Old 03-08-2010, 08:55 AM   #406
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,915
Originally Posted by Spam16v
i know i can order from there but there is a http://www.tractorsupply.com/ next to my work and was wondering if i can walk in and walk out with what i need it would be dandy.
It's called an operators manual canister. But you just tell them its a long cylinder shaped tube with a cap
HaChayalBoded is offline   Reply With Quote
Old 03-08-2010, 09:25 AM   #407
BHW
BHW's Avatar
Oddometer: 4,135
I bought mine in the store. I looked all over the tractor section, then asked someone. They ended up being over in the tool department.
2003 Aprilia Tuono
Alcohol, Tobacco and Firearms should be a convenience store, not a government agency!
BHW is offline   Reply With Quote
Old 03-09-2010, 09:52 PM   #408
ChasingTheSun
Itinerant
ChasingTheSun's Avatar
Oddometer: 61
9$ home depot. doesnt seem to have clearance on the inside of the pannier, still figuring out where i want the thing...
Photobucket
ChasingTheSun screwed with this post 03-09-2010 at 11:15 PM
ChasingTheSun is offline   Reply With Quote
Old 03-10-2010, 07:17 AM   #409
jaycommando
jaycommando's Avatar
Oddometer: 103
what kind...?
hey chasing the sun what kinda tube is that??
Jay.
Just because I stink of petrol, look like shit and still smile doesn't mean I've not been having fun!
Soldiers Do It With Their Helmets ON!!
jaycommando is offline   Reply With Quote
Old 03-10-2010, 07:46 AM   #410
Rick West
Function not Farkles
Oddometer: 1,222
Welding rod tube
KTM 990 - The only real "dual" sport in the big Adventure bike class
Rick West is offline   Reply With Quote
Old 03-10-2010, 09:40 AM   #411
ChasingTheSun
Itinerant
Oddometer: 61
What rick said, its used as a "welding rod tube." some other guys on the forum were running them, so I thought I would try it out. It seems pretty well made, and pretty waterproof. for the price i'm not sure you can beat it if you are looking for a tool tube. The only thing is...it's pretty damn big and I couldn't really see mounting it anywhere else (on my bike at least.) I'm probably going to end up putting it inside the pannier.
"My thoughts were so entirely bent upon seeing the world, that I should never settle to anything with resolution enough to go through with it."
05 BMW 1200 GS"A"
Old 03-21-2010, 12:10 PM   #412
idea man
Plate Spinner
idea man's Avatar
Oddometer: 2,513
Rocket Launcher
I hate to even put this out there but this was a little home made bodge job I did with some 2.5 and 1.75 inch PVC pipe and some zipties.
In the middle are a couple of "pipe bombs" I filled with liquids that shouldn't mix with other things. I sealed one end with plumbers epoxy and the other end just pressure sealed. On the right hand side I have a monopod but you can put just about anything inthere you want. The caps sealed up very well and the whole thing acted like a frame to mount a large Rev Pack Expedition pack on. I thought labeling the pipes would be a good idea to (maybe) asuage any concerns a border person might have with my frame.
8500 miles later the thing is still assembled in my garage in case I ever have a need for it again. Maybe on the Great Ride East.
"You know sir, there is a fine line between Badass and Dumbass." Medical Records Lady
[*]'06 1150 GSA Thread: http://www.advrider.com/forums/showthread.php?t=375824[*]'06 1150 GSA SE Registry: http://www.ericsyn.com/2006bmwr1150gsadv.html[*]Great Ride North, Alaska/Yukon '09 http://www.advrider.com/forums/showthread.php?t=494846[/LIST]
idea man is offline   Reply With Quote
Old 03-22-2010, 07:47 AM   #413
tipler
tipler's Avatar
Oddometer: 92
I have the same welding rod tube (Canadian tire). Mounted across the touratech rack with two hose clamps. That sucker can take a lot of kit!
tipler is offline   Reply With Quote
Old 03-22-2010, 11:22 AM   #414
dcwn.45
Frozen Rider
dcwn.45's Avatar
Oddometer: 757
I just swapped out the painted pvc tube on my wee (it was looking pretty trashed)
For 2 of the home depot welding rod tubes, and I had to take a dremel tool to the inside to grind down the ridges in order to put an msr fuel bottle inside.
I carry the fuel bottle in 1 and chain lube /tire levers in the other.
Maybe a rag , zip ties , spare bungee, or small bits as well.
I like the screw top, but heads up on the smaller diameter.
[my first mexico ride]
http://www.advrider.com/forums/showthread.php?t=544013
dcwn.45 is offline   Reply With Quote
Old 04-30-2010, 07:01 PM   #415
Engine698
Engine698's Avatar
Oddometer: 22
Finally, after 16 months of owning the Tool tubes...
I finally mounted them... In my living room (ahh the life of a grad student). Thanks for everyone who helped with ideas, hopefully this will help you other KLRers looking for a cheap way to mount. I will post after a few hundred miles to let you know if the exhaust side tube melted off and if the Zip ties held up.
KLR Tool Tube Full View
I relocated the tail lights with "L" brackets.
IMG_2689
IMG_2683
IMG_2684
IMG_2685
Zip ties? really? What's the over under they hold? Also, note the spacers. As a typical KLRer, I spray painted some plastic corks from cheap wine. They work great and are super durable.
KLR Tool Tube w Cross bar
I added a cross bar for extra stability for when I wreck in Mexico.
IMG_2681
'07 KLR 650
'98 KLR 650
'01 YZ 426
Engine698 is offline   Reply With Quote
Old 05-01-2010, 12:05 PM   #416
Possu
de-nOObed!
Possu's Avatar
Oddometer: 5,221
Just finished making these pannier frames for my partners DRZ, I wanted to keep the weight forwards, leaving room for a Tooltube (tyre levers etc):
I included an O'ring to secure the lid to prevent it working loose & dumping the contents, the bike's off on a trip to South America starting mid-August.
www.possu.smugmug.com
Possu is offline   Reply With Quote
Old 05-02-2010, 01:02 AM   #417
Wildman
In my castle
Wildman's Avatar
Oddometer: 18,083
Nice job Steve.
Ridden; GBR CYM DEU FRA ESP AND MCO ITA BEL SCT LUX CHE SMR LIE AUT NLD POL LTU LVA EST SWE FIN NOR DNK CZE SVK HUN ROU BGR GRC MKD SRB ALB MNE BIH HRV SVN MYS IRL BRA MAR PRT ARE USA ISL JPN MLT Planning; AUS TUR MDA UKR MEX BLR MNG RUS KAZ TJK KGZ SEN ZAF ZMB MWI NZL IND CPN
Wildman is offline   Reply With Quote
Old 05-02-2010, 01:32 PM   #418
gpracer171
Kodak Courage
gpracer171's Avatar
Oddometer: 361
larger tube
Anybody know where to find the larger diameter version of this tool tube? I would like to check out the large diameter for my f800GS.
Mike
2010 BWM F800GS
2007 Triumph Dayton 675
2013 Husqvarna Nuda
If you are not moving forward, you are falling behind...
gpracer171 is offline   Reply With Quote
Old 05-03-2010, 03:44 AM   #419
davsato
Oddometer: 799
john deere dealers have the fatter ones, and when youre there try and blag a test drive on something big green and noisy.
davsato is offline   Reply With Quote
Old 05-03-2010, 03:49 AM   #420
davsato
Oddometer: 799
nice job possu, i especially like the oil can thats very neat (at least i assume its for oil)
Times are GMT -7.   It's 11:16 AM.
