Old 09-25-2008, 11:37 AM   #136
Hotspice
Satellites not acquired
Hotspice's Avatar
Oddometer: 5,540
Originally Posted by Mercury264
AbsoFreakinLutelyGenius.
I carry my MSR bottle in the side bag and it's an odd size that takes away from usable space.
Thanks for the idea..
Cyclenutz.com motorcycle accessories
Get a SmugMug account and use coupon code DwHE0pDRjpJfw to save yourself $5.
Hotspice is offline   Reply With Quote
Old 09-25-2008, 11:45 AM   #137
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,206
Mine are Brunton 1.0L/33.8oz bottles and it's as if the tubes were made for them - they are not quite as long as the tube but I plan on just adding a bit of packing/rags at the bottom and top to cushion the bottles.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 09-25-2008, 11:47 AM   #138
Hotspice
Hotspice's Avatar
Oddometer: 5,540
Hmmmm, enough room to use some clear "siphon" hose to take up the space ???
Old 09-25-2008, 11:58 AM   #139
Mercury264
Mercury264's Avatar
Oddometer: 22,206
Mmmm....I would think so yes
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 09-26-2008, 05:28 AM   #140
HighTechCoonass
Living the Dream....
HighTechCoonass's Avatar
Oddometer: 2,493
great idea...I bought 3 ...
one or two for the new F800gs!
one for the boat. it will work great for my boat papers...I was using a paint ball tube but it is not water tight!
NEW dash plates for your F800..here... lhttp://advrider.com/forums/showthread.php?t=1007140
HighTechCoonass is offline   Reply With Quote
Old 09-26-2008, 05:36 AM   #141
Mercury264
Mercury264's Avatar
Oddometer: 22,206
Well these tubes aren't waterproof either - the cap maybe since there's a bit of a gasket but there's also (what I assume is a drain hold which seems odd) a hole in the bottom that will need to get filled if you want it to be truly waterproof.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 09-26-2008, 04:40 PM   #142
markherman
Louisianaman
Oddometer: 187
welding rod tube
Home Depot has them in the welding dept. under skew 449020. only saw red.
markherman is offline   Reply With Quote
Old 09-26-2008, 04:43 PM   #143
KCDakar
What are we waiting for?
KCDakar's Avatar
Oddometer: 3,388
I have two on the way.
To me, the best kind of trips are the ones you planned on the way, allowed yourself to change, and maybe didn't end up where you expected. Klay
Save $5 on Smugmug by entering coupon code: GJBcMk1uLoZm6
KCDakar is offline   Reply With Quote
Old 09-27-2008, 12:41 AM   #144
isa671
blah blah blah....
isa671's Avatar
Oddometer: 263
Tool tube mounted on a 2007 R1200GS
I just mounted Agri Supply's tool tube last night on an 2007 R1200GS. The tool tube is mounted just right above the rear brake reservoir (Make sure it doesn't pinch the brake line!) located on the right side of the GS. These are the materials that I used.
  1. 2x - 1" Insulated clamps (Home Depot)
  2. 2x - 1/4" x 1-1/2" Stainless steel cap screw button - socket (Needs to be the button type so that the cap can clear the screw) (Home Depot)
  3. 6x - 1/4 Stainless steel nylon locking nuts (Home Depot)
  4. 6x - 1/4 Stainless steel flat washers (Home Depot)
  5. 2x - 1" Bicycle tubing cut in the diameter the size of the insulated clamp (Used to fill in the slight gap on the insulated clamp (Free at your local bicycle store - found mine in the trash!).
(http://www.agrisupply.com/operators-...ister/p/65728/)
Science is one cold hearted bitch with a 14 inch strap on. -Masuka (Dexter)
isa671 is offline   Reply With Quote
Old 09-27-2008, 12:50 AM   #145
isa671
blah blah blah....
isa671's Avatar
Oddometer: 263
Here's my screw / clamp set up.
isa671 screwed with this post 09-27-2008 at 02:29 AM
Old 09-27-2008, 12:35 PM   #146
wayno OP
wayno's Avatar
Oddometer: 6,778
Question
Since I hardly, maybe never carry a passenger Im thinking of mounting
mine on the Front of the Caribou/Storm IM2699 cases.
RIDE SAFE
wayno is offline   Reply With Quote
Old 10-03-2008, 07:24 AM   #147
Highcountry
Winds up buying the gas
Highcountry's Avatar
Oddometer: 515
Got around to this finally. Just a single strip of metal, drilled and tapped, mounted inside my luggage frame so there's room to put the big metal cans on when need be. In the meantime, a casual glance might make one think I've got twin pipes.
ADV relay rider: SW Colorado
Highcountry is offline   Reply With Quote
Old 10-03-2008, 09:39 AM   #148
easyman05
Oddometer: 152
Who ships them internationally? Agrisupply seems not to.
TIA
easyman05 is offline   Reply With Quote
Old 10-04-2008, 04:26 PM   #149
globalrider
Suicidal Rider
Oddometer: 15
Would like to thank Inmate WAYNO for the link to the "Tool Tube."
Ordered one immediately and worked on several ways to mount it.
Working with Inmate Station Chief, he came up with an idea how to make great tool tube mount.
The pictures below show it the best (sorry some are not focused well).
Started with 2 inch aluminum round stock 2 inches long (2" x 2"). Drilled a 1 inch hole (frame size) thru the center.
Two holes (5mm) were drilled length wise (later to be tapped for 6mm socket head bolts).
One hole drilled length wise at center (6.8mm, later to be tapped for 8mm set screw).
Then the 1 inch hole was cut in half with a cold saw (blade 0.052") creating the two halves.
The pictures tell the rest of the story....set-up, mounting, etc.
Station Chief domed the top of the round stock for a better fit (and finish).
GlobalRider
globalrider is offline   Reply With Quote
Old 10-04-2008, 04:27 PM   #150
globalrider
Suicidal Rider
Oddometer: 15
Another Picture
GlobalRider
Times are GMT -7.   It's 02:10 AM.
