Old 08-19-2011, 03:07 AM   #751
barnacle bill
Riding the River
barnacle bill's Avatar
Oddometer: 206
990 Water pump bearings
Loss of coolant and the inevitable foam gunk inside the clutch housing gave the game up for the water pump seal failure.
Fair enough, 55 thou. km's, can't last forever.
The seal and shaft were pretty shot, obviously you'd better not just change the seal and hope the shaft is ok.
Checking with Orange Crush and The Garage, yes, there was a bit of sand and crap in the seal space and particularly so inside the overflow bottle, so that wouldn't help rotating parts much. Flushed the system etc etc.
Anyway, my query is regarding the two roller races. Their inside seals were removed (from the factory) on the two inside faces and the outer race seals were intact.
Fair enough, the seal behind the water seal would assist preventing coolant entering the bearing in the case of the water pump seal failing,up to a certain extent, but why is the engine side bearing seal intact, restricting lubricant from the engine entering both bearings.
Should I pull this seal of the new race prior to reassembly? Why did the factory leave it intact?
I drink in Moderation.
Moderation is a place in my mind where I am constantly at.
barnacle bill is offline   Reply With Quote
Old 08-19-2011, 06:22 AM   #752
evildingo
On a road to no-where
evildingo's Avatar
Oddometer: 420
Originally Posted by rumguzzler View Post
Howdy all!
Fitted up the Dalby FI Filter Purge kit yesterday and it all went well. Took about 30-40 mins with the most time being getting the connectors clipped up without removing the LH tank. The small " Box" fits well in the 990 and is secured with a zip tie. It goes in the void below the battery and uses the 2 plastic prongs to attach to.
The Dalby boys have rigged it up well with correct length cables and very good instructions. ( They must be for me to get it to work! )
The instructions have some pics too that help.
So after i fitted it up I started the bike and it ran well ( Always a bonus) Once the ignition is shut off you can hear a small pump sound being the reverse flushing of the fuel for a few seconds.
My fuel filters are both about 4000kms old and historically mine tend to clag up ( mainly the tea bag) at around 5000kms , so I will update once I have done a bit over that distance.
I am doing a Kroombit Tops ride this weekend so should test it out on this ride.
Overall the service and support from Craig at Dalby Moto was awesome, as always!
I will do up a small report for the Orange Crush page, as the US guys always seem to be having issues with their pumps and filters.
Righto, take it easy all and I will report back in a while!
Matt
Does this part void warranty ?
Dalby Moto wiped me after I fitted after market cans for unrelated issue !!
found his support and service piss poor , but they still take your money !!
Lets ride
evildingo is offline   Reply With Quote
Old 08-19-2011, 08:04 AM   #753
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,252
There's more to this story?????? (My bike is there at the moment???)
FE450.
XT660R
Blakduk is offline   Reply With Quote
Old 08-20-2011, 04:01 PM   #754
blackness
more riding
blackness's Avatar
Oddometer: 117
Originally Posted by ADVJake View Post
i disagree that it's a race motor, while it was used in a race, its not race tuned as such.
the motor makes a lazy 100HP from a liter capacity when an equivalent capacity & also a twin motor from suzuki made over 125HP (TL1000)
The LC8 is a well made overbuilt mill, it can make people think its an high strung racey high maintenance motor by how it runs, but this isn't the case.
Disconnect the plug under the seat to change the ignition timing and it'll run on the crappiest fuel in the world just like a DR650
Did KTM set this up from factory, or have people found this to work in a pinch.
blackness is offline   Reply With Quote
Old 08-20-2011, 08:06 PM   #755
barnacle bill
Riding the River
Oddometer: 206
It's in the Owners Manual
Old 08-20-2011, 09:38 PM   #756
shank
Shank950
shank's Avatar
Oddometer: 837
Originally Posted by emil55 View Post
I've been using Automotive Armatures in Brisvegas for some Aprilia starter and stator rewinding with mixed results but good enough for me to give them a rap. Been really good to deal with. One starter has been going really well, haven't tried the stator and another starter failed catastrophically but I expect they'll have another go free of charge...
http://automotivearmaturesaustralia.com.au/
Can you believe this... I couldnt,' I could by band new KTM item from bris ktm sheaper that getting mine repaired, & I was happy with the $ of the repair.
