12-13-2012, 07:02 PM
#586 | ||
Where we riding to?
Oddometer: 3,508
12-14-2012, 10:55 AM
#587 | |
Oddometer: 733
Hey guys, I am kind of an expert on these tubes. The mounting tabs are not made to withstand off road riding or carrying all the weight of fuel. You can grind the tabs off and attach the tubes directly to one of your frame bars with large hose clamps if you want to use it for that purpose. I am running a holiday special on these tubes and definitely have the best deal on them. You get 2 tubes shipped to your door USPS Priority insured for only $22.99 Agri Supply charges ridiculous shipping on them. Here is my group buy thread in the vendors section: http://advrider.com/forums/showthread.php?t=841622 btw: I have sold panniers and helmets in bulk on advrider before and have a great reputation so no need to worry about integrity. Thank You, Jeff
Motorcycle Accessories Business: www.journeyrider.com Central and South America (09/07-05/08)! http://www.journeyrider.net |
12-14-2012, 08:02 PM
#588 |
Oddometer: 110
I mount mine on my skid plate full of tools. Did the beginning and the end of the WABDR flawlessly. Still in one piece. The one I keep mounted yearly, not problems been on for 1 1/2 yearso far. The only one I've broke was when I crashed on it. My $.02
2008 KLR688 |
12-14-2012, 10:22 PM
#589 |
QuestionableBanterer
Oddometer: 10,529
12-15-2012, 08:05 AM
#590 |
Lost in Space
Oddometer: 486
Nice Job! I have not seen those plumbing stoppers before - that's a perfect solution.
"The memories of a man in his old age are the deeds of a man in his prime" - Pink Floyd
12-19-2012, 11:27 PM
#591 |
n00b sums it up.
Oddometer: 225
Me me me, I want one!
12-19-2012, 11:30 PM
#592 |
Location: Point Hope, Sitka & Biorka Island- all in Alaska
Oddometer: 767
2008 Klr 650- Iron Butt Association #44803 2005 Honda 150 2005 Honda 100 |
12-28-2012, 10:18 PM
#593 | |
Oddometer: 10,529
The tube is 3" PVC with a cap glued on, painted black and a pressure test plug on the other end, all available at the hardware store. The plate is the remnant of an old street sign. The clamps come from McMaster-Carr; search for cushion clamps and select the size to fit the OD of your pipe. |
01-04-2013, 11:07 AM
#594 |
Optimus Primer
Oddometer: 13,934
Nice. And it looks like you can easily remove a fair section of the plug bolt - or put a hole through it and place a small padlock to hinder hoodlums from tinkering with the wingnut.
Splitting lanes, and splitting hairs. |
02-28-2013, 05:08 AM
#595 | |
Oddometer: 473
02-28-2013, 05:21 AM
#596 |
Forever N00b
Oddometer: 1,603
CPVC grey
I used thin-walled grey CPVC. The pipe and fittings both have thinner walls so the end bulges are thinner than some I've seen. Then I replaced the big wing nut with a phillips/slotted screw. If I lose the screwdriver in the regular tool kit then any key or scrap of metal can open this.
Motorcycles are magical. Grinnin screwed with this post 02-28-2013 at 05:39 AM Reason: Replaced photo |
02-28-2013, 06:40 AM
#597 | |
Oddometer: 101
02-28-2013, 06:49 AM
#598 |
Forever N00b
Oddometer: 1,603
It holds 17" and 21" tubes, tire irons, aluminum bicycle pump, and the heavier of my tools. So I didn't want it with the other luggage.
Plumbing sizes are all nominal and a thin-walled pipe fits the same fittings as a thick-walled pipe. I.e. thin walled has a larger ID for the same named size.
Motorcycles are magical. |
