Old 06-13-2013, 10:21 AM   #8131
Baja Dad
Baja Dad's Avatar
Oddometer: 1,973
Originally Posted by mtbdemon View Post
I have the first year 640 (Actually a 620) and on long rides, my hands REALLY buzz when first off the bike. I have anti vib mounted in the bars, but I seem to remember a post sometime ago on foam rallye grips? Does anyone know anything abut these and where I might find them? Thanks!
Ken
$12.00
http://www.touratech-usa.com/Store/4...rips-BMW-G450X
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 06-13-2013, 11:41 AM   #8132
bigboyxl
bigboyxl's Avatar
Oddometer: 326
Originally Posted by bigboyxl View Post
hey guys
since I'm going to the Nordkapp in 3 weeks and then proceeding to far-north Russia I was considering to put heated grips on my 640A. I've already chosen the Symtec heated grip kit to use with my beloved PROGRIP 786 foam grips...
Never used those heaters, but read some good stuff about them. Are they really good?
Also wanted to fix the clutch lever sensor for starting the bike not only in neutral position of gearbox, it wasn't working since the day 1 I bought the bike from previous owner. Returning the gearbox to the neutral position sometimes becomes annoying and since I will do all that stuff on handlebars I decided to change the handlebars, cause they are not narrow any more and suffered a lot for last years
I can get Easton EXP handlebars with some discount but I don't know which will fit 640A... any help with that?
bump bump
KTM LC4 640 Adventure 2006 KTM 530 EXC 2011
KTM LC8 1190 Adventure
www.alburmoto.com
Nomada panniers, Holan crashbars, Remus silencers etc. Worldwide shipping. Better deals for ADVriders
bigboyxl is offline   Reply With Quote
Old 06-13-2013, 02:54 PM   #8133
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
bump bump
I've fitted Symtech grip heaters to 3 different bikes now & we really like them. I find the 2 heat levels to work well for me. Insulate under the clutch side one with adhesive lined heatshrink. Only issue over many miles of use has been the plastic rocker switch that came with the 1st set which crapped out - get the metal toggle switch.
Check the wiring to the clutch lever sensor too - this is more likely to be the issue than the sensor itself in my experience.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 06-13-2013, 05:54 PM   #8134
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,392
hey guys i could use a hand. this is a shameless request for your vote!
i'm trying to win a new intake system for my 990 and need some votes. please go to this THREAD and vote for me. all you have to do is make a post and vote for my member name.
thanks,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 06-14-2013, 06:14 AM   #8135
endurists
endurists's Avatar
Oddometer: 59
Lc4
Hi AdvRiders :)
Here is my fathers 98 Adv R.
And my son helping him to repair bike
Could You help a bit, to get this thing run properly:
as I alreday wrote on ktmtalk:
It's very problematic to start after winter, last year everything was OK:
a) fueal is fresh
b) new spark plug - NGK D8EA
c) changeg spark plug
d) carburetor is Dell'Orto PHM40SD, disassembled an cleaned few times - there everything must be OK
e) valves OK, and no air leak.
Is there common stator problems to LC4 as RFS have? I'm thinking that spark is too week!
and is possible to start bike only with kick and without choke, if turns choke on running bike it dies immediatelly. When it's running - runs and idles well at 1700 rpm.
Feels there is no fuel in float chamber. If sqiurts right in it or squirt in inlet tract bike starts good with kick.
Any sugestions?
Kalvis, Latvia
endurists is offline   Reply With Quote
Old 06-14-2013, 08:31 AM   #8136
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,183
Originally Posted by endurists View Post
Hi AdvRiders :)
a) fueal is fresh
Any sugestions?
Kalvis, Latvia
A lot of starting issues like your having can be chalked up to a poor battery... If the battery is good then the next thing I would look at is your starter sprague clutch, is it slipping and not giving the engine the proper spin when the E-start button is pressed...
