Old 09-15-2011, 12:05 AM   #526
HaChayalBoded
Brooklyn Bored
HaChayalBoded's Avatar
Oddometer: 6,733
Send a message via AIM to HaChayalBoded
Originally Posted by ktm950se View Post
Greetings,
'Sorry if this has been mentioned, but does anyone know if there's a tool tube available that has internal dimensions at least this large: 10.3" L. x 4.0" D. x 4.2" H. (26cm L. x 10cm D. x 10.7cm H.)
I'm thinking about carrying one of these:
http://www.warn.com/atv/winches/XT17_portable.shtml
ktm950se
Here ya go. It'll fit a 2L bottle of fuel (originally a bottle of Pepsi) perfectly, oddly enough, it will NOT fit a 2L bottle of coke. It's maybe 2mm thicker. The Pepsi bottle is such a perfect fit that you put it in and it takes a few seconds for it to come down while expelling the air. If you leave the bottle in there while going through mountains and it expands you sometimes have to open the bottle to release pressure so you can pull it out of the tube.
Eddie
Stuff FS
'00 Harley MT 500
'93 Concours, extreme farkle (for sale)
'00 Shadow ACE Tourer (for sale)
'03 Shadow Sabre (Gone)
'90 Honda Hawk GT NT650 (Gone)
Lookin' for a (cheap) '95 GSPD Classic
I've been stranded in the combat zone
I walked through Bedford Stuy alone
Even rode my motorcycle in the rain!
HaChayalBoded is offline   Reply With Quote
Old 09-16-2011, 04:02 PM   #527
Afry
Why hike?
Afry's Avatar
Oddometer: 328
Originally Posted by mrprez View Post
Best idea yet but if you use the Jegs part number #289-33279it's a cleaner install.
The #289-33273 is for lap joints and one half is slightly larger then the other half. #289-33279 is for a butt joint and no place to trap dirt etc.
Afry is offline   Reply With Quote
Old 09-17-2011, 05:57 AM   #528
ktm950se
ktm950se's Avatar
Oddometer: 1,385
Great finds from both HaChayalBoded and Afry!
ktm950se
ktm950se is offline   Reply With Quote
Old 01-23-2012, 11:28 PM   #529
Eemo
Oddometer: 6
Cool2
My 1200 GSA setup
No extra modifications made
Eemo is offline   Reply With Quote
Old 01-24-2012, 12:38 PM   #530
Casejeep
Casejeep's Avatar
Oddometer: 726
this is myset up on my f800
Casejeep is offline   Reply With Quote
Old 01-24-2012, 12:40 PM   #531
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 20,421
Looks good Love the para-cord idea...stealing that
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 01-24-2012, 12:45 PM   #532
Cabrito
Terminal Lurker
Cabrito's Avatar
Oddometer: 100
I like how you did this right here. Let us know how they hold up.
The Bags on your bike look like they've gotten some good use!
Michael G in SF | 00 KLR650
Cabrito is offline   Reply With Quote
Old 02-01-2012, 03:57 PM   #533
Airjunky
Oddometer: 25
Originally Posted by Peirre O`Bollox View Post
you don`t know the item/part# for it do you?
Sears or Harbor Freight sells one too.
Airjunky screwed with this post 02-01-2012 at 04:21 PM
Airjunky is online now   Reply With Quote
Old 02-18-2012, 12:38 PM   #534
Shimie
Oddometer: 6
Hi, I just installed two tubes in my R1150GS.
Regards.
Shimie is offline   Reply With Quote
Old 02-18-2012, 05:59 PM   #535
Snowbound
Oddometer: 599
I can't see your pictures . OK I see them now ,No panniers ?
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is online now   Reply With Quote
Old 04-14-2012, 03:04 AM   #536
klondike1
Nobody in particular
klondike1's Avatar
Oddometer: 392
http://www.advrider.com/forums/showt...=681075&page=2
Post 20 shows what i had come up with. I had a different attachment after this that was much neater. This was just the beta test. Took them off this year and went with the pelican case 1170 mounted on the inside and works well but bit of a bugger to get at. (post 38) Not that i want/need to be getting at it on a regular basis.
Were all here because were not all there!
2009 BMW R1200GSA(Grey Boy)
2007 BMW F800ST(Blue Boy)
www.danieljenkins.ca
klondike1 is offline   Reply With Quote
Old 04-14-2012, 06:25 PM   #537
KYwoodsrider
KYwoodsrider's Avatar
Oddometer: 205
3" PVC with 2 test caps on each end. Mounting brackets made from some 1" aluminum angle
KYwoodsrider is offline   Reply With Quote
Old 04-19-2012, 12:19 PM   #538
Hubbman
Hubbman's Avatar
Oddometer: 515
Mounting Question???
I'm about to do exactly the same procedure on my GS and I'm wondering if you could have mounted the tube on the other side of the frame without it interfering with the rear wheel travel?
I would like to keep the tube out of sight as much as possible.
BTW, brilliant use of the Vario mounting brackets which I have gathering dust in my scrap cabinet!
Thanks for posting!
Originally Posted by Marc - Australia View Post
I finally got around to do what everyone else is talking about... I found one of these tubes here in Australia... in a tractor shop. Thanks for all the posts here... I love this forum.
Just in case there are other inmates from Oz that are looking for this tube... contact Rob (rob[at]fieldquip.com) from Fieldquip. He was very helpful!
I used the Vario Pannier braces... works just fine..
Here are some photos.
Cheers
__________________________________
Hubbman is offline   Reply With Quote
Old 04-25-2012, 12:07 PM   #539
Hubbman
Hubbman's Avatar
Oddometer: 515
Finished! Thanks!
Just copied your set up on my 2011 GS!
Really glad I found your comments, it saved me from using ugly P shaped brackets. I also painted the Vario bracket pieces flat black to match the bike and blend in with the rest of the bike!
As an FYI, I also salvaged the two large washers that were used in the stock skid plate on the lower mount point to give the mount a larger clamping area. These two washers have an integrated sleeve on the backside of the metal washer that slide inside the bracket to provide a more solid interface between the two pieces.
I'll post some pics later on to show what I mean here.
Cheers
Old 04-26-2012, 08:12 PM   #540
UnclebudinTX
UnclebudinTX's Avatar
Oddometer: 184
I have two tubes on my gs.. i lost a cap on one yesterday.. i didnt screw it on tight.... But i found it today near where i work on side of road... Soooo this weekend ill be trying figure how to "lock" the cap or "make a retainer" for the cap.. any ideas would be appreciated..
Sent from my PG06100 using Tapatalk 2
Unclebudintx
http://unclebudsadventures.blogspot.com/
2004 BMW R1150GS 2004 BMW R1150RT
1979 Kawasaki KZ1000st (sold)
1991 Harley XLHsporty 883 (sold)
UnclebudinTX is offline   Reply With Quote
Times are GMT -7.   It's 10:01 AM.
