Old 08-06-2008, 02:47 AM   #16
Triwi OP
Oddometer: 42
and at your thumb
Triwi is offline   Reply With Quote
Old 08-06-2008, 02:48 AM   #17
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 509
Originally Posted by Triwi
On the go instant deactivation. No stop no delay
triwi
Nice...
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 08-06-2008, 03:32 AM   #18
mysterio
Eventually an Adventurer.
Oddometer: 985
Originally Posted by rgmax
I got tired of all that ABS button crap pretty quick.
I wired a ON/OFF rocker switch into the rear brake ABS sensor circuit. When switched off this basically causes the ABS to fault and turn off.
Now when off road I flip the switch to the OFF position the ABS stays off until I want it on again. No need to touch the factory ABS switch.
All it cost me was:
1) On/Off rocker switch
2) 2 male / 4 female wire connectors
3) about 8 feet/2.5 meters 16 ga. wire
4) 1 hour of my time
I had all this stuff lying around so it was free for me, might cost $10-$15 if you had to buy it.
The first step is to follow the glossy black wire from the rear ABS sensor pickup, you will find it ends under the seat above the rear shock.
I stripped about 40-50mm of the insulating cover off the wire leading into the female side of the connector. I cut one (doesn't matter which one ) of the wires and added wire connectors and then ran two wires along the frame rails to my switch on the dash.
When the switch is flipped OFF the signal from the rear ABS sensor is interrupted causing the system to detect a fault and turn off.
Here is a picture of the factory connector under the seat and my "splice" into it. The black stuff you see on my connectors is "liquid tape" for some additional water proofing. ( sorry, the pic could be be better, but you get the idea )
Here is a pic of the dash switch. I got this switch from Radio Shack for $3.
http://www.radioshack.com/product/in...entPage=search
To turn the ABS back on just flip the switch back to ON and restart the bike.
You could also tap into the front ABS sensor and accomplish the same thing ( speedo/odo won't work though ).
Brilliant! I'll be into this on the weekend, including the handlebar switch.
"This is the way the world ends/Not with a bang but a whimper." T.S. Elliot.
"This is the way the world ends/ Not with a whim but a banker." Paul Desmond
mysterio is offline   Reply With Quote
Old 12-01-2008, 01:20 PM   #19
viola-tor
Needs to ride!
viola-tor's Avatar
Oddometer: 2,071
So I have a question for rgmax or anyone else that's done this:
When the rocker switch is "off" does the factory ABS light still blink as an error? It'd be nice if it does, I'd like having it there reminding me to flip the switch "on" when I get back to pavement.
viola-tor is offline   Reply With Quote
Old 12-01-2008, 03:56 PM   #20
Moraflex
Moraflex's Avatar
Oddometer: 1,342
Strange thing happened this sunday. I started the bike and b4 the ABS light went out, I pressed it to deactivate it. This did not work, and I could no longer deactivate it. However, I did not turn the bike off and restart to see if it was really screwed up.
Moraflex is offline   Reply With Quote
Old 12-02-2008, 04:25 AM   #21
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 509
triwi
Request for a little update (still haven't started to put the switch on my bike ): Do you know if it generates errors that the dealer can see if he hooks the bike up to the computer?
www.roeligan.net
Old 12-02-2008, 07:30 AM   #22
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,059
Linked a wire each into both wires of rear ABS circuit at the plug under the seat. Ran them to the red handlebar switch. Now have instant off with a dab of switch. Whenever the ignition is switched on the ABS automatically resets.
triwi
By "red handlebar switch" do you mean the main switch on the right hand switch unit?
So do you replace OEM wiring into this red handlebar switch?
Sorry English is not my native language.
Old 12-02-2008, 07:55 AM   #23
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 509
No, he actually added a new pushswitch to the left hand side unit, pics are not showing anymore for some reason (on my pc )...
So in theory he fakes a shortcircuit in the sensor which disables the ABS on the fly.
Should not hurt anything but I wonder if the CDI logs errors about this...
www.roeligan.net
Old 12-02-2008, 08:01 AM   #24
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,059
Thnx Roeligan, so what is the difference with your solution?
Is it Triwi avoids cuting the OEM wires? Seems the same to me. Or is it yours doesn't produce error signals? Pls enlighten me. Cheers.
P.S. Pictures are not attached any more because we need to host them on a pay host somehow. My "masterpiece" study on slave cylinder failure is crippled. Oh! what the hell?
gefr screwed with this post 06-21-2011 at 08:41 AM
Old 12-02-2008, 08:04 AM   #25
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 509
I don't have a solution yet... But I think I will try Triwi's this winter.
But this is Triwi's:
Finally talked to Autosparky who is local Bosch and ABS expert and did the following after being initially motivated by this thread. Linked a wire each into both wires of rear ABS circuit at the plug under the seat. Ran them to the red handlebar switch. Now have instant off with a dab of switch. Whenever the ignition is switched on the ABS automatically resets. No need for a rocker type switch which has to be manually switched which is needed if you loop just one side of the circuit to the bar switch.
Have to say I did querie the sparky about apparently introducing a short circuit by doing it this way but he just smiled and said No. Before doing the 990 I alterred my 650 Dakar and have been running it for a month. Works perfectly. No ill effects whatsoever plus the bonus of automatic reset every startup.
cheers
triwi
Maybe if he sees these questions, he will post the pics again
www.roeligan.net
Old 12-02-2008, 10:25 AM   #26
Krust
Krust's Avatar
Oddometer: 63
The only difference between Triwi's version and rgmax's version is the switch. Both require cutting into the rear ABS sensor wires. Triwi's version uses a temporary interrupt button which disables the ABS as long as the bike remains on. Same as the stock button, but no 3 second holding period, and also works while the bike is moving. If you turn the bike off and turn it back on the ABS will be active again. rgmax's version uses a permanent interrupt switch which disables the ABS as long as the switch is flipped. If you turn the bike off and turn it back on the ABS will still be deactivated unless you flip the switch back before you turn the bike back on.
I prefer the permanent switch because I don't want to have to remember to turn the ABS off everytime I restart the bike offroad. ABS on dirt is SCARY. This comes with the downside of forgetting to enable the ABS on the road. Much less of an issue. I've ridden plenty of other bikes on the street without ABS.
It really comes down to personal preference. Do which ever works best for you.
2007 990 Adventure
2008 YZ250F
2003 YZ250
1999 WR400
Krust is offline   Reply With Quote
Old 12-02-2008, 11:29 AM   #27
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,999
What I did while riding off road for the weekend was just put a couple washers between the sensor and the housing onthe rear wheel. Moving the sensor away from the ring by just that small amount made the signal unreadable and the ABS was off.
To under just remove the screw and put the washers on the other side outside of the sensor and your done.
No cutting into the wiring harness and takes only couple secs to do.
The really cheap penny trick.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-02-2008, 11:41 AM   #28
DSM8
DSM8's Avatar
Oddometer: 3,999
Old 12-02-2008, 11:52 AM   #29
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 509
Then it's off permanently, and so, can not be activated again easily/fast when riding home on the road... But I like the idea for a 2 week offroad trip though
www.roeligan.net
Old 12-02-2008, 11:56 AM   #30
DSM8
DSM8's Avatar
Oddometer: 3,999
Like I said the REALLY CHEAP (Like KLR Cheap) penny tech.
Times are GMT -7.   It's 06:56 AM.