Vinny: What the fuck do you mean, replicas?
Sol: They look the shit, don't they? And nobody is gonna argue. And I've got some extra loud blanks, just in case.
Vinny: In... Oh, in case we have to deafen them to death?
shank is offline   Reply With Quote
Old 08-20-2011, 10:14 PM   #757
blackness
more riding
blackness's Avatar
Oddometer: 117
Thanks, doing a bit of research.
I'm hoping to up scale to a two bike family next year. The KTM twins always have me thinking.
Then its always a question of efi vs carbs and low kms vs the mid 40k kms that many 950s for sale seem to have at the moment.
blackness screwed with this post 08-20-2011 at 10:21 PM
Old 08-20-2011, 10:56 PM   #758
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,971
Ah they are only starting to loosen up at 40k
Actually I sort of half mean that, mine has 60k on it an runs beautifully. Revs nice and freely. 40k on these doesn't seem to be that much.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 08-21-2011, 01:16 AM   #759
rumguzzler
Oddometer: 45
I am not too sure about the warranty bit... I spose it would void warranty. After a 1200km ish ride on Fri/Sat, I can say that I experienced no ill effects from the Dalby Purge kit. However I did have a few ignition shut downs, that resembled the side stand cut off problem that others have mentioned. ( Bike would cut out for a second or so then fire up as usual) Could this be related to the fitting of the purge kit??? Maybe but I doubt it.... so I am now looking at disabling the side stand switch.
I really love these 990s but I tell ya.... its a love hate relationship out in the scrub.
Sorry to hear about your bad run with the guys at Dalby, I have never had a problem.
Matt
rumguzzler is offline   Reply With Quote
Old 08-21-2011, 11:17 PM   #760
Shakey!
Pants....That is all
Shakey!'s Avatar
Oddometer: 524
Laugh Got mine today!
Picked mine up at lunchtime from KTM Brisbane....
Only wish I'd got one sooner!!
Now to go get it dirty!
KTM 990 ADV "Zer Stuka"
Guzzi V7 Racer
Yamaha WR200
Kawasaki KLX250S
Shakey! is offline   Reply With Quote
Old 08-22-2011, 02:08 AM   #761
Gidyup
Lookin' round
Gidyup's Avatar
Oddometer: 445
Always pays to ask eh.
I am sure some of the parts price ripoff attributed to KTM are overstated at times.
Maybe my spirit is broken by a certain Dear John farm machinery parts.
Eat more Broccoli
Gidyup is offline   Reply With Quote
Old 08-22-2011, 02:11 PM   #762
evildingo
evildingo's Avatar
Oddometer: 420
Good luck Duck , have a look around at the antiquated grease pit they call a workshop . how could you work on any thing ? Disgraceful
Lets ride
Old 08-25-2011, 03:28 PM   #763
ozbikedude
so little time
ozbikedude's Avatar
Oddometer: 2,050
Originally Posted by ozbikedude View Post
what are the service intervals of a 990,oil and filter change at ......kms?
what is the average fuel economy litre/100km ball park figure will do.
expected kms of engine before rebuild 100000km+?
any other info common problems?
cheers aub.
nothing sweet about me
04 950 adv s
08 dr 650 (sold)
ozbikedude is offline   Reply With Quote
Old 08-25-2011, 04:35 PM   #764
ADVJake OP
***** dweller
ADVJake's Avatar
Oddometer: 4,341
heres one with 130kkm on it
looked good for another 100,000...
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 08-25-2011, 04:39 PM   #765
Shakey!
Shakey!'s Avatar
Oddometer: 524
According to my manual,
1st service is 1000klm, then every 7,500 after that.
Valves to be done at 15000 intervals
Cheers
Guzzi V7 Racer
Yamaha WR200
Kawasaki KLX250S
Times are GMT -7.   It's 04:25 PM.
