01-30-2013, 03:26 AM
#7831 |
Oddometer: 62
Amazing...
01-30-2013, 06:04 AM
#7832 | |
Oddometer: 18
Excellent work with the bracket, and good looking designing with the bashguard. It looks GREAT
01-30-2013, 06:33 AM
#7833 | ||
Oddometer: 438
There is a minimum radius of bend. If you exceed that, aluminium will crack... It also helps to bend across the draw lines of the aluminium if you know what I mean. There are many techniques from what I found later, you can heat treat is as you bend it but that depends on which series you are using... The best answer to my problem was this one: Quote:
Also, I found the hard way that it is better to get one workshop to do the job. In my case someone did the laser cutting and another did the sheet bending. They kept arguing with each other ... D.
Work like you don't need the money Live like there's no tomorrow ... |
02-01-2013, 01:09 AM
#7834 |
Location: Czech Republic (that's in between Germany&Poland!)
Oddometer: 11
Guys, I've purchased the tripmaster switch for my '07 model, it works how it is supposed to BUT I have a question.
Does the tripmaster on my model year allow you to switch the Trip 2 mode in to a large digits instead of the speed digits? I got it for my first roadbook "race", just to try it, keep the budget low but I was wondering if I can make it just more visible. Thanks!
'07 LC4 640 Adventure
02-02-2013, 12:57 AM
#7835 | |
Tyre critic
Also, IIRC if you use the big-bore Rallye piston the cases need to be replaced (or machined) because the piston bottoms into the cases. Pretty sure the details are on this site somewhere!
Cheers, Colin KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread Quote:
02-03-2013, 08:27 AM
#7836 |
problem_solvent
Oddometer: 65
Purchased a project 640 Adventure last week, that the PO had decided to part out. Picked it up just outside KC without hearing it run, and without an IMO. PO stated the machine had roughly 4500 miles, and other than a spray bombed tank and upper fairing, she looked like a low mileage example. The price was right, and came with a decent amount of spares, so the deal was struck.
Got the bike back to the workshop and had myself a decent assessment of what I'd gotten into. Lots of buttoning up, and understanding that all the case cover and valve cover gaskets had been discarded. I really needed to get this beast up and going for an enduro ride 3 days later, so against my better judgement..............liquid gaskets were made ![]() After reasonably sealing the LC4 up and reinstalling the starter, it became very apparent, that there were issues somewhere with the E-start system. After reading through several posts, I deduced a sprag assembly is the most likely culprit. So I kicked. And kicked. And swore, then kicked some more. After shredding both legs, it finally caught, started and IDLED! I live 30 minutes from the Chadwick off road vehicle area, located in the Mark Twain Nat'l forest near Springfield, MO. World class (IMO) off road riding that covers everything from wide gravel to black diamond rocky/rooted single track. Took the bike out with some friends of various skill, with the intention of riding the easier family grade trails. This lasted 15 minutes before taking a wrong turn down a moderately difficult black diamond. I typically tackle this area with a well worn 250EXC two stroker with a fair amount of struggle, so I was pretty nervous taking an unproven monster in and back out. I fell in love with this machine and its capabilities in short order. It's a twist of the throttle to tractor up and over logs, shelf rock, mud, ice covered rock, you name it. Riding down gravel at the same pace I felt comfortable on the EXC, was boring! Twist the gas and fly! I haven't been this excited about a moto purchase in a decade, and now I'm contemplating selling my Triumph Scrambler, as it now seems obsolete! Will make a better assessment after sorting out the E-start and installing factory gaskets. ![]() Brad 417moto.com
Triumph Scram, 640 Adventure, 520 EXC/Supermoto, SV650, RD350, |
02-03-2013, 09:43 AM
#7837 |
Track Addict ADV Wannabe
Welcome to the obsession...
On the road less traveled.... .... You always meet more interesting people! ______________________________________ 2003 KTM 640 Adventure 2009 Husqvarna TE 310 |
02-03-2013, 09:56 AM
#7838 | |
Adventuring Creep
'99 KTM 640 Adventure R ***************************************** East Bay Weekly Coffee ***************************************** Support your local creep! CREEPS MC |
02-03-2013, 12:52 PM
#7839 | |
problem_solvent
Oddometer: 65
Single track--check Highway use--check Loaded touring--check ish Unknown: If'n my 520 EXC Supermoto wheels fit this bike, I'll give it a shot at a track day to see if it's a viable Supermoto. I've more or less stuck the rear EXC wheel in place of the LC4 stocker, and it seemed to fit just fine. Anyone know off hand if the front will work?
02-03-2013, 02:01 PM
#7840 |
Big Bike, Slow Rider
Oddometer: 494
If the tank is the standard KTM tank (not the KTM competition tank), you should have no problems with paint or vinyl adhesion. They are the plastic that does not "breathe". Otherwise, the standard paint from KTM would be bubbling off.
Maybe the PO just covered over the beautiful paint underneath? Love to here about your experience with the 520 wheels.
David 2005 KTM 640A 2008 Wee-Strom |
02-03-2013, 02:24 PM
#7841 |
problem_solvent
Oddometer: 65
If I post a pic of the tank, can you Identify it?
02-03-2013, 02:27 PM
#7842 | |
Have Fun, Don't Die!
Oddometer: 1,835
Roaming Rally 2011Roaming Rally 2012 Roaming Rally 2013 "I don't hate people...I just feel better when they are not around." - Henry Chinaski |
02-03-2013, 04:20 PM
#7843 |
Oddometer: 494
Look on the bottom of the tank, it may have the KTM part number moulded on it. It it does, use munnracing.com to cross reference the part number.
If it is listed on the normal parts fiche, it's a standard tank and can be painted, wrapped etc. If it says it's from the KTM hard parts catalog, then it is the unpaintable one. On my 2005 640A, when you look inside the filler cap, the tank is a white(ish) colour. My tank from the hard parts catalog is orange the whole way through (and translucent). (Yes I have both tanks and swap them depending on the ride).
02-03-2013, 04:52 PM
#7844 |
problem_solvent
Oddometer: 65
The clear solution then, is to trade me your hard parts tank, for this one. Seems equitable.
02-03-2013, 05:12 PM
#7845 | |
Oddometer: 494
![]() The shipping to Australia would make it cheaper for you to buy a new tank! The real reason I bought the hard parts tank is on the later models, the tank capacity was reduced and sometimes I need all the range I can get. Also, I ride like shit (fall off a lot), so I prefer scratching the hard parts tank than the super expensive original.
