Old 02-05-2005, 10:24 AM   #1021
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
Originally Posted by boejangles
Coming over to the loud side are ya?
Another anti-social, snausage fingered, rat bastard, Akra flashin' POS. Saving grace?... best KTM seats ever. Scofflaw dodges another bullet.
So... how's tricks?
creeper is offline   Reply With Quote
Old 02-05-2005, 11:03 AM   #1022
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,744
Go back to your "I have nothing better to do/ I need a life/ please be my friend and tell me what color I should paint my bike and what do you think THREAD!
Renazco is offline   Reply With Quote
Old 02-05-2005, 11:30 AM   #1023
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Hey...be nice, or Creep will kick you in your good knee...
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-05-2005, 11:49 AM   #1024
creeper OP
Still alive...
creeper's Avatar
Oddometer: 10,718
please be my friend
I got enough "frends"... what I really need are some creative enemies.
So... how's tricks?
Old 02-05-2005, 11:52 AM   #1025
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
Making the semi-safe assumption that 2005 will be the same as '03 - '04 here...
1. Main jet... from 152.5 to 157.5 - 162.5... dependant on other variables.
2. Needle clip from #3 to #4 position
3. Slide vacuum ports... drill to .110 - .125", or 3mm
4. Leave the pilot air and fuel jets alone for now. Doesn't seem to be an issue on '03 and later.
5. Mixture screw... adjust idle speed to 1800 RPM on a hot bike, adjust mixture screw to provide fastest idle (usually no more than 1/2 turn in or out), then readjust idle speed to 1600 +/- 50.
Thazit,
Creep
So if 157.5 is a little rich at 7k is there something like a 155.5? that would be ideal for 5k?
I have ridden fuels injected bikes for so long am I gonna have a problem going from 5k to sea level?
The 152.5 will just get worse, leaner, the lower I go correct? I dont wanna be running lean in Baja in April...
Surly
I pray that you dont look at me
I pray I dont look back...
Where is Surly?
Surly is offline   Reply With Quote
Old 02-05-2005, 12:24 PM   #1026
Renazco
Renazco's Avatar
Oddometer: 4,744
I got a good knee??
Old 02-05-2005, 12:28 PM   #1027
Renazco
Renazco's Avatar
Oddometer: 4,744
You know I love you Pimp dog
Old 02-05-2005, 03:32 PM   #1028
Mack
Gone, but never forgotten. RIP, Mack...
Mack's Avatar
Oddometer: 3,797
I have run seal level jetting, that we arrived at on a dyno with a ega, it seemed about perfect. Well this same jetting has been run from 4000ft to 8000ft, and it worked fine, I changed out one full step, and didn't even notice a difference. (It only takes 5 minutes max to swap the main through the bowl screw.)
Österreichische Motorräder und deutsche Autos. Wie wundervoll kann das Leben sein
Mack screwed with this post 02-05-2005 at 03:51 PM Reason: Changed out one full step, on one day to see if going a main jet leaner would help at the higher elevations, no diff.
Mack is offline   Reply With Quote
Old 02-05-2005, 03:41 PM   #1029
Buckster
Buckster's Avatar
Oddometer: 1,003
Duely noted.
Buckster is offline   Reply With Quote
Old 02-05-2005, 04:44 PM   #1030
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
this is all contingent on keeping the holy BST
FCR runnin' heathens must use a slide ruler to compute jetting changes as the temperature swings 10 degrees or the altitude changes 10 feet
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-05-2005, 05:38 PM   #1031
Surly
surly adventurer
Surly's Avatar
Oddometer: 2,131
At sea level you had the best AFR with the 157.5, correct?
I have a wideband O2 that I think they make an adapter for the tailpipe for tuning bikes. I could try that out and see what I get here at 4-5k. Though I am no pro tuner, I just have it for the car.
Jets cant be that expensive so I guess that I could buy a couple (155.5, 157.5) and probably wont need anything richer if you had a 157.5 at sea level.
Surly
Where is Surly?
Old 02-05-2005, 05:43 PM   #1032
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
BST! ( ) jets come in steps of 2.5, so stock is 152.5, then 155, 157.5.....and so on....
CC
Chris
1943 BSA M20WD
Old 02-05-2005, 05:55 PM   #1033
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
John did you get yours, in Boise? Is it in yet?
Thats where I am getting mine
I ride at 4-6k feet and am heading to sea level for Baja and like to know if I should make these changes for those altitudes also
Im getting from another dealer who is a good riding budy. I need to go to the local shop and confess my sins but they probably will have no problem selling the two they have arriving. I feel real shitty about buying from some where else but hopefully I can redem myself as soon as they find out what I usually spend each year on accessories. If they are like my wife I wont have to say anything and they can read my mind. I always try to suport the local shops.
john in idaho
mars is offline   Reply With Quote
Old 02-05-2005, 06:05 PM   #1034
mars
Starbucks anyone?
mars's Avatar
Oddometer: 1,900
I sent an email to Scott Harden and asked if there was going to be another KTM rally this year like the one in Idaho. He sent me a nice reply that there would be one in Nevada. Cool.
Its great to have sports heroes that actually communicate.
john in idaho
Old 02-05-2005, 06:12 PM   #1035
Mack
Mack's Avatar
Oddometer: 3,797
2002 - Sea Level - KTM Hardparts airbox sidescreen - SXC Supermoto silencer (Straight through, unbaffled can) yielded a 165 main, I swapped to a 160 to try that at higher alltitude, for one day out of several where I expected to see major jetting changes, and as I said noticed no difference.
Times are GMT -7.   It's 01:25 AM.
