Old 06-10-2011, 07:00 PM   #511
Toompine
Toompine's Avatar
Oddometer: 111
Big thanks on that link
Toompine is offline   Reply With Quote
Old 06-10-2011, 07:09 PM   #512
AttoirRE
AttoirRE's Avatar
Oddometer: 143
Harbor Freight carries these now.
Don't know if this has been posted or not, but Harbor Freight in my area keeps these in stock now.
http://www.harborfreight.com/welding...per-46477.html
AttoirRE is offline   Reply With Quote
Old 06-11-2011, 02:30 PM   #513
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 7,915
anyone happen to crack or ruin their tool tube? friend of mine is missing the cap from his and needs another.
HaChayalBoded is offline   Reply With Quote
Old 06-11-2011, 06:35 PM   #514
mac inger
mac inger's Avatar
Oddometer: 667
Damn,..your friend must be really broke to not be able to afford a new one altogether...
And im the one with a KLR
mac inger is offline   Reply With Quote
Old 06-11-2011, 10:58 PM   #515
donny662
donny662's Avatar
Oddometer: 373
The shipping for the cap will probably be nearly as much as a brand new tube.
Calvin: I think people worry too much about the little things. All they do is make themselves unhappy that way. Why get an ulcer over things that don't really matter?
Hobbes: Like that book report you're supposed to be writing now on the book you haven't read?
Calvin: Exactly. Case in point.
donny662 is offline   Reply With Quote
Old 06-12-2011, 09:13 PM   #516
Toompine
Toompine's Avatar
Oddometer: 111
Tractor Supply Company - like about $5 for a tube and a cap
Old 06-14-2011, 04:37 AM   #517
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Greetings,
'Sorry if this has been mentioned, but does anyone know if there's a tool tube available that has internal dimensions at least this large: 10.3" L. x 4.0" D. x 4.2" H. (26cm L. x 10cm D. x 10.7cm H.)
I'm thinking about carrying one of these:
http://www.warn.com/atv/winches/XT17_portable.shtml
ktm950se
ktm950se is offline   Reply With Quote
Old 07-15-2011, 02:40 PM   #518
marksbonneville
marksbonneville's Avatar
Oddometer: 962
Yesterday I bolted up my new tool tube and today the tabs failed so I guess the next step will be a stainless clamp, I guess I was too hard on it and thankfully I did not loose the tools. I'll probably test it next time full of powdered sugar so if I lose it the lucky person who finds it will think he struck it rich on a drug transfer gone bad.
marksbonneville is offline   Reply With Quote
Old 09-14-2011, 06:00 AM   #519
Marc - Australia
Marc - Australia's Avatar
Oddometer: 289
found one in Brisbane
I finally got around to do what everyone else is talking about... I found one of these tubes here in Australia... in a tractor shop. Thanks for all the posts here... I love this forum.
Just in case there are other inmates from Oz that are looking for this tube... contact Rob (rob[at]fieldquip.com) from Fieldquip. He was very helpful!
I used the Vario Pannier braces... works just fine..
Here are some photos.
Cheers
__________________________________
my beema's history -
Marc - Australia is offline   Reply With Quote
Old 09-14-2011, 09:11 AM   #520
Orangeshirtdude
Fight the Power Commander
Orangeshirtdude's Avatar
Oddometer: 65
It's a good thing the illustrative how-to is on the side or else I'd be completely lost!
Orangeshirtdude is offline   Reply With Quote
Old 09-14-2011, 08:27 PM   #521
SaharaJp99
Oddometer: 678
Just picked up a new to me DRZ 2 days ago and just so happened to have two of these on my tractor implements, so I took them off and modified the stock DRZ rack to mount them up. Pretty slick if I do say so myself!
Welded on bolts for the single bolt mount:
Made and welded on tabs for the dual bolt mount:
Everything all bolted up for fitment:
Just have to re-paint the rack and I should be good to go!
SaharaJp99 is offline   Reply With Quote
Old 09-14-2011, 11:37 PM   #522
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Originally Posted by ktm950se View Post
Greetings,
ktm950se
I haven't found one. If you do, please do post. I had the exact same idea as you...
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-15-2011, 12:05 AM   #523
HaChayalBoded
Brooklyn Bored
Oddometer: 7,915
Greetings,
ktm950se
Here ya go. It'll fit a 2L bottle of fuel (originally a bottle of Pepsi) perfectly, oddly enough, it will NOT fit a 2L bottle of coke. It's maybe 2mm thicker. The Pepsi bottle is such a perfect fit that you put it in and it takes a few seconds for it to come down while expelling the air. If you leave the bottle in there while going through mountains and it expands you sometimes have to open the bottle to release pressure so you can pull it out of the tube.
Old 09-16-2011, 04:02 PM   #524
Afry
Why hike?
Afry's Avatar
Oddometer: 611
Originally Posted by mrprez View Post
Best idea yet but if you use the Jegs part number #289-33279it's a cleaner install.
The #289-33273 is for lap joints and one half is slightly larger then the other half. #289-33279 is for a butt joint and no place to trap dirt etc.
Afry is offline   Reply With Quote
Old 09-17-2011, 05:57 AM   #525
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Great finds from both HaChayalBoded and Afry!
ktm950se
Times are GMT -7.   It's 10:55 PM.
