Old 08-04-2008, 09:01 PM   #121
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
SE disc
I wonder if you can get an adaptor to put the 640ADv Disc on the 950Adv.....
I doubt the single standard disc will be strong enough on the tar..... maybe with a bitey set of front brake pads....
I am looking at doing this myself. - do you have the part number for the SE master cyclinder??????
Joe
Originally Posted by shawty950
Just removed one disc and caliper. SE950 mastercyclinder(better feel) and good to go.
Makes the bike lighter...suspension reacts better and pops better monos ;-)
Doesn't quite pull up on bitumen like the twin setup...but I double the GF with sport rubber on and just have to use the rear brake a bit more.
Tis still more than powerful on the dirt.
Not sure what ya mean about the forks???
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 08-04-2008, 09:33 PM   #122
shawty950
shawty950's Avatar
Oddometer: 228
se m/c #
Joe
Hey Joe,
63013001000 HAND BRAKE CYLINDER 06 - US $127
edit...heres the link....as this one is crap....
http://65.57.254.60/munnracing/catal...RENDURO%20%20R
Done a heap of 2-up with this setup....cant do stoppies but couldn't do them with the twin setup either ;-)
Could give you the usual "FIGJAM" and how fast I ride...but you wont know if you like it till you try. Mate has done the same thing on his 04 and he wants more stopping power and for me its fine. We both ride the same speed solo and 2 up.
Shawty
shawty950 is offline   Reply With Quote
Old 08-04-2008, 10:30 PM   #123
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
cheers
Hey Joe,
Shawty
Cheers mate - I will order one of these and maybe an oversized disc. I can't quite rake up the bucks for the full oversized disc and caliper like Rory did - ($960 plus postage.)..
Joe
Simpson Trip 2008
Old 08-04-2008, 10:38 PM   #124
mysterio
Eventually an Adventurer.
Oddometer: 983
That is a 990, yes? I see 990 on the side panel. The forks look a different colour to mine, 07 990, so I thought you had done more serious alterations.
"This is the way the world ends/Not with a bang but a whimper." T.S. Elliot.
"This is the way the world ends/ Not with a whim but a banker." Paul Desmond
mysterio is offline   Reply With Quote
Old 08-04-2008, 11:17 PM   #125
Mouse
I'm only smelly
Mouse's Avatar
Oddometer: 8,830
my knowledge is now a bit rusty and i've not been tracking this thread but i'm pretty sure thats the way they set up the original single disc race bikes.
i also believe that the stopping factor is fine, I recollect reading a technical paper on diameter and the effect on breaking that somewhat concluded you don't need much of an increase in diameter to overcome a second disc.
I've always wanted to go to a single disc as the only flaw i think of the adv is its too biased forwards (which can be a blessing if you're in the hills)
afaik the se uses the same frame basically so the only real differences has to be in the upper fairing headlight switchgear stuff and the disc setup... my one ride ont he SE highlighted the fact its a lot better balanced for my liking.
like i said this is old knowledge and will need verification.
"Australian history... is full of surprises, and adventures, and incongruities, and contradictions, and incredibilities, and they are all true." Mark Twain
“It is better to stir up a question without deciding it than to decide it without stirring it up”
Mouse is offline   Reply With Quote
Old 08-05-2008, 04:12 PM   #126
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
thanks
I will try the SE mastercyclinder first. then look at over sized disc if I believe I need it.. I think I will.
Simpson Trip 2008
Old 08-05-2008, 04:43 PM   #127
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 1,658
I have a good contact for bringer ,there M\C are awesome may have to order apair for da 950 my self , But there pricey
Mudguts is offline   Reply With Quote
Old 08-05-2008, 06:30 PM   #128
MymoJoe
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,332
do tell
I would be interested in a 320mm disc, caliper and caliper carrier... what can your contact do!!!
Simpson Trip 2008
Old 08-05-2008, 11:38 PM   #129
Mouse
I'm only smelly
Mouse's Avatar
Oddometer: 8,830
put my thinking cap on - a measure they talk about in brakes is swept area which is, i understand, the area the pads would contact in one revolution.
here's some light reading though not on swept area.
he makes the point that a larger rotor gives you more force.
Old 08-06-2008, 02:42 AM   #130
ADVJake OP
i like stuff
ADVJake's Avatar
Oddometer: 4,319
talk to k2m, he has a single 320mm front disc on his adventure as well as a 4 piston caliper.
apparently pulls up the bike quicker than the standard twin disc setup.
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 10-21-2008, 04:52 AM   #131
atgreg
Africatwinarama
atgreg's Avatar
Oddometer: 9,758
mmmmmm, no posts in this one for a while, all broken down
1990 RD04 Africa twin 750
350,000km and still going strong
atgreg is offline   Reply With Quote
Old 10-21-2008, 01:57 PM   #132
1WD
KTM Tragic
1WD's Avatar
Oddometer: 754
Preparing for Mungo..
Pic for fun:
1WD is offline   Reply With Quote
Old 10-21-2008, 02:03 PM   #133
Mr Ogmore
no u
Oddometer: 427
Send a message via MSN to Mr Ogmore
will post a new pic of mine when my new seat arrives from the states, cant wait!
Mr Ogmore is offline   Reply With Quote
Old 10-26-2008, 02:31 AM   #134
KatoomDownUnder
Safer off a horse than on
KatoomDownUnder's Avatar
Oddometer: 948
My pic will happen once the Akro's are fitted. mmmmmmmm can't wait
Na cnuic tha lomnochd
's tha duilleach Foghair
mar bhrat air la\r,
am fearann caillte
dan tug na seo\id ud gra\dh,
a sheas an aghaidh
feachd uailleil Iomhair
's a ruaig e dhachaigh
air chaochladh smaoin
You're not drunk if you can lie on the floor without holding on.
KatoomDownUnder is offline   Reply With Quote
Old 03-16-2009, 05:59 PM   #135
kiwipeet
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 2,919
Thumb
Originally Posted by MonkeySpank
hey gang
just done the deal on a new to me 990 adventure
it's an orange one
still getting my head around an orange bike
derek
Nice one. Don't worry about the orange... it'll grow on ya like a yeast infection.
kiwipeet is offline   Reply With Quote
Times are GMT -7.   It's 08:30 AM.
