Go Back   ADVrider > Bikes > Battle Scooters
Old 01-20-2010, 11:55 AM   #91
Bar None
IBM Retired
Bar None's Avatar
Oddometer: 5,144
hugemoth,
Very nice, I would not call it a rat bike.
Vince @ SWFL or WNC
2015 Ural cT 2012 Dong Fang DF250RTB-A
Bar None is offline   Reply With Quote
Old 01-24-2010, 03:51 PM   #92
helidude
defy gravity
Oddometer: 142
check this out!!!!
[IMG]images/statusiconCrash/post_old.gif[/IMG] 01-18-2010, 06:42 PM #12
timk519
Oddometer: 2,050
Street Bike? Scooter? You tell me -
This was the challenge:
And this is the bike:
Low-tech version of a GPS on board:
_____________
I met this guy last week...
His name is Alan Robertson, and not only did he do this "race' but he and his Daughter are doing a ride for charity to Newfoundland this summer.
Perhaps he may post the details here to interest contributions to the charity.
helidude is offline   Reply With Quote
Old 01-25-2010, 08:04 AM   #93
helidude
defy gravity
Oddometer: 142
NOTE, MODS: Please move this to proper thread location if it does not fit/belong here.
Cheers, Helidude
Pass this on to everyone you know who would like to support a good cause.
Thanks....
Allan & Julia Robertson
Cross Canada by Cub (A Great Ride For A Great Cause)
This Vintage Honda Cub will travel across Canada, from coast to coast.
Approximately 10,000 kilometres including return to Brampton!!
Help support our cause. We are doing this as a Charity Ride to raise funds for Because I Am A Girl.
Our goal is to raise $10,000 ($1 per kilometre).
For more info and to donate: www.plancanada.ca/rideforgirls
This 1967 Honda C65 Cub was ridden from Vancouver, B.C. to Timmins, Ontario in 1971 by the original owner.
After restoration in 2006, Allan Robertson rode it from Timmins to Brampton.
In July 2010, Julia Robertson will continue the quest across Canada to NFLD and back to Brampton.
Owner/Rider: Julia Robertson (18 years old)
Charity: Because I Am A Girl (A division of Plan Canada)
1-800-387-1418ext. 215
Sponsors/ Support: Classic Honda Powerhouse, Brampton
Dad (Allan Robertson) and his 1980 Honda CT110
Richard Love and his van
helidude screwed with this post 01-25-2010 at 05:31 PM
Old 01-26-2010, 03:08 AM   #94
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,907
Originally Posted by hugemoth
Here's an updated picture of the 68 CT90 rat bike. Since it's going to be used mostly off road this year I put the skid pan back on, knobby tires, and a second headlight. The Lifan 110 manual clutch engine is still running great.
Q
Where can I get one of those gas tanks?
Mr. Fisherman is offline   Reply With Quote
Old 01-26-2010, 05:23 AM   #95
hugemoth
hugemoth's Avatar
Oddometer: 3,075
The tank is from an old Honda XR100 dirt bike.
Old 01-30-2010, 07:46 AM   #96
Bladeforger
Bladeforger's Avatar
Oddometer: 116
Hey, Hugemoth:
What is the front clip from? And how do you like it?
I'm looking for candidate front clips. Looks so far like the selection is CT90, CB125, S90, CL90, and SL125.
Oh, wait! I see in another post that it's from an XR100. Did the stem bolt up fine? Not too short? (I just have the frame and rear wheel so far....)
Keith
Q
KLR650
DR350 (sold)
KLX250
"Obsolete doesn't mean a thing isn't any good--it just means they don't make it anymore" Von Dutch, May 1970
Bladeforger screwed with this post 01-30-2010 at 08:00 AM
Bladeforger is offline   Reply With Quote
Old 01-30-2010, 01:09 PM   #97
hugemoth
hugemoth's Avatar
Oddometer: 3,075
I had to add an inch or two to the stem. Otherwise it fit fine and it works very well.
BTW: I'm working on lowing the seat today because it was too high for my daughter. Had to remove the stock tank and make a bracket to hold the seat.
