03-17-2012, 06:14 PM
#151 |
Air cooled runnin' mon
Oddometer: 6,141
So I had bad, but good news. I had removed the oil pump as I thought I needed to clear the gears while removing and installing the crank. Well, I didn't have too. I just needed to remove the gears on the crank which had to be swapped over anyway. I didn't realize you only need to remove two long bolts to get the pump off. I removed all 4 and the pump came away in pieces.
It was actually a good thing as it was somewhat scored. Weird, I've never run low on oil and pretty good about changing the oil.![]() ![]() I've got two numbers for the pump though, 26357-02B and 26357-07. I'm not sure which is right. Gotta get me a parts manual.
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
03-17-2012, 06:22 PM
#152 |
Lost In Place
Oddometer: 15,990
This is great stuff, vtwin.
Need to split the cases on my S2 to re-seal the front of the case (weeps oil at higher revs) and these photos, though different, will be useful for me. Thanks! |
03-17-2012, 06:55 PM
#153 |
Some Guy
03-17-2012, 08:47 PM
#154 |
MoTard
Oddometer: 893
better to find out now than put it back together and have problems down the road!
XR650L & DR350
My Videos: http://www.youtube.com/user/wbedient#g/u |
03-19-2012, 08:35 AM
#155 |
Oddometer: 157
03-19-2012, 07:46 PM
#156 | |
Oddometer: 6,141
Could very well be, although not much debris on the magnet.
03-19-2012, 07:47 PM
#157 | |
Oddometer: 6,141
No worries, getting a new pump instead and it should come as a complete unit. But thanks.
03-19-2012, 07:48 PM
#158 | |
Oddometer: 6,141
Exactly!
03-19-2012, 07:51 PM
#159 |
Oddometer: 6,141
Well, got ambitious after work and thought I'd work on it for an hour, turned into three!
Put the pistons onto the rods.... ![]() Book says to use new snap rings, I did. Don't want them popping out and scoring the cylinders. ![]() ![]() Now for the rings.
03-19-2012, 07:56 PM
#160 |
Oddometer: 6,141
![]() Time for the cylinder. ![]() I'm only doing one at a time, gotta break it down in chunks. Cleaned the surface with this. My adapter doesn't quite fit it. ![]() Since I've got a new honing tool, better clean up the cylinder. ![]() Not perfect, better than it was though. ![]() Surprising I couldn't get it all out. Bike wasn't using any more oil than normal and I never let it run low, weird. Wonder if it was an oiling problem?
03-19-2012, 08:03 PM
#161 |
Oddometer: 6,141
Dropping the cylinder down on the piston #1.
![]() I forgot a step that comes into play later on. ![]() Time for work on the head. ![]() I have new stem seals, may as well replace them. Seat looks a little nasty, a little grinding compound to help the valves seat. ![]() ![]() New seals, a light lapping job and back together.
03-19-2012, 08:09 PM
#162 |
Oddometer: 6,141
![]() Look! I've got a Blast now! ![]() ![]() Here's where I messed up. I was supposed to install the push rod tube first or you'll have a heck of a time getting this bolt in. I ended up cutting a cheapo allen to fit, no way was I going to take this apart just for that bolt. ![]() ![]() That sure did eat alot of time up and I still have number 2 to do. Glad it's not a Goldwing!
03-20-2012, 08:09 AM
#163 |
Has a thing 4Fungirl
Oddometer: 833
No matter how much money you have, it's only possible to drink about 35-40 beers a day. |
03-20-2012, 06:09 PM
#164 |
Oddometer: 6,141
Today I worked on cylinder #2, honed and in place.
![]() Boy I screwed up on this one. They give you a little plastic tube to go over the valve stems grooved surface so the seal can glide on without damage. In my hurry, I put one of the seals on a valve without the sleeve in place. I didn't see any debris of the seal on the lands of the valve stem and I oiled it pretty well, so I actually think I'm ok. So it was time to put on the head and install the cams.![]() You have to line up all the little dots, "V's" and lines. It was time to call it quits for the day. Do yourself a favor and check the entire box for gaskets. I thought it was missing the oil pump/cam cover gasket and the primary gasket, so I went to the local dealer since it I was nearby. Today, I found the gaskets under a supporting cardboard. Sheesh! ![]() Starting to look good though.
03-20-2012, 06:28 PM
#165 |
MoTard
Oddometer: 893
Looking really good! Keep posting this stuff, I'm sure one day I'll need it for reference!
XR650L & DR350
