04-27-2012, 07:28 AM
#541 | |
Anatomically Correct
Oddometer: 2,568
See the Mega Tube thread in vendors . . . . ..
Searching for the immaculate contraption |
04-27-2012, 08:25 PM
#542 |
Oddometer: 184
Well here is what i came up with as a retainer for the cap.
1/16th wirerope (cable) 14.5-16" long ![]() drilled hole in the bottom, threaded into tube ![]() drilled hole in cap, threaded cable through and attached cable ferrel ![]() and TTTTTTTTTUUUUUUUUUUUUDDDDDDDDDUUUUUUUUUUHHHHHHHHH! cable is 16" long on this one. cable is 14.5 on this one..Dosnt provide a lock but will keep cap from falling off and provide place for cap when you take it off so you wont ride off with out it.
Unclebudintx http://unclebudsadventures.blogspot.com/ 2004 BMW R1150GS 2004 BMW R1150RT1979 Kawasaki KZ1000st (sold) 1991 Harley XLHsporty 883 (sold) |
04-27-2012, 11:36 PM
#543 |
Oddometer: 337
I like that.
But, I don't see why the cable needs to go through the center of the tube, you could drill the holes at what would be the bottom of the tube so the cable doesn't need to be deformed when objects are place in the tube.
Calvin: I think people worry too much about the little things. All they do is make themselves unhappy that way. Why get an ulcer over things that don't really matter? Hobbes: Like that book report you're supposed to be writing now on the book you haven't read? Calvin: Exactly. Case in point. |
04-27-2012, 11:37 PM
#544 |
misadventurer
Oddometer: 256
Whats in the tube?
Curious, watcha puttin in the tubes? Other than tools that is.
I don't know! I don't know why I did it, I don't know why I enjoyed it, and I don't know why I'll do it again! Bart Simpson |
04-28-2012, 05:24 AM
#545 |
Dirty_Sanchez
Oddometer: 2,120
You can put your WEED in 'em.
Dirty
No, really, the mustache means I love you. '09 KTM 250SXF for Sale, take a look: http://advrider.com/forums/showthrea...7#post21410167 |
04-28-2012, 02:23 PM
#546 |
Oddometer: 184
I originally wanted to put an inner tube and tire repair stuff... but a tube wont fit, so i got some tools, some bungee straps, if you are real creative you can stuff a cargo net in there for those impulse purchases you make then realize you rode your bike to the store. I got my insurance card in there... I try to keep it lite...
04-29-2012, 03:20 PM
#547 |
Oddometer: 630
I bought a two each of the large and the small from Agrisupply to save on shipping. I used the large mounted with 5/16 U-clamps that I fashioned to fit. Round is not quite as effecient as a rectangle for my needs so I am looking for a box that will fit my sockets mounted on a rail with hex head bits on a rail inserted into the working part of the sockets . About 4''by2'' by 12''
BMWMOA ABC Pikes Peak BMW Riders 2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72 1955 CJ-5 1975 F-250 Highboy |
04-29-2012, 03:43 PM
#548 |
Oddometer: 112
I put a 1 litre fuel bottle in one and tools in the other.
2008 KLR688 |
06-11-2012, 06:57 PM
#549 |
d00b
Oddometer: 74
So what have you done with the holes in the official agri-supply operators manual tubes? I mounted them on my top case as seen below, and will be using them for fuel storage. The holes are on the mount-side, and I assume it would not be ideal for water to get in. Any reason not to seal them?
Pics: ![]() ![]() ![]() I wanted to paint them like rocket boosters, but that sounded like work. Decided on the Buell pegasus instead. Anyway, holes: sealed? Unsealed? Also, loving the reflective tape idea. |
06-12-2012, 03:41 PM
#550 |
Oddometer: 112
I siliconed mine, just to make sure.
2008 KLR688 |
06-12-2012, 09:48 PM
#551 |
d00b
Oddometer: 74
Sweet, thanks. Also, any idea if storing the fuel canisters sideways will be a bad idea? Spillage potential? This occurred to me after I had drilled and mounted them to my topbox...
06-12-2012, 09:51 PM
#552 | |
Oddometer: 49
Awesome setup! Good call on adding a dab to keep it water tight |
06-14-2012, 12:53 PM
#553 | |
Oddometer: 112
I have the brunton 1 litre bottles. No leaks in over a year.
2008 KLR688 |
06-16-2012, 12:10 PM
#554 |
Buell Not Dead
Oddometer: 13
Tool tube on an XR400
Here is my set up, welded a bracket to the subframe, used a 3.5" muffler strap, and added a cable and lock.
rouserworks |
06-17-2012, 06:21 AM
#555 |
Oddometer: 1,359
All who wander are not lost ![]() "Play hard and FLOOR IT" Stevie Ray Vaughan just remember: the only difference between genius and stupidity is genius has limits |
