Old 05-29-2009, 08:14 AM   #271
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,142
Originally Posted by HaChayalBoded
can anyone tell me what the distance is between the two mounting holes?
Eddie - I measure it as about 10.5" (hard to be more specific since they are installed on the bike)
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Mercury264 is online now   Reply With Quote
Old 05-29-2009, 11:26 AM   #272
wayno OP
wayno's Avatar
Oddometer: 6,694
Mine are off the bike and I get 10 3/8.
RIDE SAFE
"Never wrestle with a pig. You just get dirty, and the pig likes it.” George Bernard Shaw
wayno is offline   Reply With Quote
Old 05-29-2009, 12:52 PM   #273
Gravel Seeker
Thomas
Gravel Seeker's Avatar
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,982
Originally Posted by Dirty950
Sounds great did u call them or was it all arranged with mail? How much was the shipping? I live in sweden myself, have tried to search for something similar sold in sweden but no luck.
/Johan
I've been to the agri/ farm shops this side of the border and no luck here either
'01 F650 Dakar - modified as best I can
2005: Australia - 8 months/ 26.000 km (anti clockwise circle)
2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape)
Gravel Seekers.com
Hey !
It's the African ant eater ritual !
Gravel Seeker is offline   Reply With Quote
Old 06-02-2009, 11:03 AM   #274
CamelTour
Anfänger seit '65
CamelTour's Avatar
Oddometer: 46
Don't think I've seen this rack version yet.
practice what you preach
KLR 650
KLR 650
CamelTour is offline   Reply With Quote
Old 06-02-2009, 11:10 AM   #275
HBN
lostwithmike.com
HBN's Avatar
Oddometer: 11,977
That looks clean. No issues with the chain guard under suspension compression?
Lost with Mike
12' Ruckus, 01' R1150GS, 75' XL250
Old 06-02-2009, 01:39 PM   #276
usgser
Oddometer: 2,169
10 3/8"
usgser is online now   Reply With Quote
Old 06-07-2009, 05:46 PM   #277
KTMarty
KTMarty's Avatar
Oddometer: 322
Tool tube on a ktm 950
I just received my tubes and installed them on the front of my KTM 950. Not sure how well they will work here has anyone else installed them here on a 950?
Only concern is if the tubes come in contact with something they could get pushed into the tanks. I would think (hope) the zip ties would break first. May try some other methods to fasten the tubes on.
Any other concerns I may have missed?
For now In one tube I have four tire irons wrapped in a work rag and a small bottle of WD40. For trips I plan on putting in a fuel bottle in the other tube. This will keep the weight nice an low.
Here are some pic of the installation.
Marty
2010 KTM 450EXC (FSL)
06 KTM 950 Adventure (Orange)
Fire Road Closure Report
Dual Sport Tire price comarison
2008 Idaho ride
Camp Chair
KTMarty is offline   Reply With Quote
Old 06-07-2009, 07:39 PM   #278
HowlingMad
drags knuckles
HowlingMad's Avatar
Oddometer: 1,353
Anyone ever done one on a f650gs? I have yet to see one, with the exception of the PVC tube attached to the bash plate.
Looking for some ideas. Good ideas would be even better.
P.S. I like the KTM idea.
HowlingMad is offline   Reply With Quote
Old 06-07-2009, 08:54 PM   #279
Jamming
Desert RAT
Jamming's Avatar
Oddometer: 2,883
Here's mine on a Triumph 1050 Tiger. I hung em off the case mount. 1 on each side. I removed the cases so you can see it better.
2014 Victory Cross Country
2007 Triumph 1050 Tiger
WWW.Motorcyclistcafe.com
Jamming is offline   Reply With Quote
Old 06-07-2009, 10:04 PM   #280
Meles meles
Oddometer: 177
Originally Posted by bill1960
That's a tidy job but I agree it would be better if it was tucked in a bit more.
Mine arrives soon for my DRZ.
I'm wondering if cutting off the moulded mounts would allow the tube to be mounted ~1" further in without fouling the tyre under full suspension compression
One could then fabricate a bracket to hang off the same frame mounting holes that you used.
The tube could attach to the bracket using 2 good quality stainless steel hose clamps.
DR-Z400S: I used some aluminum angle and trimed the plastic brackets on the tube. This was about as far inward as I could get without the tire hitting on full compression. The nylon strap is a backup in case the plastic brackets break. Cutout in rear fender allows cap to be unscrewed.
Carb or brake cleaner will take the yellow labels off in 5 seconds.
Cheers
Phil
Meles meles is offline   Reply With Quote
Old 06-07-2009, 10:32 PM   #281
theksmith
complete n00b
Oddometer: 61
my install on my DR-Z 400 S, it came out OK i guess, but not sure if i'll keep it, it's kinda bulky looking:
theksmith is offline   Reply With Quote
Old 06-07-2009, 10:46 PM   #282
WeeBee
Roaming ADV Gnome
WeeBee's Avatar
Oddometer: 1,539
From your pics it looks like you might have clearance issues on full rear suspension compression. Are you sure about that not being a problem?
Formerly NorCalTA
WeeBee is offline   Reply With Quote
Old 06-07-2009, 11:14 PM   #283
theksmith
complete n00b
Oddometer: 61
it's all good, had the girlfriend look and even stick her hand on the tire while i jump up and down and bottomed it out, still had a 1/2" clearance... thanks!
Old 06-08-2009, 01:01 PM   #284
Gravel Seeker
Thomas
Oddometer: 3,982
You bottom out the suspension just by jumping up and down on the bike while it's static ?
Gravel Seekers.com
Hey !
Old 06-08-2009, 04:53 PM   #285
theksmith
complete n00b
Oddometer: 61
Thumb
if i put my fat 225lb ass all the way back on the rear rack and jump up and down it feels like it is ???
either way, i now also took a straight-edge just to make sure and lined up the edge of the tire and followed it up and yes there is still a 1/2" between the left edge of the tire and the end of the bolt/nuts that stick toward it, so even if the tire came all the way up and hit the fender, it would not rub the bolts.
Times are GMT -7.   It's 05:26 PM.
