Old 09-15-2010, 03:53 PM   #136
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,451
OK CT90 guys.....
I just bought my first one. A really clean, not showroom, but a solid 7 or 8 with 860 miles. PO said it was running (but a little rough) this spring. He owned it a year, but only rode it a mile. I have not messed with it at all.
Has new air filter. Battery is toast. Gas smells old
First plan is to drain tank, clean the carb and check for spark, but........
Part of me wants to see if it will run as is.
Will these things start & run without the battery in them?
I found DR. ATV, looks like that is going to be a big help in the parts department.
Thanks,
Scott
This is SPARTA!
SCQTT is offline   Reply With Quote
Old 09-15-2010, 06:09 PM   #137
White Tenere
Look a moose
White Tenere's Avatar
Oddometer: 740
Originally Posted by SCQTT
The little mule..
White Tenere is online now   Reply With Quote
Old 09-16-2010, 02:14 PM   #138
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,408
OK CT90 guys.....
Thanks,
Scott
Actually you will toast your bulbs without the battery and the voltage delivered by the rectifier to the points will be less than adequate for running the engine smoothly. Any small 6 volt motorcycle battery will work in a pinch as long as the lights are off. I just wouldn't run it for long.
Get that bad old gas out of the carb and fuel tank and get the float bowl off and actually look at the float bowl, the float and jet orifices. Most times there will be additional problems with old gas like condensed water causing powdery aluminum corrosion and if it's been stored with old E10 gas the rubber O rings and gaskets might be eroded or worse.
Never assume with old stuff, especially with the PO saying they had it "running last year, month or spring". he's wanting to make a sale.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 09-22-2010, 12:57 PM   #139
Vuldub
Bikini Tag Removal Expert
Vuldub's Avatar
Oddometer: 35
Scott:
What year is yours? - looks like a 73 or 74?
I have a "73 by tag, but it's a late model so it's got more in common with the 74s.
Vuldub is offline   Reply With Quote
Old 09-23-2010, 07:03 AM   #140
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,451
Originally Posted by Vuldub
Scott:
The title says 72 & it was built in the spring of 72.
Looks like your headlight shell is a different color & your tail light is slightly different.
My bike has a switch for blinkers, but it did not come with them. Your front turn signals look like they were made as part of the bars.....cool! Never seen that before.
Looks like your rear sprocket is much smaller, perhaps that was the touring model made for highway use...
Maybe it was just a slightly different bike in Canada....not certain.
I do not even know when what colors were available...yellow...orange ....red?
This CT stuff is all new to me......I am a BMW & Yamaha guy!
This is SPARTA!
Old 09-24-2010, 09:58 AM   #141
RocketDog
Rocket Dog
RocketDog's Avatar
Oddometer: 70
110
My father bought this 110 new and put a total of 800 miles on it. I kept an eye on it making sure it was always garaged and fresh oil in the crankcase. The other day, he said that I should take it home with me... so I did. Love this bike! Always have...
RocketDog is offline   Reply With Quote
Old 09-24-2010, 10:19 AM   #142
White Tenere
Look a moose
Oddometer: 740
RocketDog that is super clean...
Awesome
Old 09-29-2010, 01:17 PM   #143
NatsFan
Adventure Apprentice
NatsFan's Avatar
Oddometer: 286
Very nice RocketDog! Please don't pull off with that bike attached and have a national lampoons moment!
"Once you can accept the universe as being something expanding into an infinite nothing which is something, wearing stripes with plaid is easy." Einstein
"You've got to be very careful if you don't know where you're going, because you might not get there." Berra
NatsFan is offline   Reply With Quote
Old 10-01-2010, 06:48 AM   #144
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,451
Looks like DR ATV only has black cables.
Does anyone know if Honda still offers the OE gray ones? I'd like to have it be 100% original.
This is SPARTA!
Old 10-01-2010, 06:58 AM   #145
hugemoth
hugemoth's Avatar
Oddometer: 3,032
I think DRATV has gray sleeves that fit over cables it that will work.
Old 10-02-2010, 11:10 PM   #146
WILL_S
OUTLAW POSTIE 001
WILL_S's Avatar
Oddometer: 2,328
A little offroading on the 110
being wrecked by bored and stroked posties....braaaaaaaaaap
WILL_S is offline   Reply With Quote
Old 10-07-2010, 12:11 PM   #147
Vuldub
Vuldub's Avatar
Oddometer: 35
You can paint them with light grey vinyl paint.
Old 10-07-2010, 12:14 PM   #148
Vuldub
Vuldub's Avatar
Oddometer: 35
Updated photos
Old 11-23-2010, 09:14 AM   #149
SCQTT
Zwei Kolben
SCQTT's Avatar
Oddometer: 5,451
Scott
Never found the time to work on it, just too busy.
Tossed a new & full charged battery in it and started on the third kick.
Put two shakedown miles on it, all seems fairly well.
Hopefully I will find time to pull the carb apart this winter.
Much easier to get motivated with a bike that is a known runner.
This is SPARTA!
Old 11-24-2010, 07:36 AM   #150
b00t
errrr, yes uh-huh?
b00t's Avatar
Oddometer: 325
Billy Goat CT110
A few shots of my '86 CT110 I just got. Bought with 700 miles on it for $700. No title but thanks to vermont I am not registered and plated!
This was from a few different rides. One a campout, the other a morning ride.
My Buddies CA305 - "Honda Dream"
'06 DRZ400s - JD, 3x3, Yosh and a cheese eatin' grin
'86 CT 110 "Honda Trail"
b00t is offline   Reply With Quote
Times are GMT -7.   It's 04:29 PM.