You mentioned that you cleaned the carb, did you make sure the pilot circuit under the pilot jet is clear? If there is a clog in the passageway itself the bike will not run correctly at low revs...
640 A x 2
BC RIDING 2014
gunnerbuck is offline   Reply With Quote
Old 06-14-2013, 08:49 AM   #8137
fastdadio
Still gettin faster
fastdadio's Avatar
Oddometer: 2,106
Starts without choke?
But runs well after warm? Sounds too rich. Check float height.
fastdadio is offline   Reply With Quote
Old 06-14-2013, 06:37 PM   #8138
tdreyer
KTiM
tdreyer's Avatar
Oddometer: 503
thanks,
laramie
Bumping this back to the top. Let's hook him up!
~Tim
"04625 SXC
'04 625 SMC 76,xxx mi.
'97 CR500 Sold
tdreyer is offline   Reply With Quote
Old 06-14-2013, 08:18 PM   #8139
bmwktmbill
Traveler
Oddometer: 5,108
bump bump
Big box,
Another bump for your Easton bar question. I don't know the answer.
For the heated gtips, never used a heater system with foam grips, always used hard rubber type grips.
So I will ask, is anyone using foam grips with grip heaters?
bill
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 06-15-2013, 01:18 AM   #8140
mcguyver
mcguyver's Avatar
Oddometer: 1,270
Rear brake caliper
The inner face (alloy) on my rear brake caliper has worn due to the pad vibrating against it over time. (Possible due to worn brake pad retaining pin as well)
This causes the pads to wear on an angle and wear out prematurely.
Bike has done 60000klms.
Any one know of a reasonably priced aftermarket caliper?
Ignore the dirt, but tis pic shows whati mean.
mcguyver screwed with this post 06-15-2013 at 01:30 AM
mcguyver is offline   Reply With Quote
Old 06-15-2013, 02:06 AM   #8141
sir phily
sir phily's Avatar
Oddometer: 356
Originally Posted by bmwktmbill View Post
Big box,
bill
Hi there guys i have used grip heaters with my foam grips with no problems at all, I love the rally foam grips on my 640 have used them for years can't fault them also help's to stop my hands going numb.
Cheers Phil
sir phily is offline   Reply With Quote
Old 06-15-2013, 07:48 AM   #8142
bigboyxl
bigboyxl's Avatar
Oddometer: 326
Originally Posted by Baja Dad View Post
these are Progrip 786 Foam Rally grips, my favourite
http://lnx.progrip.com/site/product/786-foam
www.alburmoto.com
Old 06-15-2013, 07:50 AM   #8143
bigboyxl
bigboyxl's Avatar
Oddometer: 326
Cheers Phil
Great info, because I had some concerns about this combination and was afraid that foam grips can work as insulator
thanks Phil!
www.alburmoto.com
Old 06-15-2013, 10:35 AM   #8144
TripleThreat719
Track Addict ADV Wannabe
TripleThreat719's Avatar
Oddometer: 282
Bike prep is almost done for the UTBDR Trip...
Pivot Pegz
Rekluse Clutch
Dunlop D908 Rally Raid tires
New Chain and Sprockets...
Now I just need to pack! So ready to get going!
On the road less traveled....
.... You always meet more interesting people!
______________________________________
Coming Soon... 2004 BMW R 1150 RT; Gone Soon... 2009 Husqvarna TE 310; Gone, but fondly remembered... 2003 KTM 640 Adventure
TripleThreat719 is offline   Reply With Quote
Old 06-15-2013, 12:04 PM   #8145
Gregidy
tallabanian
Gregidy's Avatar
Oddometer: 162
time to sell my beloved 640
http://ontario.kijiji.ca/c-ViewAd?Ad...wmid=494821427
thought id let yall see 1st
640 adventure rack for sale
http://www.advrider.com/forums/showp...1&postcount=23
Gregidy is offline   Reply With Quote
Times are GMT -7.   It's 10:31 PM.
