Old 02-04-2013, 11:52 AM   #7861
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,610
Originally Posted by Earthscape View Post
The year 2000 models came from the factory with the side stand tab on the frame. As far as I know, no other years had this. I have a 99 that I put the DualStar kit on, which required welding a tab to the frame. The picture could be a 2000 converted to USD forks - the footpegs, engine, fuel pump look correct for that year, but the tank and front end do not - or it could be a different year with a welded-on tab.
I quote from a previous post ....
''its a complete 950 front suspension , wheel , discs , calipers, master cylinder etc , with 640 yoks . changed the brake lines so i could fit the high front mudguard, the fork protectors are from an 85cc ex . the full cost of everything was somewhere around £500. the exhuast is an akropovic full titainium non road legal race system and carb has been jetted etc its like night and day from standard lol .''
He also says somewhere that the color is the normal one that the 2000 bikes came with...
Very clean bike indeed ...
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is online now   Reply With Quote
Old 02-04-2013, 12:31 PM   #7862
DaddyBigDaddy
AKA -Evel Kneilson
DaddyBigDaddy's Avatar
Location: Liberal ShitHole, San Fran-sissyco, Kalee-Fornee-a
Oddometer: 303
Ktm
The 1998 620 Rally Adventure has the frame kickstand mount too
DaddyBigDaddy
1998 KTM 620 Adventure
2007 KTM 950 SE
2008 KTM 530 EXC
2004 KTM 450
DaddyBigDaddy is offline   Reply With Quote
Old 02-04-2013, 02:59 PM   #7863
rjf
SBS's #1 fan in January
rjf's Avatar
Location: Gosford, NSW, Aust. Scrambler, 640Adv, 300EXC
Oddometer: 4,376
Originally Posted by philosobrad View Post
And that's all I'm replacing on mine, using this SKF part for $9.18
http://www.rockauto.com/dbphp/x,cata...SKF_19993.html
Watch when reading through the how to...................I don't think using the crankshaft locking bolt method is a great idea for holding the flywheel when tightening things back up.
After I read the correct thread on the starter clutch (with guide already done), thats what I'll be doing too.
In Aust the sprag is -
Reference:7
Part number:584 40 026 000
Description:B2 FREE-WHEEL FWD 332008 BLS
Retail Price:125.65
Central Coast ADVenture bike training courses and 1 on 1 lessons - For details Click HERE
Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadslide, thoroughly used up, totally worn out and loudly proclaiming- WOW-WHAT A RIDE!
rjf is offline   Reply With Quote
Old 02-04-2013, 03:00 PM   #7864
LeglessOne
Baiter of OldDog
LeglessOne's Avatar
Oddometer: 2,330
Originally Posted by rjf View Post
Cheers Lego, I think there maybe pullers and stuff packed away at work somewhere.
The one you need is P/N 58012009000
I never find a place where I can stay
I'd rather be a thousand miles away.
LeglessOne is offline   Reply With Quote
Old 02-04-2013, 03:10 PM   #7865
rjf
rjf's Avatar
Oddometer: 4,376
Part number:58012009000
Description:B2 FLYWHEEL EXTRACTOR
Retail Price:63.55
Cheers mate, I'll see if I can borrow one locally first, if not I'll pm ya about borrowing yours.
I'm becoming a cheepskate in my old age, I'd much rather get it sorted for $10 and a borrowed puller instead of encouraging KTM AUST's pricing by giving them $190 odd for for a starter clutch and puller.
Old 02-04-2013, 03:22 PM   #7866
tileman
tileman's Avatar
Oddometer: 870
Originally Posted by 640 Armageddon View Post
It should be ok tileman. The KTM disk is also a semi-floating disk and the one you have should be semi floating. Full floating disks are not present any more, mainly due to the noise they were doing. The rivets, on the new one, have spring washers in them,
In any case modifiyng the caliper in that area will not cause any problems but make sure you are gentle with it and if you have a thin disc cutter, use that. If the modification was near the bolts then it may have been a problem...
Let us know how it goes and take some photos
In the end I gave up and sold the disc with the motomaster setup I had to a fellow inmate. The standard disc will be find for my use, it was just bling really, but hey, I like a bit of that sometimes !!!!
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 02-04-2013, 06:55 PM   #7867
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,179
In a pinch, the spring from your fork seal work also, that's what's in mine.
Michael
AES Racing - Crow Canyon Riding Park
mgorman is offline   Reply With Quote
Old 02-04-2013, 06:57 PM   #7868
mgorman
Crashing since 1964
mgorman's Avatar
Oddometer: 5,179
This cheap skate found one for $29 on ebay
Michael
Old 02-04-2013, 09:25 PM   #7869
Low594
Adventuring Creep
Low594's Avatar
Oddometer: 1,130
Can you link to this bike thread, I'd like to look thru it!
Low594 is offline   Reply With Quote
Old 02-05-2013, 07:45 AM   #7870
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,408
FCR's?
I stumbled on a thread in the vendors where a guy is selling a bunch of FCR carbs cheap if you're looking to swap out the BST. (no affiliation with the vendor)
http://www.advrider.com/forums/showthread.php?t=816973
2005 KTM 950 Adventure
Roaming Rally 2011RR2012 RR2013 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 02-05-2013, 08:06 AM   #7871
640 Armageddon
-oo-
Oddometer: 2,610
Originally Posted by juames View Post
I stumbled on a thread in the vendors where a guy was selling a bunch of FCR carbs cheap if you're looking to swap out the BST. (no affiliation with the vendor)
Old 02-05-2013, 08:08 AM   #7872
juames
juames's Avatar
Oddometer: 2,408
Was? Are they all gone?
Old 02-05-2013, 08:12 AM   #7873
640 Armageddon
-oo-
Oddometer: 2,610
Originally Posted by mknight View Post
Thanks for all the interest guys. I think this thread kind of got resurrected, but most of the good stuff is gone. I don't have any of the carbs available. They are all sold.
The thread started back in August 2012. He had 18 carbs approximately. So From August.... ehm.... 6 months. 3 carbs per month
Old 02-05-2013, 08:30 AM   #7874
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,530
All the carbs are sold - vendor posted a notice last night to that effect.
Old 02-05-2013, 08:30 AM   #7875
MCLARDIE
Oddometer: 54
Originally Posted by tileman View Post
Is the rear end in the attach pic a factory rally part or something that appeared on only certain models?
Hi that is my mates bike,he bought it new in 2000 and still has it today
it was the first 640 adv in scotland ,it has been changed quite alot, that is a ktm 950 adv front end
cheers
dave
MCLARDIE is offline   Reply With Quote
Times are GMT -7.   It's 02:11 AM.
