Old 05-18-2013, 12:21 AM   #8071
Baggi'tard
Assventure rider
Baggi'tard's Avatar
Oddometer: 784
Originally Posted by warewolf View Post
Hey what was involved in welding those radiator mounts back on? How much did you have to strip from the bike?
obviously seat/tank, and then had to remove the adventure tank frame, which mounts to the front four radiator mounts. removed the rear radiator screws just so I could push the radiators out of the way. Getting to the radiator mount bolts with the plastic guards and the tank frame in the way was a f-in pain. don't think I'm putting those plastic guards back on cuz they just seem to collect dirt and leaves and pine needles, and you can't reach in there and clean them out.
The Tellico Adventure Trail and Tellico Farmhouse Inn Loops
"Welcome to Tennessee, the patron state of shootin' stuff." Bob Lee Swagger.
KTM 640E, KTM Duke II, Ducati Multistrada 1100S
Baggi'tard is offline   Reply With Quote
Old 05-18-2013, 02:57 AM   #8072
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,527
Thanks Baggi.
Cheers,
Colin
KTM LC4 640 Question? Check here first --> KTM LC4 (640) Index Thread
The Stable
warewolf is offline   Reply With Quote
Old 05-18-2013, 05:23 AM   #8073
warewolf
Tyre critic
warewolf's Avatar
Oddometer: 2,527
Another question: is yours an oil-in-frame job? If so, did you drain the oil?
Cheers,
Colin
The Stable
Old 05-19-2013, 12:05 AM   #8074
Baggi'tard
Assventure rider
Baggi'tard's Avatar
Oddometer: 784
yes, and no. We talked about it, they welded onto a sheet that was already welded onto the tube, they used a "cooler" method MIG or TIG I think, and it was so short of contact anyway, there was no way that oil and frame didn't just suck all that heat right up. I think you'd have to be a ham-handed welder to burn through.
Old 05-20-2013, 09:46 PM   #8075
gjcarving
Oddometer: 99
Riser Question.
Hello, I just picked up a New to me 06' 640 Adventure. I am 6'4'' and the bars are definitely too low for me. I am thinking of some ROX or the like 2 inch risers to put the bars forward and up. Can anyone tell me if they have something similar, and if a 2 inch rise will work with all the stock cables. Thanks!
gjcarving is online now   Reply With Quote
Old 05-20-2013, 09:58 PM   #8076
dnrobertson
Big Bike, Slow Rider
Oddometer: 794
I had the stock cables (except for the decomp, get an earlier model decomp cable (I think about 2000)) with the ROX and a Stenhouse under bar mount for the Scott steering damper. It's tight and I had to alter the positioning of the cables and wiring.
David
2005 KTM 640A
2008 Wee-Strom
dnrobertson is offline   Reply With Quote
Old 05-20-2013, 10:05 PM   #8077
jrozar
jrozar's Avatar
Oddometer: 618
Does anyone know where I can get a rear led taillight for my 06 640 A?
jrozar
Las Vegas NV
www.my2wheels.com
jrozar is offline   Reply With Quote
Old 05-21-2013, 08:59 AM   #8078
wvrocks
wvrocks's Avatar
Oddometer: 601
I've got 2" Rox risers on my 2000 Adv with no real issues. Had to route the decomp cable between the risers to so it didn't catch on the upper
triple clamp pinch bolts. I'm about 6'4" as well and the reach to the bar is very comfortable with the risers and Tusk Chub fat bars. Not sure which bend they are since the previous owner put them on. I also have Protaper low pegs mounted so that may affect my position from stock too.
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 05-21-2013, 09:13 AM   #8079
mxchamp
Registered Lurker
mxchamp's Avatar
Location: The corn state,11 curves in 318 miles (Iafalls IA)
Oddometer: 1,520
GJ
I too am 6'4" and like the others I run the 2" Rox risers with the Stenhouse risers as well. With the stock handlebars.
The throttle cables will stick when you turn, solve that by putting the cables below your mirror mount. Or in front of as your sitting on the bike.
As for the decomp cable I had mine lengthend by my local KTM dealer:
Motosports in Des Moines Iowa.
Talk to Doug the owner, he will get you squared away.
Ride safe!!!!
2014 KTM 690 Enduro
Encouraging Serious Horseplay!
mxchamp is offline   Reply With Quote
Old 05-21-2013, 09:16 AM   #8080
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,428
You looking for just an LED bulb, or a whole tail light assembly?
Queen of Spades has what seems like a really nice and bright LED bulb here..
LINK
Don't know nothing about an entire assembly though.
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Boon Booni is online now   Reply With Quote
Old 05-21-2013, 03:03 PM   #8081
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,425
I found mine cracked about 50K km back, took off the rads, cleaned up the area & stuck em back on with the stick welder with the bike laid over. They have cracked again I just noticed, so I'm going to fix at the next service - will gusset them up a bit too now I have a TIG. I think one of the LC4 regulars (Tseta? Laramie?) put up a few pics of strengthening up these mounts some time back.
Bring yours up with some beer & we'll do both at once
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 05-21-2013, 09:21 PM   #8082
gjcarving
Oddometer: 99
Thanks! Sounds like ROX are the way to go. Also sounds like you didn't need a new decomp just a re-route which would be nice. Would you mind telling me more about the Protaper lower pegs and where I can get them? I have not come across these. Thank You!
Old 05-21-2013, 09:31 PM   #8083
jrozar
jrozar's Avatar
Oddometer: 618
I'm looking for the full assembly, KLR's and other bikes have the full assemblies someone must make one for the lc4 bikes.
LINK
jrozar
Las Vegas NV
www.my2wheels.com
Old 05-21-2013, 09:37 PM   #8084
gjcarving
Oddometer: 99
Originally Posted by mxchamp View Post
GJ
Thanks for all the tips with the throttle cables. I am somewhat new to wrenching on bikes and can hopefully figure it all out. Again, sounds like ROX are the way to go. But, can't believe you use the Stenhouse combo with it also. I am hoping I don't have to deal with a longer de comp cable as hopefully I can reroute them. If not though, Hope I can find a place like you did. The dealer here sucks. Thanks again for all your help!
Old 05-21-2013, 09:40 PM   #8085
gjcarving
Oddometer: 99
Thanks for the info! I am thinking of going with just the ROX 2 inch, so hopefully won't need a new decomp cable. If so though, it sounds like the earlier model cables are longer? Again, thanks for the help. I have 2 months to fully set this bike up for me for the RMAR rides in CO.
Times are GMT -7.   It's 11:34 AM.
