Old 11-18-2013, 11:45 PM   #8371
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Originally Posted by Lornce View Post
Thanks, Gunnerbuck.
The successful mileage you've seen with your 640adv has prompted me to look for one of my own.
The bike is still running well with that old piston bouncing around in there... I'm near 172,000km now and it uses zero oil, my is plan to renew the piston at the 200,000 mark...
gunnerbuck is offline   Reply With Quote
Old 11-19-2013, 04:05 AM   #8372
hajoktejnSI
hajoktejnSI's Avatar
Oddometer: 73
Thumb
Respect man. I know a lot of bikers that haven't made so many km in their 10 or so years of riding ...
hajoktejnSI is offline   Reply With Quote
Old 11-19-2013, 04:25 AM   #8373
Dirty3
Just add sauce
Dirty3's Avatar
Oddometer: 153
Adjustable rear brake lever
Hi all,
I have been searching threads for anyone that has fitted or knows where one can get an adjustable rear brake lever. Does it exist or is it a mod i have to make myself.
I have large feet and thought it may be worth trying longer length level. Also same with gear shift lever, especially when standing.
Dirty3 is offline   Reply With Quote
Old 11-19-2013, 07:21 AM   #8374
my6
my6's Avatar
Oddometer: 380
447lbs
Sent from my Nexus 4 using Tapatalk
Check your Six
04/625 SXC
98/200/MXC
my6 is offline   Reply With Quote
Old 11-19-2013, 07:42 AM   #8375
Dirtstar1
Human torpedo
Oddometer: 121
Originally Posted by my6 View Post
447lbs
Is that your all up weight with tools and bags?
I'll do mine next week when I get my giant loop.
Dirtstar1 is offline   Reply With Quote
Old 11-19-2013, 07:45 AM   #8376
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,198
Good stuff.
Have you replaced the rings, valves or valve guides during that time?
Old 11-19-2013, 08:10 AM   #8377
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,296
Good stuff.
The current rings have 45,000 kms on them, same goes for the valves... I usually do a valve service at 40,000 km intervals, but this time I am just going to keep running them until they produce symptoms of been worn... Clintz ran his valves to 90,000 km before they were serviced so they will go a fair ways and Clintz does not baby his bike...
My bike also does not have an easy life, it has done a lot of luggage loaded 2 up riding, spent a lot of time on rough trails and gravel tracks...
I am a pre-emptive servicer as to where I like to replace stuff before they are worn out... I will usually do an in depth service every 2nd winter at around 40,000 KM intervals... At this time I'll inspect the all the engine bearings that are visible without pulling the motor for wear... At 127K I found that one bearing on the countershaft showed excessive wear so I decided to tear the whole engine down as outlined in this thread: http://advrider.com/forums/showthread.php?t=632893
Old 11-19-2013, 09:41 AM   #8378
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,247
Originally Posted by Dirty3 View Post
Hi all,
Nothing here?
http://advrider.com/forums/showthread.php?t=86958
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 11-19-2013, 01:57 PM   #8379
Pokey66C23
Oddometer: 484
WP Extreme 50mm Forks
I just picked up a set of low miles, (6500 mostly street use), WP 50mm forks. They came off of an Enduro, they're going on a 2001 640 Enduro.
I don't want to re-invent the wheel. I'm looking for the straight poop on servicing them for a 160 lb rider. Anyone have links to the service manual for these forks? Thanks.
Pokey66C23 is offline   Reply With Quote
Old 11-19-2013, 08:29 PM   #8380
hajoktejnSI
Oddometer: 73
http://husaberg.org/wiki/index.php?t...ont_suspension
Old 11-20-2013, 01:52 AM   #8381
Dirty3
Just add sauce
Dirty3's Avatar
Oddometer: 153
Originally Posted by meat popsicle View Post
I tried this section and found 2 threads but no real answers.
I see you can buy say from TT the lever extension but it really only widens the lever from the original folding one. What i'd like to do is extend the length.
Old 11-20-2013, 10:03 AM   #8382
meat popsicle
Ignostic
Oddometer: 14,247
sounds like custom fabrication, unless you get lucky and find one from another bike that fits the shaft and the shape of the engine... I think you should start a thread on that so you get more attention.
Old 11-20-2013, 03:23 PM   #8383
Umarth
Umarth's Avatar
Location: Tramping arround the world for a bit with Big O
Oddometer: 372
55,000km old...
Here it is posing in Colombia a few weeks back, on it's way to Terra del Fuego...
Umarth is offline   Reply With Quote
Old 11-20-2013, 09:51 PM   #8384
supercoyote
Oddometer: 94
More pictures please!
There's only one rule that I know of, babies - God damn it, you've got to be kind.
supercoyote is offline   Reply With Quote
Old 11-21-2013, 05:55 AM   #8385
meat popsicle
Ignostic
Oddometer: 14,247
Originally Posted by Earthscape View Post
Second, the connector for "empty battery" starting. This is from my owner's handbook that came with the bike. It's a '99, I have no idea if later models are the same. I know electrical components were some of the things that DID change on later models, but I don't know exactly what changed. I would guess that the reason for the existence of this connector wouldn't have changed. Based on what the manual says, I'm second guessing my memory that more than just the headlight is turned off when this is disconnected - it's been too long since I tried it, I just don't remember.
*** EDIT ***
I realized the wire was long enough to pull it out and get a picture, so here it is in real life.
Hope this stuff is helpful.
You made me check my 03 manual - they dropped this nice bit - I was wondering for a bit if I didn't read my manual carefully... I can check my bike next time I have the dash off for others, but I did rewire the headlights to get adequate power to them and now have a similar connection for connecting a battery charger, which I could use to disconnect the headlights.
Times are GMT -7.   It's 09:00 AM.
