Old 08-05-2013, 06:36 AM   #8266
Dirty3
Just add sauce
Dirty3's Avatar
Oddometer: 153
Originally Posted by bmwktmbill View Post
D3,
Nice machine and welcome tothe madhouse.
bill
Cheers Bill
Looking forward to it!!
Dirty3 is offline   Reply With Quote
Old 08-06-2013, 08:40 AM   #8267
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,260
Originally Posted by ChrisC View Post
Meaty.. you big sissy
Ego protecting the Id -standard practice.
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 08-07-2013, 05:26 AM   #8268
wvrocks
wvrocks's Avatar
Oddometer: 628
Originally Posted by Boon Booni View Post
Mine would howl each and every time I got in the rear when speeds were below 20ish.
After zip tieing all of the rear spoke intersections, she'll howl only every nice in a while and not nearly as loud.
The front doesn't make any noise, but the front wheel was replaced on recall to the much stronger setup.
The zip ties just about got rid of all the squeal when braking. Much nicer. Also found a loose spoke while I was cleaning them so that was good.
Never underestimate the power of stupid people in large groups.
wvrocks is online now   Reply With Quote
Old 08-07-2013, 05:50 AM   #8269
TowPro
Lets ride
Oddometer: 3,299
I will be dealing with the rear squeal this weekend.
I am starting with a new set of pads (my current ones are vintage 2000, as the bike only has 2200 miles on it).
I plan to use that automotive gook you put on the back of the new pads that acts like an isolator (if there is enough room).
then we will see if I need zip ties.
TowPro is online now   Reply With Quote
Old 08-07-2013, 06:16 AM   #8270
wvrocks
wvrocks's Avatar
Oddometer: 628
Mine has newer pads with about 1000 miles on them. Nothing on the back of the pads.
Old 08-07-2013, 06:26 PM   #8271
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,597
Any thoughts as to why a new countershaft sprocket seal would still want to weep some oil now that my clutch is finally fixed?
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 08-07-2013, 06:59 PM   #8272
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,964
Did the previous seal wear a groove in the sprocket or shaft?
Old 08-07-2013, 07:54 PM   #8273
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,352
It's a 2 part repair, you have the seal which lasts a long time and the o-ring which should be replaced every time you change the countershaft sprocket...
If you only replaced the seal and not the o-ring then it is likely that the o-ring is what was leaking...
gunnerbuck is offline   Reply With Quote
Old 08-07-2013, 10:00 PM   #8274
in-trim
Finding my Way
in-trim's Avatar
Oddometer: 23
DEcomPRESSED
Howdy folks,,, About 5 months ago I got a 2003 640A with 24k on it from another inmate. It wasn't the cleanest nor dirtiest bike out there, but it felt like a good runner and had worked on suspension.
I've got decompression issues described in more length on this thread,
http://advrider.com/forums/showthread.php?t=910080.
Short questions,,, if the lobe to the manual decompression lever isn't touching rocker arm for exhaust valves and has full/smooth range of motion, so basically isn't working,,, is there a fix besides parts replacement?
Besides the clack sound or doing a compression check,,, is pulling the head and manually inspecting auto decomp on the cam the only other way to verify its functioning properly?
Thank you all for the info you've poured into this forum,,, and whatever help you might give me?
Cheers!
in-trim is offline   Reply With Quote
Old 08-08-2013, 12:17 AM   #8275
Hockeygod
Hockeygod's Avatar
Oddometer: 740
Dirt Tricks KTM LC4 Dome Washer
Don't know if this is a solution, but have you seen this and might it work? Has anyone used it? If so, thoughts? I was thinking about ordering one for $25.
http://dirttricks.com/shop/dirt-tricks-ktm-dome-washer
Dean
2007 KTM 640 Adventure
2001 KX 100
1989 KDX 200
Various mountain and road bikes
No his mind is not for rent
To any god or government
Always hopeful, yet discontent
He knows changes aren't permanent
But change is...
Hockeygod is offline   Reply With Quote
Old 08-08-2013, 07:19 AM   #8276
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,597
Both good pieces of information and I can't remember if I changed that o-ring or not? Now the challenge would be to pull the new seal without destroying it to replace the 0-ring?
gunner are you familiar with this Dirt Tricks product for the LC4?
Beerthief
Old 08-08-2013, 07:51 AM   #8277
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,352
Hi Mike,
You don't need to pull the seal to replace the o-ring, just slide the metal bushing out and use a pic or make a hook out of a piece of wire to grab the o-ring... Make sure you get all the pieces as sometimes the o-ring breaks up... Make sure you put the cupped side of the bushing inward against the o-ring...
With the old spring washer should be replaced, but I sometimes reuse them... What I do is set the washer into a large socket {1 1/4"} and then peen it by using a ball peen hammer head for the punch and hitting it with a second hammer... This usually takes only one whack to add the required bit of side tension to the spring washer...
gunnerbuck screwed with this post 08-08-2013 at 07:58 AM
Old 08-10-2013, 08:02 PM   #8278
straight_8
SM rims for KTM wanted
straight_8's Avatar
Oddometer: 74
New owner (for the second time)
My new 07 next to my well used 02.
Current Bikes:
12 Ossa 280i Factory
02 640 Adventure (Airbox, carb, exhaust modded)
07 Gas Gas ec300 (street legal, scott damper)
straight_8 is offline   Reply With Quote
Old 08-11-2013, 10:33 AM   #8279
singletrak
singletrak's Avatar
Oddometer: 73
My Hi Beam headlight does not work even after replacing the bulb. The Low Beam works, the running light works .. but the Hi beam does not work. I suppose I could have gotten a bad bulb? Anything else I may be missing?
Singletrak
singletrak is offline   Reply With Quote
Old 08-11-2013, 11:00 AM   #8280
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,964
Do a continuity test on the bulb and if it's good, use a voltmeter to see if there's power in the connecter to the bulb. Just keep tracing the wiring back from the bulb to the hi/lo switch, then back farther if necessary and you'll eventually find the problem.
Times are GMT -7.   It's 06:57 AM.
