
Originally Posted by Baja Dad View Post
send me a PM !!
I have a hook up
PM sent!
Scott - Semper Fi
Old 01-24-2013, 01:03 PM   #7767
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,598
the '06 and '07 were identical, I was told the last production run was in '06 and no new bikes were actually built in '07
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is online now   Reply With Quote
Old 01-24-2013, 02:14 PM   #7768
juames
juames's Avatar
Oddometer: 2,546
And some left overs were sold in 2008 as the "Travelers Edition".
Old 01-24-2013, 03:30 PM   #7769
liferider
Never It's enough
liferider's Avatar
Oddometer: 648
Juames, didn't know that.
I found this proof of your info: http://www.topspeed.com/motorcycles/...n-ar50633.html
About the article content... WTF, the writer was 8 years old I think...
Old 01-25-2013, 02:47 AM   #7770
Aussie Steve
Aussie Steve's Avatar
Oddometer: 1,401
660 crank
Got my engine in bits at the moment, and as you do, am looking at the 660 rallye crank.
Anyone know how complete the KTM 'crankshaft complete' is? Is it either end only or as in the picture crank with rod?
Can anyone confirm the rallye crank will go in and can keep both electric and kick start?
Aussie Steve screwed with this post 01-25-2013 at 02:54 AM Reason: add picture
Aussie Steve is offline   Reply With Quote
Times are GMT -7.   It's 09:10 AM.
