Go Back   ADVrider > Riding > Regional Forums > Australia
Old 03-29-2012, 04:54 AM   #946
Dan_B
Sunny Coast KLR'r
Dan_B's Avatar
Oddometer: 235
The T63 is a good tyre too
'04 Kawasaki KLR650
Dan_B is offline   Reply With Quote
Old 03-30-2012, 12:46 AM   #947
Buddy10
Oddometer: 46
Dunlop 606 worked well for 4500km to the KLRRR and home, lots of tar and they still worked well in the dirt / sand / rocks on the way home.
Growing Old .........Inevitable
Growing Up....... NEVER
Buddy10 is offline   Reply With Quote
Old 03-30-2012, 01:24 AM   #948
charlie59
Oddometer: 736
Seen a mitas eo9 today that had done 12thou and still had a bit in it.It come of a dr which would explain it.
charlie59 is offline   Reply With Quote
Old 03-30-2012, 01:31 AM   #949
charlie59
Oddometer: 736
Thought i would ask this here to save the shit fight,can you mix synthetic and mineral oil.Cleaning out the shed and have a few litres of four stroke oil just different types.Yes it does use a bit of oil. Cheers Charlie.
Old 03-30-2012, 05:55 AM   #950
griffo1962
griffo1962's Avatar
Oddometer: 1,608
I have done in the past to use up the odd bottle or 2......
griffo1962 is offline   Reply With Quote
Old 03-30-2012, 06:05 AM   #951
Fergy_klr_650
Oddometer: 4
Thumb
Thanks for replies think ill give the 606 a run. I havn't seen anything bad about it. 12000K's has got my interest will have a look at the EO9.
What about oil any help there? I enjoy doing my own services but don't know much about ......... Well anything really any advise would be appreciated.
Fergy_klr_650 is offline   Reply With Quote
Old 03-30-2012, 01:06 PM   #952
Buddy10
Oddometer: 46
Oils arn't Oils Sol. my advice is pick a good quality oil and stick with it, dont put Castrol in this month and Caltex next change etc, dont mix different bands of oil as they all have slightly different additives and these additives put different coatings on the bore, rings etc. If you change brands the new oil could clean the surface and take time to apply its own "coating" in which time the motor could use oil. Dont change to diesel oil (if you motor isn't new) as it has a much higher detergent level which will wash the bore and rings and generally causes high oil usage.
Old 03-30-2012, 03:12 PM   #953
shieldsy
shieldsy's Avatar
Oddometer: 247
Laugh Shock Porn
What a difference a shock makes !!
New Ricor installed and I love it
Highly recommended and fast shipping from the USA
shieldsy is offline   Reply With Quote
Old 03-30-2012, 04:49 PM   #954
Mowster
Stressed Member
Mowster's Avatar
Oddometer: 472
How much was the Ricor? ^^^
I did the "doo" the other day; certainly worth doo-ing!
The 'eagle mike' kit is tip top..
raising links are next...will report back
"No, it's not, it's all about you and your content-free word slurry. "
Mowster is offline   Reply With Quote
Old 03-30-2012, 05:35 PM   #955
Rumble
Rumble's Avatar
Oddometer: 1,790
Must have been a pussy rider Mine only got to 4500 km on a E09 . 10,000 with a E07 .About 4500 with a 606 if I take it easy but thats no fun . Most times less for some reason
Happiness comes from within, that's why it feels good to fart.
You Must Always Blow on the Pie Rumble's 2003 650 Transalp
2010 650 DR Suzuki
Rumble is offline   Reply With Quote
Old 03-30-2012, 06:01 PM   #956
shieldsy
shieldsy's Avatar
Oddometer: 247
Cool2
$586 AUD landed Mowster
Old 04-01-2012, 05:22 AM   #957
wiggywildwildwest
cranky bugger
wiggywildwildwest's Avatar
Oddometer: 760
amen to that !
Where you come from is gone. Where you thought you were going, Was never there. Where you are, Ain't no good unless you can get away from it.
wiggywildwildwest is offline   Reply With Quote
Old 04-01-2012, 03:59 PM   #958
Fogo72
I Bleed Green
Fogo72's Avatar
Oddometer: 1,562
E09 with 500 klms on it, mounted to a KLX680R.
Crap tyre.
Fogo72 is offline   Reply With Quote
Old 04-02-2012, 01:38 AM   #959
Buddy10
Oddometer: 46
I havent had any personal experience with the EO9 but have heard people say you must have the EO9 Dakar not just an EO9. The Dakar is supposed to be a better tyre?????????????????????
Old 04-02-2012, 02:22 AM   #960
triple hoe
triple hoe's Avatar
Oddometer: 268
Eek 2008 question
Has anyone had any trouble with either the front disk warping or the caliper seizing on the slides? One of these will be the cause of my squeaking front brake. The last set of pads wore completely out on one side while the other was only about half gone.
any opinion?
KLR 650, GSX 1100
triple hoe is offline   Reply With Quote
Times are GMT -7.   It's 07:07 AM.
