Old 06-07-2013, 03:23 PM   #8116
Baja Dad
Baja Dad's Avatar
Oddometer: 1,952
Originally Posted by Emmbeedee View Post
The Kijiji ad doesn't say if it's running but $5000 for an 01 seems a bit high. It is pretty, though.
The Bike is worth what the BUY wants to pay!!!
the Bike is very cleen
I woluld give him $ 4000 if it was in Calif, Nv or AZ
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad screwed with this post 06-07-2013 at 11:46 PM
Baja Dad is online now   Reply With Quote
Old 06-09-2013, 08:35 PM   #8117
singletrak
singletrak's Avatar
Oddometer: 72
I just got an 06 Adventure today. The bike has scratches on each side of the tank, typical spot on the edge of tank. Any tips to hiding the road rash?
I see pictures of the carbon fiber guards, who makes them?
Are tank guards like the ones used on the 950 Adventure available? Where can I get them?
Any other tips for new owner?
Singletrak
singletrak is offline   Reply With Quote
Old 06-09-2013, 11:35 PM   #8118
bmwktmbill
Traveler
Oddometer: 5,048
Singletrak
Single,
I had the local upholstery shop add leather to the corners of my tank.
It has held up well and was glued into place.
Check the pinned threads for 640 advice.
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 06-10-2013, 06:27 AM   #8119
wvrocks
wvrocks's Avatar
Oddometer: 601
Singletrak
You can get the carbon/kevlar guards here: http://www.advrider.com/forums/showthread.php?t=868271
Never underestimate the power of stupid people in large groups.
wvrocks is offline   Reply With Quote
Old 06-10-2013, 11:50 PM   #8120
bmwktmbill
Traveler
Oddometer: 5,048
Originally Posted by gjcarving View Post
Hello, I recently picked up and 06 Adventure and am working on getting it jetted properly for my altitude. I am at 7,000 ft, and run mostly from 4-12k in ft. Looking for anyone in high altitude areas and what you are running for jetting. I will be using the stock BST with the snorkel removed. Thanks!
With the BST40, for altitude just run stock jetting.
It was set up to run properly in the Alps.
bill
Bill Shockley
Old 06-11-2013, 05:08 PM   #8121
Earthscape
Have ya got a helmut?
Earthscape's Avatar
Oddometer: 338
Oil Filter
Anyone used the PC Racing FLO PCS1 spin-on oil filter?
Specifically, I'm wondering if that's the correct one for a 640 Adventure. There is some confusing information about what exactly it fits, as in, fits a Duke 640 and a 990 Super Duke - huh?. My 950 is the same basic engine layout as the 990, and there is no spin-on oil filter of any kind.
I actually have been using a scotts stainless spin-on for many years, and it works great, but is very difficult to get off (no nut), and more difficult than it needs to be to take apart. The PCS1 looks easier on both counts, if it's the right one.
"You do your own thing in your own time, you should be proud."
2004 KTM 950 ADV : : : : : : : 1998 Triumph Tiger
1999 KTM 640 ADV : : : : : : : 1993 Kawasaki KLX650
2007 Kawasaki KLX350S : : : : 1996 Yamaha XT350
Earthscape is offline   Reply With Quote
Old 06-11-2013, 09:43 PM   #8122
Beta450
Oddometer: 92
Sight glass part number
My 2002 KTM 640 sight glass is spraying out oil. I can't find the part number for the sight glass on any of the online part finders?
Beta450 is offline   Reply With Quote
Old 06-11-2013, 09:48 PM   #8123
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,422
This is what I come up with for the stator side cover..
58430095100
Unless you've got a site glass on the left side of the motor, then you've got a clutch cover from a newer bike.
Where the fuck...
Where the fuck is the bike?
You gotta be shitting me.
Where the fuck is the road?
Old 06-11-2013, 10:12 PM   #8124
Beta450
Oddometer: 92
Wow, that was fast. Thanks Boob Booni I will try to order one tonight.
Old 06-12-2013, 07:33 PM   #8125
singletrak
singletrak's Avatar
Oddometer: 72
Still checking out my new to me 06 Adventure... It looks like I have a small oil leak right above exhaust/head area. I have not pulled the tank yet to check it out. Is this a common leak area? Rocker arm cover? Possible other leak areas?
Singletrak
Old 06-12-2013, 08:44 PM   #8126
RENCRN8
RENCRN8's Avatar
Oddometer: 253
My 2002 for sale
http://advrider.com/forums/showthread.php?t=895310
RENCRN8 is offline   Reply With Quote
Old 06-12-2013, 09:10 PM   #8127
Casejeep
Casejeep's Avatar
Oddometer: 736
My new to me 06
Casejeep is offline   Reply With Quote
Old 06-12-2013, 09:23 PM   #8128
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,887
Singletrak
An easy fix. The exhaust stud on the left side of the head is threaded all the way into the wet part. Pull that stud and apply some 5770 Loctite thread sealant on the threads and reinsert. Presto chango-the fix is done.
The other place is at the counter sprocket-an easy fix, the other two places are on the rocker arm shafts as they exit the head above the spark plug.
Counter Shaft-replace the O-ring and pick up a few more as spares for the clutch slave.
The easy way to address the rocker arm shaft seep is to run a bead of an oxime cure (sensor safe...important it says this on the tube) RTV on the end of the shafts. The more in-depth and correct fix is to replace the O-Rings.
Dirty
No, really, the mustache means I love you.
dirty_sanchez is offline   Reply With Quote
Old 06-13-2013, 08:51 AM   #8129
mtbdemon
mtbdemon's Avatar
Oddometer: 971
Vibration
I have the first year 640 (Actually a 620) and on long rides, my hands REALLY buzz when first off the bike. I have anti vib mounted in the bars, but I seem to remember a post sometime ago on foam rallye grips? Does anyone know anything abut these and where I might find them? Thanks!
Ken
I am a leaf on the wind, watch me.....ride (I know, it makes no sense)
2007 YZ 250F SOLD
1998 KTM 620 Adventure
2004 KTM 200 EXC
mtbdemon is offline   Reply With Quote
Old 06-13-2013, 09:05 AM   #8130
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,422
So, has anyone successfully replaced the shift shaft seal without splitting the cases? Mine's got a slow drip. I've clean and then replaced the v-seal that rides against the shift lever and cleaned the area behind it as well as possible with silicon spray.
On my bike it looks to me like the seal is cocked in the bore and that a suitably small puller could reach in there and grab it out.
Where the fuck...
Times are GMT -7.   It's 05:58 PM.
