Old 12-02-2008, 12:00 PM   #31
Moraflex
Moraflex's Avatar
Oddometer: 1,342
Originally Posted by DSM8
What I did while riding off road for the weekend was just put a couple washers between the sensor and the housing onthe rear wheel. Moving the sensor away from the ring by just that small amount made the signal unreadable and the ABS was off.
To under just remove the screw and put the washers on the other side outside of the sensor and your done.
No cutting into the wiring harness and takes only couple secs to do.
The really cheap penny trick.
Absolutely brilliant. Would I be correct in thinking that the front wheel is still ABS while the rear is not?
Moraflex is offline   Reply With Quote
Old 12-02-2008, 12:06 PM   #32
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 507
Like I said the REALLY CHEAP (Like KLR Cheap) penny tech.
Doesn't matter... I like it...
Drive 2500kms to the south of Spain, enter Marocco, put the washers in, ride 10 days offroad without thinking of deactivating the ABS all the time, enter spain again, remove washers and ride 2500kms home... cheap and certainly no malfunction...
KTM 990 Adventure (Stealth one ; 2008-), now S-d & Beta 350 RR 2013 to play with
Suzuki DL-1000 V-Strom (2004-2008) and Suzuki GSF 600 Bandit (2002-2006)
www.roeligan.net
Roeligan is offline   Reply With Quote
Old 12-02-2008, 12:06 PM   #33
Roeligan
Belgium power!!!
Roeligan's Avatar
Oddometer: 507
Don't think so....
But you can not do this with the front sensor as the cable is also used for the speedo, or am I mistaken?
www.roeligan.net
Old 12-02-2008, 01:12 PM   #34
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,953
Once the system sees an ABS fault code the system as a whole is deactivated. They are a shared circut not independent of one another.
All or nothing.
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 12-02-2008, 01:34 PM   #35
rgmax
rgmax's Avatar
Oddometer: 235
There's an even cheaper fix.
Just unplug the rear sensor wire located under the seat above the shock.....
rgmax is offline   Reply With Quote
Old 12-02-2008, 02:06 PM   #36
DSM8
DSM8's Avatar
Oddometer: 3,953
WHAT?!!
Are you freakin INSANE!!!
That doesnt even require tools...whats wrong with you!
Old 12-02-2008, 02:41 PM   #37
viatormundi
Citizen of the world
viatormundi's Avatar
Oddometer: 644
Do you have a picture of that?
And in this cheap versions, do we get an ABS warning all the time?
viatormundi is offline   Reply With Quote
Old 12-02-2008, 04:22 PM   #38
DSM8
DSM8's Avatar
Oddometer: 3,953
From what I have done on the bike the light will just remain lit that is all.
Old 12-07-2008, 11:38 AM   #39
shep532
Still a novice !!
shep532's Avatar
Oddometer: 470
Even with the 'trickier to do' switch fitted into the wiring for the rear sensor ............... the warning light stays on - but that's good because it reminds you the ABS is off.
I did the switch in the rear sensor wire a while ago. it took about 1/2 an hour to do, the switch is pretty well concealed - but comes in very handy for a day off road.
When the bike was last serviced the dealer told me I had a lot of error codes for the ABS rear sensor - but they couldn't find anything wrong ....... which means they didn't spot the extra wiring and switch ......... which probably means they didn't really look for any faults either!!
Pete
shep532 is offline   Reply With Quote
Old 12-12-2008, 01:46 PM   #40
lc8john
lc8john's Avatar
Oddometer: 535
Guess I've something useful to do if it rains this weekend!
Thanks for sharing it!
Cheers,
J.
Husaberg FS 570
lc8john is offline   Reply With Quote
Old 12-26-2008, 03:02 AM   #41
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
Thumb ABS disconnect
I've just finished the Triwi method (wired to both rear wires = short). Works a treat!
Only thing I did different was to use my high beam flasher button (you know the one you flash with your left index finger?).
Disconnected the white and green with black stripe wires from the connecting block behind the dash(these go to the switch), wired them to some figure 8 wire that goes to the abs wires under the seat. Total cost, well nothing except the wire that I already had.
Flick the flasher switch once, and the abs it off until I next restart.
Smugmug $5 discount coupon # 2ucrtCWwf7D7A
KTM Pilot is offline   Reply With Quote
Old 12-26-2008, 08:24 AM   #42
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
In the same thinking, I would suggest...
disconnecting the wires from the triangular ABS switch and connecting the new wires to this switch. That would be the most functional arrangement for the ABS switch disconnecting the system at will. How about that?
Old 12-26-2008, 08:38 AM   #43
DZL850
DZL850
DZL850's Avatar
Oddometer: 20
OK, so I am new to the 990 but I see several things I don't like about the ABS, one of them being the fact that 2/3 of my toolbox is taken up with the ABS crap. I still also am still trying to decide if I even like the ABS when I am street riding. Obviously it is no good in the dirt.
Do the rest of you guys have the ABS system mounted in your toolbox area?
Thanks,
2014 Ktm 690 Enduro
2014 KTM 300 XC-W Six Days
DZL850 is offline   Reply With Quote
Old 12-26-2008, 01:20 PM   #44
KTM Pilot
KTM Pilot's Avatar
Oddometer: 439
ABS switch
gefr - I'd guess the answer is no!
That circuit needs to be operated while stationary and for 4 seconds.
Old 12-26-2008, 02:42 PM   #45
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,003
I suggested just using the existing switch, not the OEM system.
To shortcut the rear brake sensor, the existing ABS switch could be used instead of using the flash switch. Cheers.
Times are GMT -7.   It's 06:56 PM.