Q
Keith
Old 02-03-2010, 07:16 PM   #98
Bladeforger
Oddometer: 116
Q
Just add an inch or two to the stem... you make it sound soooo easy. And I know it can't be that easy. I'm sitting here puzzling out how you'd do that. Weld (or braze, silver solder) on another piece of similar tubing and cut new threads??? Cut the stem in the middle (between where the bearings fit) and add a piece there??? Either one sounds fiddly, and the result has to pass through center of the bearings. Am I missing a simple solution here?
Keith
KLR650
DR350 (sold)
KLX250
Old 02-03-2010, 07:49 PM   #99
hugemoth
hugemoth's Avatar
Oddometer: 3,075
I cut the top few inches off the original stem from the leading link forks, cut the threaded part off the XR100 stem, then welded them together with an oxy torch. I lined them up with a straight edge, tacked them in place, made a good weld, then ground it down so the bearing race would slip over. No rethreading needed. It's quite easy if you have the tools.
Q
Keith
Old 02-04-2010, 05:06 PM   #100
Bladeforger
Oddometer: 116
Q
A donor piece from the original stem... I like it! Thanks!
KLR650
DR350 (sold)
KLX250
Old 02-24-2010, 04:29 PM   #101
mac66
Quasi Adventurer
mac66's Avatar
Oddometer: 240
I don't post much but here are mine. A K1 and a K6 I bought and rebuilt 10-12 years ago.
mac66 screwed with this post 02-25-2010 at 03:57 PM
mac66 is offline   Reply With Quote
Old 02-24-2010, 05:22 PM   #102
vabrzn
vabrzn's Avatar
Oddometer: 7
I'm restoring this one my father in law gave me. It hadn't been started since 1981. It started on the third kick after the carburator was cleaned and I got rid of the 30 year old gas.
I finished the engine a few weeks ago.
"Logic will get you from point A to point B, imagination will take you everywhere"
Einstein
vabrzn is offline   Reply With Quote
Old 03-06-2010, 03:54 PM   #103
RoyB
Dartmouth, Massacusetts
Oddometer: 1,578
1971, 900 mile....Found it buried in my father-in-laws garage a couple years after he passed. Today I rebuilt the carb, new spark plug, new battery and air filter......started right up on the third kick!
I had one of these as a kid, should be fun for my grandkids to use.....
Roy B
Dartmouth, MA www.rvbprecision.com
2007 BMW K1200R Sport abs,2007 DL650 V Strom abs
2004 Honda VFR abs,2001 Moto Guzzi Rosso Mandello
1971 Honda Trail CT90
RoyB is offline   Reply With Quote
Old 03-07-2010, 08:36 PM   #104
highsierrabear
Location: North Bay area & Lake Tahoe, CA (life is good)
Oddometer: 13
Probably my favorite CT pic. Our '69 and '75 CT90s atop Ellis Peak (8100') overlooking Lake Tahoe with the moon rising.
The venerable CT. Awesome. Slow, but awesome. One day my lovely girl (who'd never owned a motorcycle before- me either), took the truck and went out and bought one ('69 K0). They multiplied till we had 4 of them. We're pretty much bicycle nuts, but seem to have accumulated 6 motorcycles as well.
The girl, on top of Mt Watson (8200'), overlooking Lake Tahoe.
See a trend here? CTs (and my girl), at Martis Peak (8550'), overlooking Lake Tahoe.
My little CT90 (with a 140cc Lifan engine), dwarfed by my girl's TW200 at an abandoned cabin near Desolation wilderness.
And last one. My CT90 (Lifan 140cc), out on the Rubicon Jeep trail, near my house. The funny thing is that jeepers wouldn't take note of the pretty blond girl on the TW200 with me, but would go nuts waving and honking and pointing that I was riding a CT90 on the Rubicon Trail.
Lots of great memories with the CTs. They were great in low range and could handle some tight twisty singletrack that would be a challenge on a bigger bike. Plus you could just lift the CT over fallen logs, etc.
highsierrabear is offline   Reply With Quote
Old 03-09-2010, 07:48 AM   #105
Otto Rax
Oddometer: 91
With any luck, cross your fingers for me, I'll bring home a CT90 this afternoon to compliment my C70 Passport and round off my fleet of Adventure Tiddlers. pics to come...
Otto Rax is offline   Reply With Quote
Times are GMT -7.   It's 08:13 PM.
